Can anyone advise me on what is out there, and where.
Looking for a compact multi emitter like the DQG XP-G2 or similar, thanks.
Mtn Electronics SSSP is a good choice.
Triple XPG2 in your choice of tints. Runs on 1x18650 cell. Driver is set at your choice of power level. Very small for a triple (the host is a shortened Convoy S6).
Thats a good choice but out of stock!
Any other choices?
The only small single-cell triple that I know of that isn’t a custom build is the DQG 26650.
Depending on your modding skills, you could try building your own. I’ve built 3 myself:
- Roche F12 - single-cell 18650. I modded it for triple XPG2 neutral on Noctigon with 4 amp driver. Required straight driver and star swap. Also built copper heatsink out of copper disks soldered together to fit below the star. Runs on 1x18650 (using unmodded battery tube) or 1x18350 (using a cut down body tube).
2. Sipik 58 - single cell zoomie AA size light. I modded it to run triple Nichia 219 high-CRI at 3 amps. Runs on 1x IMR 14500 cell. No longer a zoomie. Incredibly small for a triple.
3. Sunwayman C20C - single cell side-switch 18650. I modded it to run triple XPG2 on Noctigon. Each emitter a different tint. Driver is a DrJones Lumodrv with FET mod. Incredibly bright on Samsung 20r INR cells, but gets hot ridiculously fast, so I instead run it in an 18650 li-co protected cell. Still very bright, but a more manageable level of heat.
Maybe send RMM a message asking when he’ll have them in-stock again. If you don’t mind a 1-2 month wait, it’s probably well worth it.
C20C 3x Noctigon Nichia NVSW219BT-V1 R9050 D220 + Carclo 509
