Test/Review of 19mm CC 3000mA LED Driver 3 Modes, 5.5-12v, XM-L,SSC P7,MC-E
27 posts / 0 new
HKJ
HKJ's picture
Last seen: 1 day 2 hours ago
DSC_4908
DSC_4909
DSC_4911 DSC_4912
DSC_4913 DSC_4923
Driver is from lck-led.com
Official specifications:
  • Current regulated at 3.0A
  • Input voltage 5.5V-12V, (no more than 12V would be the best option for protection of LED board according to accurate test)
  • Buck Voltage Current Regulated circuit
  • Gives 80%~94% efficient output
  • Measures 19mm in diameter, and 8mm in height
  • Multi-Mode: Low(5%)/High(100%)/Middle(35%)
  • Designed for XM-L, SSC P7 & Cree MC-E LED for maximum output 300lumen-900lumens(C bin), 900-1000LM of Cree XM-L
  • 1xLED+, 1xLED-
  • Prewired, ready to use
Output Voltage:
2.8A(High)~ 1.38A(Middle)~0.25A(Low) --at any voltage level from 5.5V to 13.2V---Current regulated
Caution: No more than 3 D-size Li-ion Batteries (4.0V~12.0V) for protection this LED board,When overheat, automatically switch to Low mode, and flash one time per 5 seconds. When return to safe temperature, automatically switch to previous mode.
Measurements
Type: LDV9
Diameter: 19mm+21mm
Height: 10mm
Tested with XM-L2 (And it did survive).
The driver is not a 3A driver, but a 5A driver!
Driver has memory
A short off/on will change to next mode.
Modes: Low, medium, high
Medium uses pwm at 1kHz with 30% duty cycle.
Low uses pwm at 1kHz with 5% duty cycle.
High
19mm%20CC%203000mA%20LED%20Driver%203%20Modes,%205.5-12v%20HL
The driver needs about 5.5 volt before the output is stabilized, but it does not stabilize at 2.8 or 3A as the specifications says, it delivers 5A to the led.
The efficiency is also lower than specified, probably because of the higher current.
The low voltage warning activates at 5.5 volt.
19mm%20CC%203000mA%20LED%20Driver%203%20Modes,%205.5-12v%20HLDriver
19mm%20CC%203000mA%20LED%20Driver%203%20Modes,%205.5-12v%20HLLed
19mm%20CC%203000mA%20LED%20Driver%203%20Modes,%205.5-12v%20LH
When slowly increasing the voltage, the driver turns on at about 4.8 volt and goes out of low voltage warning at about 5.7 volt.
High
There is no pwm in high mode, only some high frequency noise.
WarningHeat
When the driver gets hot is uses pwm to reduce output.
WarningVoltage
Low voltage is signalled by two fast off then 5 seconds low light.
Medium
19mm%20CC%203000mA%20LED%20Driver%203%20Modes,%205.5-12v%20medium%20HL
In medium the average led current is about 1.5A. The low voltage warning activates at 5.6 volt.
19mm%20CC%203000mA%20LED%20Driver%203%20Modes,%205.5-12v%20medium%20HLDriver
19mm%20CC%203000mA%20LED%20Driver%203%20Modes,%205.5-12v%20medium%20HLLed
Medium
For medium the driver uses a 1kHz pwm with 30% duty cycle.
Low
19mm%20CC%203000mA%20LED%20Driver%203%20Modes,%205.5-12v%20low%20HL
In low the average current is about 0.2A (Remember due to pwm the actual current is 5A, but only in short pulses).
19mm%20CC%203000mA%20LED%20Driver%203%20Modes,%205.5-12v%20low%20HLDriver
19mm%20CC%203000mA%20LED%20Driver%203%20Modes,%205.5-12v%20low%20HLLed
Low
For low the driver uses a 1kHz pwm with 5% duty cycle.
Conclusion
The driver works fine and the heat warning is a nice feature.
But the high current has a great risk of damaging the leds, the current must either be reduced or the driver must be used for leds with higher current rating.
Notes
I am not very impressed with lck-led's custom service. I got one wrong driver and one driver that were far outside specifications (This one). I have sent a couple of emails to them, I got one question back after two weeks: did I want money back or a new driver. There was no explanation if it covers one or both of the problems and I do not know if they have sent me a new driver (That was my answer).
How do I test a led driver
List of all tested drivers
Edited by: HKJ on 04/13/2014 - 14:10
Jerommel
Jerommel's picture
Last seen: 1 year 6 months ago
Hmm… That’s quite a gamble then… :^\
One related noob question though:
What happens if you put a capacitor parallel to the LED, to eliminate the PWM ripple?
maciex93
Last seen: 4 years 2 months ago
I have the same driver and I have a problem becouse in low and medium mode led blinks a little every (i think) 5s. It is not any protection feature, and PWM. In high mode all is ok, only in low and medium something like this is happening.
Did you noticed any blinking of led?
HKJ
HKJ's picture
Usual it wont work, you need a rather large capacitor to eliminate the pwm ripple.
maciex93 wrote:
I have the same driver and I have a problem becouse in low and medium mode led blinks a +little+ every (i think) 5s. It is not any protection feature, and PWM. In high mode all is ok, only in low and medium something like this is happening. Did you noticed any blinking of led?
I did not see it, but it is difficult to see in my setup.
Jerommel
Jerommel's picture
If you don’t mind me going on a bit about this, how about some 100µF (tantalum SMD) for each Ampère at 1 KHz? (loosely based on 1000µF for 1 A at 50 Hz)
Or would it trouble the FET?
I assume it would be better for the LED and for its efficiency.
(sorry if it’s a bit off topic)
Hikelite
Soldering looks pretty sloppy, efficiency is rather weak (talking about all modes). I also have one of those and  blinks randomly. I have one with a big inductor that also does 5A and that one always get hot to 105C and output drops immediately to low mode. I am sure these drivers are random as random they can be. I do not know why they choose such small inductors for such currents and I am sure that one is not a high-end inductor for it's size.
HKJ
HKJ's picture
Jerommel wrote:
If you don't mind me going on a bit about this, how about some 100µF (tantalum SMD) for each Ampère at 1 KHz? (loosely based on 1000µF for 1 A at 50 Hz) Or would it trouble the FET? I assume it would be better for the LED and for its efficiency. (sorry if it's a bit off topic)
100uF at 1A will drop from 3.2V to 3 volt in about 0.02 milli second (1kHz is 1 milli second period time), that is to about 50% brightness.
Adding a capacitor will reduce the efficiency significantly for a pwm driver.
HKJ
HKJ's picture
It it had run at 3A the efficiency would have been better and the temperature lower.
Hikelite
Smile Yeah but it is not 3A
Jerommel
Jerommel's picture
HKJ wrote:
Jerommel wrote:
If you don’t mind me going on a bit about this, how about some 100µF (tantalum SMD) for each Ampère at 1 KHz? (loosely based on 1000µF for 1 A at 50 Hz) Or would it trouble the FET? I assume it would be better for the LED and for its efficiency. (sorry if it’s a bit off topic)
Aha..
So that sucks…
Surely though, a 7135 also uses PWM, but on a much higher frequency, right?
HKJ
HKJ's picture
Jerommel wrote:
Aha.. So that sucks... Surely though, a 7135 also uses PWM, but on a much higher frequency, right?
A 7135 does not use pwm, but most drivers using a 7135 adds pwm. The pwm can be anywhere from 100Hz up to above 10kHz.Using a high pwm frequency with the 7135 do have some problems, because the 7135 is not that fast to turn on, especially not when driving a pack of them from a single microprocessor output pin.
Here is an example from one of my driver tests:
The microprocessor has its output on for nearly 2us, but the led is only on for about 0.1us. The rest of the time is used for the 7135 to turn on.
Jerommel
Jerommel's picture
Then how can a 7135 stay cool, when it’s not on or off, but ‘half way’ or something, like a resistor?
(It does amaze me though how fast a 7135 has to be, to keep up with the PWM)
HKJ
HKJ's picture
Jerommel wrote:
Then how can a 7135 stay cool, when it's not on or off, but 'half way' or something, like a resistor? (It does amaze me though how fast a 7135 has to be, to keep up with the PWM)
It does not stay cool, but with pwm it has a long* time to cool off between turning on.
50us to 100us is a long time when the on period is 2us.
Jerommel
Jerommel's picture
Really?
So, just to verify, a 7135 just burns off excess voltage? Sad
Like when you run a LED on 3 Volts, from 6 Volts battery, with one 7135, the 7135 uses as much power as the LED??
HKJ
HKJ's picture
Jerommel wrote:
Really? So, just to verify, a 7135 just burns off excess voltage? Sad Like when you run a LED on 3 Volts, from 6 Volts battery, with one 7135, the 7135 uses as much power as the LED?? :^\
Exactly (Usual a led will be a bit above 3 volt and batteries driving a led will be below 6 volt).
If you want to measure voltage, you must do it when the driver is in max., a DMM will not show voltage correct when pwm is active.
Jerommel
Jerommel's picture
Good thing I still have some analog meters too.
Thanks for clarifying this.
Now I have even more questions.. Big Smile
I’m thinking Class-D amplifiers now, which is PWM, efficient and no ripple due to output filter…
HKJ
HKJ's picture
Analog meters have the same problem, they will both show the average voltage and that is mostly useless with pwm.
Jerommel
Jerommel's picture
I wouldn’t trust a DMM’s view on the average voltage.
For the rest this is all a bit over my head…
I find it hard to believe though that a, say, 100kHz PWM-ed power supply can’t be smoothed to its average with a coil and a capacitor, like a class-D amp loaded with a speaker.
How about this cute thingy to modify into a driver?
Probly not, but it’s tiny enough!
drivers.. where do I start..? Tired
HKJ
HKJ's picture
Jerommel wrote:
I wouldn't trust a DMM's view on the average voltage.
Depends on the DMM.
Jerommel wrote:
For the rest this is all a bit over my head... I find it hard to believe though that a, say, 100kHz PWM-ed power supply can't be smoothed to its average with a coil and a capacitor, like a class-D amp loaded with a speaker.
A inductor improves the smoothing very much. It is often called a buck or boost driver.
Jerommel wrote:
How about "this cute thingy":http://www.ebay.com/itm/281111416915?_trksid=p2055120.m1438.l2649&ssPage... to modify into a driver? Probly not, but it's tiny enough!
For an audio amplifier you do not really need to remove the switcher frequency, it is above the audible range.
It might be possible to modify it, but it is a waste of electronic. It is much more complicated than a driver and does not deliver much power.
Jerommel wrote:
drivers.. where do I start..? :tired:
You can check my website about drivers, all my reviews are collected there.
FrickelFreak
Last seen: 9 months 2 weeks ago
Soldering on this thing looks like this guy did it:
Thanks for the review, though!
Yours are the best!
FlashPilot
FlashPilot's picture
Last seen: 7 hours 11 min ago
Big Smile Big Smile I cant tell you how many times Ive torn apart budget flashlights and thought the exact same thing about the chimps that must have put them together. Its sad that so many people have absolutely no pride in their work or such justifiable disdain for their sweat-shop employers.
As always, thanks for the excellent review. I almost purchased one of these cursed drivers but didnt when lck-led’s customer service refused to answer my email questions.
Jerommel
Jerommel's picture
True, but you don’t want to broadcast the switcher frequency, speaker wires as antennas… Wink
Hence the coil (on the example just ‘beads’ though) and caps.
Thanks for your replies.
HKJ
HKJ's picture
Jerommel wrote:
True, but you don't want to broadcast the switcher frequency, speaker wires as antennas... Wink Hence the coil (on the example just 'beads' though) and caps.
That is correct, but not all manufacturers stays completely within the regulations. With a loose circuit board you do not even need to, because you can just say that the filter must be added to the finished product.
Robbieroflcopter
Last seen: 4 years 5 months ago
Any way to disable the low voltage protection? I want it to run on high until I shut it off. Nimh battery here.
HKJ
HKJ's picture
Write you own program for the processor.
Robbieroflcopter
Dang that was quick. Disregard my pm. Well that sucks. I was hoping to get rid of it. Now my light only runs on high for about 20 minutes. If I got rid of that it would go for over an hour.
pilotdog68
pilotdog68's picture
Last seen: 7 months 2 weeks ago
There’s probably a voltage divider circuit in that mess somewhere. If you can find the right one, removing a resistor could effectively disable lvp by tricking it.
