Frankentorch -or- The Modern ProLEDtheus
8 posts / 0 new
Tido
Last seen: 2 years 4 months ago
Some time ago I ordered one of the famed XM-L T6 drop-ins from Manafont. When it arrived, I was not really impressed with its output. Underwhelmed would be the proper description of what I felt then. It drew only 1,5A on high. So, like any flashaholic worth his salt, I decided to fix it.
First step: disassembly:
Disassembled drop-in
Unfortunately, I was a bit too enthusiastic with the hot air...
dead driver PCB
It's dead, Jim.
Well, I decided to revive this corpse. Not only revive, but improve. First, a new head driver PCB:
New PCB fittet
But I was really fed up with cramming the driver program into the ATtiny13, so I decided to replace it with a bigger model:
Cerebroectomy
Igor, fetch me a brain!
 New Brain
Unfortunately, the only pin-compatible chip is the ATtiny25V-10 SSU. Initially, I planned to use a ATtiny85V. But those (and the ATtiny45) are only available in the SU package, which is too wide.
Next, I waited for a lightning strike modified the BLF-VLD to take advantage of the increased program and data space. The initial flash programming was done before the chip was soldered to the board.
Initial Flashing
Now I added some components for proper click detection. It is easy to add to this PCB, as the I/O-pins needed are connected to the stars on the backside. A 100nF ceramic capacitor in series with a 10mΩ resistor and a diode is all it needs.
Extra Components
The main problem with this driver is the spring. It is too short to make contact to the battery in an L2P. Another problem is that the downward components are not mechanically protected. They are making direct contact with the flashlight body in the Sky Ray Seraph clone.
But there is an easy solution to this:
Second PCB
The PCB is a left-over from a 4 x AMC7135 I used for harvesting the regulator chips. I sanded down the component side to remove the copper traces and drilled a 5mm hole. This extra PCB is also an excellent base to mount a proper spring.
And here it is, back from the dead:
 It's alive!
The main improvement over the standard ATtiny13-equipped drivers is the increased flash-size. This baby is programmable and  has battery protection. It uses an additional special click-sequence to enter the extended group and sports a whopping 19 different modes (ten of which are terribly annoying strobe or morse modes). And there are still around 100 bytes program flash free.
jacktheclipper
jacktheclipper's picture
Last seen: 17 hours 33 min ago
IT'S ALIVE!
Very impressive .
E1320
E1320's picture
Last seen: 4 months 2 days ago
 Great job, very impressive. Perfection.
I am already visualizing the duct tape over your mouth.
JohnnyMac
JohnnyMac's picture
Last seen: 2 days 4 hours ago
Really nice work! 8)
bushytails
Last seen: 7 years 6 months ago
I've started removing drivers by cutting them out...  since there's no solder actually in the groove between the board and the body, I just slide a sharp razor knife down the back, cutting off the solder, and the driver board falls out.
Nice work!
--Bushytails
agenthex
agenthex's picture
Last seen: 7 years 1 month ago
Is there a regulator on the MF xm-l? Seems to be two chips.
Reading this makes you smarter: http://lesswrong.com/
Match
Match's picture
Last seen: 4 years 7 months ago
Outstanding mod, Tido!  I also like the extra step you took with the cap/resistor to help fix click detection.  Nice write-up as well....had me laughing Smile
Don
Don's picture
Last seen: 1 month 1 week ago
Very nice!
That's all.
The numbers from my light tests are always to be found here.
https://spreadsheets.google.com/ccc?key=0ApkFM37n_QnRdDU5MDNzOURjYllmZHI...
