Bell wire for tricky mods
7 posts / 0 new
18sixfifty
18sixfifty's picture
Last seen: 2 years 1 month ago
I have been looking for something like this for a while but hadn't thought of this. It's called bell wire and I found it on a rare trip to home-depot. It's basically one copper wire inside of very very thin insulation. It's fairly rigid but also thin. It's great for doing multi-emitter or anything where you want the resistance of a heavy gauge wire but don't have the room for it. It was cheap too ($7) and it really does work well for a number of mods. It's not the easiest stuff to work with for all mods though because it's ridged but actually for the multi-emitter stuff in particular it's perfect. Anything where you don't have the room it can work.
I’m a junky, I mod lights so I can sell lights so I can buy more light to mod so I can sell lights to buy more lights to mod.
Chloe
Chloe's picture
Last seen: 5 years 4 months ago
It’s handy stuff. I have used it for some applications needing the support of single core wire, like joining two PCB.
Firelight2
Firelight2's picture
Last seen: 7 min 21 sec ago
Nice find!
What’s the covering on the wire made of?
Sometimes I find that PVC tends to melt when I solder the end of the wire. That doesn’t happen with Silicone or Teflon wire.
18sixfifty
Firelight2 wrote:
Nice find!
It will melt if you need more than one try to get it right. I should have pointed that out, thanks for reminding me.
I don’t mind because I’ve gotten pretty good at getting it right now. Gotta love good flux.
18sixfifty
Hadn’t thought of that one yet, it would be perfect.
Rufusbduck
Rufusbduck's picture
Last seen: 7 months 1 week ago
Another common place for single strand wire is low voltage sprinkler wire that comes in multi conductor cables. 1’ of cable can yield 5’-7’ of conductor.
Scott
bushwhacked
bushwhacked's picture
Last seen: 6 years 4 months ago
I had some 24awg single strand lightly coated, it’s a fairly heat resistant coating, from cat5 ethernet cable.
Looks similar to what you have. I never really used it, far too rigid for my applications.
The coating doesn’t take well to abrasive movement or being bent against sharp edges.
P60dropins.com (just a redirect for now)
