I have several 1 modes and I love them but I’d like a well made 3 mode Here’s what I need
-zoomie of course
–3 modes. Either hi/med/low or hi/low/strobe but I need it to start on high not next mode
-and I need it to be a good copy not one of the crap ones
Are you up for an SK98? Basically the same, but sized for an 18650.
I like the SK68’s too, but the quality is a lottery even from the same vendor (hollow pill? solid? etc), and the driver diameter is too small to take commodity parts.
If you are interested in an SK98:
http://www.aliexpress.com/item/YUPARD-Mini-12W-1800LM-CREE-XML-XM-L-T6-LED-Adjustable-Zoomable-Flashlight-Lamp-Light-Torch/1389655076.html
This was the listing that a lot of us picked up during the spring sale for ~$8.50 iirc… (My only order in the last ~6 weeks!).
Mine arrived today, High - Low - Strobe. Starts in high. XML2, clean threads clean build.
Pulls a solid 3A from unprotected Panasonic NCR18650B 3400mAh, and a decent 2.6A from some old laptop pulls.
My only complaint is the silly metal ring used for the zoom friction, but thankfully that is a very simple fix.
Nice not bad at all
I got a SH98 from fasttech for $9.09
Same as above but XM-L, it had the next mode memory but easily fixable with the pencil lead on the capacitor mod
I have subsequently rebuilt it…using at first a 20mm TexasPyro Nanjg 8*7135 rebuild from OSHPark but managed to kill it somehow (worked GREAT for about 3 months) and further builds with empty brand spankign new from digikey Attiny 13’s won’t flash…so ended up getting the 20mm adapter boards, putting a regular 8*7135 Nanjg driver flashed with STAR V1.1 firmware with reverse static build (hi>lo memory off) and reflowing a T6-4C to copper 20mm sinkpad and then siliconing it into the pill…now it runs like a champ with 5 levels (turbo w/ 2 minute fallback, high, med, low, moonlight) from high to moonlight
