2014 - Contest Light - 1st place prize light - DONE!! Video added and beam shots are up in Post#1
I was not going to post anything till the end of the contest... Well, you had to know that would not last! I just figure there's a month gone already and not too many have started their builds, so here's a look at what the third place prize will be. It will either make you want to win third place, or it will make you want to run and hide, for fear you actually might get it as a prize.
This is what I started out with and as things progressed, the components also changed to suite the needs. This is a Solarstorm SP-03. I am going to put 3xMT-G2 leds in it. I am going to use 8x18650 batteries in 2S/4P configuration. It will be fan cooled. It will not look anything like the stock light... I sure hope it works.
I put this photo in, because I did not take any of when I cut the head apart. I used a hacksaw to cut the head in two, right where the switch was. I am going to extend the head, to have room for the heat sink, fan and driver.
This is the copper heat sink that will fit under the stock led shelf.
I did not like the dimples in the led pockets, so I drilled them out.
and replaced them with copper discs.
I got a finned aluminum heat sink and a fan. The fan here is not the one I ended up with. This one was 50x50x10 and the one I ended up with is 40x40x20. There was not enough foom for the 50mm fan, but the 40mm actually produced more CFM.
Here is the cut out heat sink and the fan is mounted on a copper plate. There is also a thermostat down in there, so that the fan only runs when the temp of the heat sink gets to 60C.
I started out using copper, to make the extension for the head. I softened it and made the bends on the table, as shown below.
The problem was that the piece was not tall enough, so I ended up going to brass sheet, which you will see later, but this was the method for bending the brass too.
I needed two bodies to hold the 8 batteries, so I used an old SRK body and put it together with the stock body. I had to cut down both of them, so that the overall length would be right for two batteries in series.
I did the human lathe routine, to fit the two bodies together and used some JB Weld to make sure they hold. I made the SRK body look like the stock SP-03 body by removing those ribs on it.
The bodies lined up well and I think it will work.
Ok, remember I said I ended up using brass for the extension. Well, here you can see what it looked like before cleaning it up. I also made a brass sleeve on the bodies to cover up the mess there.
I removed the components from the stock driver and I will use it for a contact plate.
The board in these two photos is one that was designed by Mattaus, for this build. Originally, I was going to do 9 amps per led and he designed this board for 3 legs with 9 amps per leg. I ended up backing off and going with 6 amps per leg after being cautioned on my folly, by comfychair. He was right, even with 2S/4P, there isn't a cell out there that would hold 27 amps for more than a few seconds, because of the low amp hour rating on them. They just would not last at all and when the voltage dropped a little, it would just go dim. So, I went with 16 chips per leg, for about 6 amps per led. It still won't last long, but it will be better than a 30 second wonder, (I hope).
Since I cut apart the stock switch hole, I decided to put the momentary switch in the handle. Here's a couple shots of that.
Here's a couple photos of the brass extension in place. I've cleaned it up a little and I ended up polishing with steel wool and clear coating it. The screws are stainless steel.
I ended up painting the body. There was no way I could clean it up well enough to leave it, so I used the same rough finish paint that I have done many times. I like the copper showing through.
I had to drill out the led holes in the reflector for the MT-G2 leds to fit. I used the drill press and I ended up drilling from the bottom, instead of from the top as shown. I just couldn't risk ruining the reflector by doing it this way.
I coated the copper heat sink before putting it in the head.
Then I wired up the leds and stuck them down in. I only used thermal grease here, since there is a bolt going all the way through the center and everything gets tightened down when the bolt tightens the reflector down into the head.
Finished product. One head ready for the next steps.
Luckily, I had a metric bolt laying around, but I had to file the head round, since it was a hex head and I cut a slot in it, so I could use a screwdriver to tighten it down.
The aluminum heat sink is glued down and the fan is in place.
The brass extension is in place too.
The top plate is copper and it is silicone in place. Hopefully it will help to seal a bit, so any water won't run into the driver area, but this is Not a water resistant light. It would be best to not expose it to rain.
I managed to get the slave board in and it's wired, but now I don't have a good master lying around, so I need to wait a few more days. Sorry.
I put a copper disc over the bottom side of the board, glued to the 7135 chips with AA. It might help a little with heat... or not.
I will put another disc or rectangle on top of the board, after everything is wired up and tested.
Last time, it looked like it was mostly done. Well, the driver came in from RMM and I hooked it up. It almost worked! Two leds worked as advertised and the driver cycled with the switch, but the third one just came on high and wouldn't cycle... Shorted to ground. I tore everything apart and found the reflector was pressing on the led substrate, causing the short.
Sooo... Time to make changes.
I put kapton tape on the reflector. See, most of these multi reflectors have metal between the led holes and that acts as a stopper. This one does not. The led holes rest right on the substrate. When it was an XM-L, it rested on the centering ring, but with the MT-G2, it rests on the substrate.
I also added three stoppers, so that the reflector will not compress too hard on the substrates.
The third thing I did was to switch to silicon coated wires. The Teflon ones were just too stiff to work well.
Now, I can reassemble everything and see how it goes this time.
Finished!
I don't have 8 batteries for it, so I am testing with 2S/2P Panasonics
And it works this time!
Final wiring
Shots of the finished light. It's a very strange looking light.
As I said, I don't have 8 matched batteries, but I did have 8 total batteries, so I tested them. I had to get it hot to make sure the fan works. The fan does work, but I wish I had used a 40C thermostat instead of a 60C. The head gets hot! Very hot! The batteries start to gim before the fan turns on, but it does turn on.
Almost a total success, but at least it does work. Guess I should be glad for that.
05-17-14 I am going to tear it down and use a lower temp thermostat, so the fan kicks on sooner and I need to tackle a ground issue, so it ain't over till it's over, but there's a beam shot in post #1 to tide y'all over.
Listen to the light,
Beam shots will be done tonight (6/4/14)
I have a Thrunite T10 with a Nichia 219 in it and a HD2010 that does 65k lux at one meter, for reference shots. I liked the HD2010 and I have used it quite a bit. I thought it was a bright light, well, not any more.
sbs1
T10
sbs2
HD2010
sbs3
OMG
sbs4
T10
sbs5
HD2010
sbs6
It literally hurts my eyes
sbs1a
HD2010
sbs1b
Wall of light
sbs1c
HD2010, I used to be impressed
sbs1d
Nothing will ever be satisfactory after this light.
The camera doesn't even do it justice. In real life, that blue haze is hardly even noticeable and the light is much brighter in person.
OK, that's it. I still did not use a matched set of batteries, but I ordered a set of eight of the 25R, to go with this light. Yep, it's now officially the brightest and most expensive light I have ever done.
Yep, it's now 1st prize in the contest... Hey, it is my contest ya know...
Sometimes I’m glad I have a really bad sleep schedule and get to see some crazy OL build before I finally hit the hay. :slight_smile:
I think this is the most custom build I’ve seen to date. Incredible. Can’t wait to see the finished product.
This is… WOW. :slight_smile:
wow… good thing I’m still up… now I can go to sleep and dream I’m a lighting thief holding this flashlight :smiley:
OK, Old-Lumens has finally gone off the deep end, and I don’t think there’s any coming back.
The good news is that some of you are going to reap the rewards of this most fortunate development :wink:
Im completely blow away by this monstrosity! I knew you had something in the works with active cooling… but man, you’ve gone way over the top! Friggen awesome! :bigsmile:
HOLY!!!
WHOAH! That thing is going to pump out the light!
Certainly not all your designs appeal to me, and find the amounts of massive copper in the builds usually overdone, but this monster has what it needs inside to make it work (8000 OTF lumens? 6A runs the MT-G2 at 75% of max, which is my personal sweet-spot for mods), and the looks are on its way to look perfectly scary and awesome!!
Thanks OL in advance. I was never in the comp to win it but to come third. You have my mailing address and thanks for putting us all to shame.
Wow, that is one epic light!
Holy cow, that’s awesome.
Hmmm, what a precarious situation. You’ve gotta make something good, but not too good. But you’ve gotta hit just the right amount of not too good. Too much not too good might drop you to 4th. Not enough not too good and you might inadvertently hit second. So the question is, what is the right amount of not too good?
I don’t envy you.
(I don’t envy anyone who tries to read and understand the entirely of this post either)
Anyway, good luck!
Wow, that’s a monster! :expressionless:
Awesome light Dr Frankenstein. That sucker will start fires.
Even if he found the perfect amount of not too good, that right amount of not too good may still be too good and win first or second, if others also try to position themselves for third, making the right amount of not too good, still too good, and too much not too good perfectly not too good by not being too good compared to other peoples interpretation of not too good. Of course without hindsight, the wrong amount of not too good being the right amount of not too good is again, purely speculative.
My guess is that lights use in Victoria, NSW, Tas and SA during the summer months, would be banned due to the fire danger.
o m g - what a build!
looking forward to the day it will be alive :smiley:
hahaha nice that’s not a flashlight, that is a cannon of photons :slight_smile:
Yikes!
I’m drooling… This is just the third place prize?!
That’s the kind of beauty & craziness I like, great work! :smiley:
I’ll be using forced air cooling because I like the concept . . . that thing actually needs it.
To whoever gets this thing: I see abdominal muscle aching from all the giggling in your future! :stuck_out_tongue:
