Another TR-J19 Mod: 3 x XM-L2 @ 5A per Emitter
34 posts / 0 new
Ouchyfoot
Ouchyfoot's picture
I know the TR-J19 has been reviewed and modded by other members already, so here's another mod anyway.
You cannot really grasp how enormous this light is from looking at pictures, it's awesome, and built like a high end light.
Here it is beside a FandyFire/LusteFire 3XML. I used to think that light was obscenely big, but the TR-J19 dwarfs it.
I purchased it with modding in mind. The stock driver put out just over 1A per emitter.
So...let's get this over with.
The stock XMLs were on 16mm aluminum MCPCBs so I replaced them with XM-L2 U2 1A on 20mm Noctigons. I had to file down one edge so they would fit.
Everything was wired up with 20AWG 19 strand Teflon wire.
I used an LCK 5A 3 mode driver. The building and mounting of the contact board and driver is well notated in my DIY Tutorial thread.
http://budgetlightforum.com/node/30864
This light has a weird set-up for the driver mount. There is an odd shaped spring locked between two nylon discs in the retaining ring that press down on the drivers battery in pad. It is not soldered onto it. Also there is another large spring that presses against the ground ring. I really don't know why it's there
I discarded one of the nylon bushings and the large spring that doesn't do anything. I then soldered copper braid to the board and soldered down the spring.
I like double copper braid on my springs. This is how I do mine. If there is an attached spring, I remove it first, solder down the braid, and then thread it up through the spring. Then I solder down the spring.
Okay. That's all installed and tested. Everything is working fine. I still don't know why they bothered with that cheap large spring. If anything, it would keep the retaining ring from making good contact. I'm glad I chucked it.
Since this is a hobby, I like to take a little extra effort withe the tailcap.
This light has one of those brass spring caps, but when I removed it, it was solid 1cm thick brass. I always like a copper connection, so I drilled a hole through the center of the cap. That took me a lot of time with my dremel.
I flooded the hole and the end of a copper rod with liquid flux, inserted the rod into the hole and hit it with heat and solder. I chopped off the rod and filed it down flush. A nice copper core.
After the spring is double braided, this is how it will fit together after it is in its collar. The end of the copper rod will jam into the top of the braided spring. I don't know if the results are worth the effort, but I don't mind doing it.
(The light came with an Omten switch)
I guess that's about it.
With three Sony US26650VT I'm getting a tail reading of:
High - 5.02A (per emitter)
Med  - 1.35A
Low  - 0.15A
I thought I might get higher than 5.A Per emitter. The exact same 4.5A version from IOS goes into direct drive on high. I'm wondering if this one is staying in regulation?
The J-19 and Tangsfire/Lustefire have pretty much the same diameter reflectors, but the J-19s is a lot deeper, giving it a smaller, tighter hotspot. I'll have it out tonight. It looks like it might be one hell of a thrower.
This torch is so massive, I had to order three Trustfire unprotected 32650s for it. They should arrive this week.
I just couldn't get a good picture to represent the depth of the J-19 reflectors.
And as always with my show off lights, I capped it with my signature "clear" bootcap.
THE END
Edited by: Ouchyfoot on 05/05/2014 - 19:47
bushwhacked
bushwhacked's picture
Last seen: 7 years 2 months ago
Very nice. Seeing all these multi emitter mods makes me want to get one.
P60dropins.com (just a redirect for now)
downlinx
downlinx's picture
Holy cow that light is huge, I love it, can I send you mine to do, hehe. J/k
BLF Community Battery Pull Thread http://budgetlightforum.com/node/32720
M4D M4X
M4D M4X's picture
Last seen: 1 year 1 month ago
very nice Mod!
thanks for showing!!!
PLEASE NOTE
i do not work in "reviews, deals and codes" for the time being
maybe M4D M4X will return one day, but until then:
THANK YOU FOR YEARS OF YOUR SUPPORT AND FRIENDLY CONTACTS!
Chazzy
Chazzy's picture
Can’t wait to see the beamshots!
"Whoa that's a bright light!" ... Yea I guess.
MRsDNF
MRsDNF's picture
Laughing Nice effort. Looking forward to the comparison shots. What batteries do you have on order?
Ouchyfoot
Ouchyfoot's picture
Trustfire unprotected 32650.
I don’t know about beamshots. All I have is an ipad, and it tends to make them all look the same. It also gets all mixed up trying to focus controlled light at distances. It can’t decide whether to focus close or far.
Tom E
Tom E's picture
Last seen: 1 month 1 week ago
Ouchy - the last Super Shocker I did (couple weeks ago), I used an old IOS 4.5A driver and found it was current limiting! I know the earlier 3.5A drivers were not. So, I simply jumpered the resistors, then that got her opening wide to 6.2A or so -- highest amps I ever got in a Super shocker.
Ohh! Exc. mod by the way. Always wanted to do a J19, and those copper mods are real nice. Shouldn't have to worry about melted springs for sure.
Ouchyfoot
Ouchyfoot's picture
Yikes! I’ll have to try that. I hope the resistors are on the top, because the bottom of this one is mounted in Fujik.
I have a few of those IOS 3.5A drivers that I’ve never used.
I’ll PM you if I need help locating them. (Resistors)
Tom E
Tom E's picture
They are underneath, unfortunately. There's a pile of them. The older 3.5A drivers seemed to not need the jumpers though.
Ouchyfoot
Ouchyfoot's picture
Thanks Tom. I’m not crying about only 5A per emitter. It’s kind of nice having a really nice light that can be made even nicer when I’m out of projects. I got some more 5A drivers in the mail today. I’ll compare them to the 3.5A ones, see if there’s something different.
unknown00101
Did not realize how much I needed a J19 until right now. That is a truly beautiful and massive light. Great mod too!
Ouchyfoot
Ouchyfoot's picture
It’s dark and I just took it outside for a test. Wow. This thing can really throw!
With the deep reflectors and all that horsepower, this thing can really move some light.
18sixfifty
18sixfifty's picture
Last seen: 2 years 11 months ago
Nice mod. I love the J-19 most bang for your buck of all the large head mutli-emitters possibly just the best. It is huge though. But still it’s easier to carry than the Shocker simply because the weight is balanced. It does actually weigh slightly more than a shocker but not a lot.
I’m a junky, I mod lights so I can sell lights so I can buy more light to mod so I can sell lights to buy more lights to mod.
Tom E
Tom E's picture
Btw, lately I've been getting just the Shocker as a host for $75 shipped from RIC. Just add emitter/stars and a driver - perfect setup for modding. It does carry like a Thor hammer though. I still don't own one...
18sixfifty
Tom E wrote:
Btw, lately I’ve been getting just the Shocker as a host for $75 shipped from RIC. Just add emitter/stars and a driver – perfect setup for modding. It does carry like a Thor hammer though. I still don’t own one…
That’s good to know.
Ouchyfoot
Ouchyfoot's picture
I haven’t gotten around to modding my shocker. I haven’t had it apart yet.
Tom. I see you grind down some of the reflector. Is it that close, or is that done mostly for dedomed emitters?
unknown00101
How do the reflector / reflector wells compare Btu vs J19 vs the tk70 clone (roughly is fine, don’t need measurements, just curious).
Ouchyfoot
Ouchyfoot's picture
When you say “wells”, do you mean the depth of the reflectors? If so, I just pulled out my shocker to see, and the reflector depth of the TR-J19 seems to be the same as the shocker. The diameter of the shockers reflectors are larger though.
I haven’t seen my shocker since I bought it. I forgot how cumbersome it is.
Tom E
Tom E's picture
Well the bottom of the reflector is completely flat, so been grinding out indents for the wire connections, since the stock wires are thinner - price to pay for thicker better wires.
RaceR86
RaceR86's picture
Last seen: 6 years 7 months ago
Nice mod! Thanks for the pictures. Its nice to see them side by side like that.
You just confirmed what I have seen before. I don't like the J19 compared to the Lustefire.. Looks too vulgar/tacky. I dunno.  And its so much larger and heavier, yet, it does not have wider reflector for more throw. It just limits spill. And the larger tube for the larger trustfire batteries.. I prefer 26650, which I have lots of. So always a spare set of quality batteries available. Either for high amps or runtime.
When buying the lustefire you also get the nice HX-1175B driver. Yeah, the lustefire is more my cup of tea.
btw, the lustefire is in my latest beamshots comparison. Along with many other BLF favorites.
BLF LED database – collaboration spreadsheet and latest news about where to buy LEDs
http://budgetlightforum.com/node/19342
unknown00101
Yep that was what I was curious about, thank you.
I love how ‘compact’ the btu is (though it is quite hard on the wrist because of it).
The plunger style of the J19 is nice too and the fact that you can use 32650 is just awesome. I will definitely have a J19 sometime in the future. Smile
Interested to see how your 32650’s fare in this beast.
Ouchyfoot
Ouchyfoot's picture
RaceR86 wrote:
You just confirmed what I have seen before. I don’t like the J19 compared to the Lustefire.. Looks too vulgar/tacky. I dunno.  And its so much larger and heavier,
It certainly is monstrous with that fat battery tube. I just wish the Lustefire was machined and designed with as high of quality as the J19. I don’t know anyone that knows about LED lights. They all refer to those dollar store torches when you mention them. This is a pure show light, intended to make the jaws of the unenlightened drop. They’ll be in awe of it before it’s even turned on. It’s my one of a kind light, so I invested in some 32650 cells that will live in it permanently.
Yes, vulgar and decadent it is, but, Wow!
WarHawk-AVG
WarHawk-AVG's picture
Last seen: 2 years 4 months ago
Wow! Incredible!
Thing is going to be a BEAST!
djozz
djozz's picture
Last seen: 2 days 17 hours ago
Very impressive, sounds like well over 4000 lumens.
PersonallyI would not worry about driving it any harder, it will make the emitters more fragile, the heatsinking will be more critical, and who will see the 20% more output?
Ouchyfoot
Ouchyfoot's picture
I’m going to keep it this way. It seems to be regulated at 5A, so with the new 32650 it will have better run time too. It’s funny how I was so ecstatic the first time I ever attained 5A per emitter, now I feel like its some kind of a failure. This hobby makes you nuts!
Ouchyfoot
Ouchyfoot's picture
Besides the BTU Shocker, Lustefire/Tangsfire 3XML and TR-J19, are there any more of these large reflector flashlights out there that I haven’t seen. Those are the only three I can think of.
Tom E
Tom E's picture
The SolarStorm SC03SP03 is 85mm head diameter... Different setup though with parallel cells, but nice to have 4 cells.
Here: wallbuys-SolarStorm-SP03, and here: fasttech-solarstorm-sp03
Oopsie!
Ouchyfoot
Ouchyfoot's picture
Tom E wrote:
The SolarStorm SC03 is 85mm head diameter… Different setup though with parallel cells, but nice to have 4 cells.
I just looked it up. SC03 takes 1 x CR123.
RaceR86
RaceR86's picture
Ouchyfoot wrote:
Tom E wrote:
The SolarStorm SC03 is 85mm head diameter... Different setup though with parallel cells, but nice to have 4 cells.
SP03 is included in the beamshots comparison I just did..
Ouchyfoot
Ouchyfoot's picture
Ah yes SP03, not SC03. I’ve been getting a little tired of 4P soupcans lately. I needed a break from them. I could convert it to series, but a side switch limits driver choices.
I’m thinking of converting my 1 x XML Nage to a triple with series cells.
