Group Buy for the GearBest Ultrafire F13 - Closed?
312 posts / 0 new
wight
Last seen: 2 years 6 months ago
processengr wrote:
I haven’t received mine yet. I have a noctigon star with a XML2 and a Driver that I purchased from IOS for a P20…will it fit?
Who knows? You should post some dimensions.
Most of this is available elsewhere on the forum: The stock driver is 22mm in diameter, the cavity above that is >20mm in diameter – so you can piggyback anything smaller than that. The stock LED is mounted on a 20mm star, so you can use either a 20mm star or a 16mm star. I’m not sure whether the thickness of the Noctigon will have an effect.
Still fine, still on a break. One day I’ll catch up with you folks! previous wight catchup Wink
list of my drivers & variants (A17DD, FET+1 stuff, WIP stuff, etc)
musket3
Last seen: 10 months 2 weeks ago
clicking on the link gives me this, 404 ERRORNOT FOUND!
Has anyone else gotten this error?
This is the url at the top of the page, http://www.gearbest.com/led-flashlights/page_not_found
wight
This link?
http://www.gearbest.com/led-flashlights/pp_5499.html
It works for me.
max
max's picture
Last seen: 3 days 3 hours ago
Order W1405200719495112
Order Date: 05/20/2014 22:19:49 PM
“Tracking Details >> SGxxxxxxxxxx9276
Not found .”
 max
musket3
This is the url I get when I click on the link you posted.
gearbest
gearbest's picture
Last seen: 1 year 4 months ago
strongest2004 wrote:
Ordered last May 10. No info where my order is till now…
Hello strongest2004,
Sorry for this problem, could you please pm me your order number, I will keep track of it, thanks.
It’s WW1405090932288077.
Kindly advise once you tracked it’s current location.
Thanks
I just checked your order#, since you selected Flat Rate Shipping which is unregistered mail, no tracking number is available with this order therefore the shipping progress cannot be traced online.
However I’m delighted to inform you that your order is on its way. The standard delivery time will be around 15-45 business days after dispatch if there are no delays. Please don’t worry,the package can reach you in due time. Thanks.
wight
Most likely something is wrong on your end. Possibly something on your computer is modifying URLs. Try a different browser.
hank
hank's picture
Link works fine for me.
Note, I am signed in to the site; it would not work for me if I weren’t signed in there.
ohaya
The link that wight provided (which is the same as the one in the OP), works for me:
or, you can go to their home page and put:
ultrafire ceee xm-l
in the search box (yes, “Cree” is misspelled).
wight
Really? I tried it without being signed in to GB – it seemed fine.
musket3
musket3 wrote:This is the url
I tried all 3 of my browsers, firefox, chrome and IE. None work, everything else works fine on my computer.
Then I tried this,
ultrafire ceee xm-l
This worked, search for ultrafire ceee xm-l, and brought up 1 light, then when I clicked on the light I got the error message again. I am signed in to my account on their web page. I give up.
WarHawk-AVG
WarHawk-AVG's picture
Last seen: 2 years 3 months ago
I know it has a 20mm star, the reflector centering ring is quite thick so I don’t think a noctigon/sinkpad thickness will be an issue if you either use a thinner centering ring or thin it down a bit…
wight
Noctigons and Sinkpads are thinner, not thicker, than standard aluminum MCPCBs.
Old-Lumens
Old-Lumens's picture
Last seen: 5 years 9 months ago
All of the 16mm and 20mm aluminum stars I have are thinner than any Noctigon or Sinkpad I have.
Just sayin...
My PayPal address: oldlumens (insert the @ sign here) gmail.com
My YouTube Flashlight Video Channel
The BLF Modding Links Thread
http://imageshack.com/a/img922/1374/jQ2wdL.jpg
Gj
Gj's picture
Link works for me without being logged-in.
wight
Just sayin…
I seem to have lots of thicker ones. I think that the aluminum stars I have from Illumination Supply and SinkPAD are all thicker than my copper Noctigons, but on the other hand the inexpensive Chinese stars are probably thinner than those. I have no idea what’s in the F13 head, I haven’t removed the MCPCB yet. My bad Sad
ohaya
Then I tried this,
ultrafire ceee xm-l
That is might weird :(…
I’ve seen things like that happen if I am pointing to some incorrect DNS server, or if the browser has the proxy setting wrong.
Have you tried clearing your browser’s cache? That might help also.
strongest2004
strongest2004's picture
Last seen: 2 years 8 months ago
Thanks
As per our offline discussions which you affirmed, I will wait only for a max of 40 days after my payment was placed. If I don’t have my order by that date, I will file for PP dispute already.
Thank you.
Low mode and long runtime lover…
hank
hank's picture
I had placed a different order on 4/20 that arrived 5/30, I think it was.
No surprise, stuff happens.
My order for this light was on 5/16.
I’d have paid for tracking if I wanted to be able to complain about delays.
I didn’t.
Sometimes delays happen and no one can explain.
MRsDNF
MRsDNF's picture
I bought quite a few of these in two shipments. The second shipment has arrived. In it there were two different drivers. Some had no mode memory, always starting on high after being off for about five or six seconds with tailcap measurements of 2, 1.45 and .75 amps. The other had next mode memory with tailcap measurements of 2, .75 and .3 amps. The pencil trick worked to get this light to always start on high after about 5 seconds.
ohaya
Did the ones with the different drivers also have different labelling? Wasn’t the original one for this GB a “SkyFire” or something, and then they switched to “Ultrafire” (now)? Maybe that was the reason for the driver differences in yours?
MRsDNF
MRsDNF's picture
The five I have so far are all Ultrafire. Two different drivers.
ohaya
Aargh :(!!
WarHawk-AVG
is the driver ring reverse threaded? I cannot for the life of me get mine to come loose
Got it…not reverse threaded…took alot of elbow grease and some very choice words and threatening to get the big hammer Big Smile
Fixed that supid next mode memory…upgrading soon, going to put a XM-L2 on sinkpad, not sure if I want to put a nanjg in, or resistor mod this driver, solder braid upgrade, thicker wires (the basic upgrades) to see how well it does, 1.7~A high stock…bleh
Chicken Drumstick
Last seen: 8 hours 24 min ago
Just got mine today. Seems ok for the price tbh. No real visible PWM that I can detect. Pulls 2.11amps on high.
Beam is good. Next mode memory sucks though. What exactly is the ‘pencil’ mod?
Also any tips on getting to the Led? Bezel comes off easy enough but haven’t managed to get the lens out.
WarHawk-AVG
ON the driver there is a capacitor right next to the MCU (controller chip), you take a #2 pencil and scrub it across the top from one side to the next, the graphite creates a high resistance shunt across the resistor, when you turn off the light, it drains the capacitor down resetting the MCU back to default (hi mode) next time it comes on, this way when you turn off the light, wait a few seconds, turn it back on, it always comes on hi, you can actually go hi>mid>lo>off back to hi>mid>lo without ever going to the epileptic seizure flash modes, but the modes are still there if you need them.
otherwise with next mode memory it goes hi>off>mid>off>lo>off>strobe(epileptic seizure)>off>sos(epileptic seizure)>off back to hi
Old-Lumens wrote:
Here’s a photo of the stock driver.
f131a
From what I understand, you can use a pencil or a resistor on top of the capacitor (highlighted in BLUE), to remove next mode memory.    As far as a mod for higher amps?? I don’t know. I thought you might be able to shift the Positive led wire over to the spot highlighted in YELLOW
jdunlap27284
Last seen: 8 hours 31 min ago
Received my 2 in the mail today. Both worked fine, thought there was something wrong with the lens but it was plastic stick on protection. Smile When I removed the body and tailcap they threaded right onto my 3c DST which was a nice surprise. Was wanting to do that conversion for awhile, was a nice bonus.
Chicken Drumstick
f131a
Thanks. I’ll give it a go. Although the driver in mine doesn’t look like that. More like the one posted earlier in this thread.
nofearek9
nofearek9's picture
Last seen: 1 week 6 days ago
all those parallel resistors ,do they effect the current ? in case we add more on top of them.
ohaya
See: http://budgetlightforum.com/node/31213#comment-579563
Apparently, you can move the + lead on the driver to the other output pad to get higher current…
