Group Buy for the GearBest Ultrafire F13 - Closed?
312 posts / 0 new
Muto
Last seen: 3 hours 46 min ago
MRsDNF wrote:
I bought quite a few of these in two shipments. The second shipment has arrived. In it there were two different drivers. Some had no mode memory, always starting on high after being off for about five or six seconds with tailcap measurements of 2, 1.45 and .75 amps. The other had next mode memory with tailcap measurements of 2, .75 and .3 amps. The pencil trick worked to get this light to always start on high after about 5 seconds.
I received my 2 today and as yours was, mine also have different drivers.
The one with next mode memory was the hotter of the 2 measuring 2.2 on high, after moving the + wire to the other output tap and performing spring braid mods, it now pulls 3.40 on high! and output drops quick (Need a sinkpad:), 1.75 on medium and .45 which is a nice low.
This light has a warmer tint than the lower output one. Did the pencil mod on the Cap and it resets real quick now. Love that Mod!
The one with the quick mode reset pulled exactly 2.0, 1.0, and .50. Talk about some spot on regulation.
After same mods as the above one, it increased to 2.82, 1.45, and .70
Output does not tank as quick as it’s hotter brother and pulls some comparable ceiling bounce numbers.
With the slightly whiter tint, it is very close to the other light in appearance of beam. Hot spot on these lights is fairly tight.
To sum up, these are very nice flashlights, the threading is much better than I was expecting and the lens are nice and clear, reflector is very nice with no flaws. Each light had the protective cover on the glass, nice touch.
Now, after a simple Noctigon upgrade, I will have 2 very nice budget lights.
Big Thanks to Old Lumens for putting this together and Gearbest for delivering the goods, even if it was aboard the slower boat from China Smile
Thanks,
Keith
The difference between Hoarding and Collecting is the illusion of Organization
.“I will get one of flashlight from patrol car”
“History doesn’t repeat itself, but it sometimes rhymes,” Mark Twain
After the Apocalypse there will be only 2 things left alive, Cockroaches and Keith Richards
hank
hank's picture
OK, so one of two (so far) drivers, and the first one mentioned earlier is shown at
http://budgetlightforum.com/node/31213#comment-585597
(where we also read “The led shelf is part of the head, no removable pill”
ohaya
Hi,
How are you all getting the driver retaining ring out? I tried (want to move the + lead), but it wouldn’t budge :(!!
WarHawk-AVG
WarHawk-AVG's picture
Last seen: 2 years 4 months ago
ohaya wrote:
Hi,
I had to hork the ever loving bejesus out of mine to get it loose
Not sure if they glued it in or they used a Chinese version of Arnold Schwarzenegger to put it in…but it was in there good!
Muto
ohaya wrote:
Hi,
I use a pair of snap ring pliers from Harbor Freight, but yes they were flexing a bit before the ring let loose.
If you do not have these or some strong tweezers you could try tapping a sharp punch tip with a small hammer on one of the dimples. The vibration of the tapping may loosen it easier.
Good luck,
Keith
ohaya
Hi,
Ok, I got the ring out. I had to use a spanner wrench to do that. Here’s what I have:
As you can see, the pad where the + lead is attached is labelled “26650+”, and there’s another pad (also circled in yellow, but unlabelled).
So, to get higher current, do I unsolder the red lead from the “26650+” pad and move it to the other pad as shown in the image?
Thanks,
Jim
Muto
That’s where to move it.
I untwisted mine to make the wires as long as possible for the soldering procedure, then re twist.
Pencil that Cap while you have it apart.
Enjoy!
Keith
ohaya
Muto wrote:
That’s where to move it. I untwisted mine to make the wires as long as possible for the soldering procedure, then re twist. Pencil that Cap while you have it apart. Enjoy! Keith
Thanks. I’ll give that a try when I have a chance. I had good results on a different light (this one: https://www.fasttech.com/products/1700404) with a similar mod, so it should be a good one.
This F13 is turning out to be a heck of a deal, huh, thanks to O-L and gearbest!
WarHawk-AVG
ohaya wrote:
Hi,
Thanks,
Jim
Yes, you can’t see the traces, but that long row of resistors, it is between the output pin of the 8 pin FET and the 26650 pad, current limiting resistors, the pad on the other side completely bypasses the resistor bank you get the FULL output that the FET can produce. If you really want better power to the emitter, then get thicker gauge wire as well.
APM9435 datasheet
PDF”:javascript:openreq(‘http://pdf.datasheetcatalog.com/datasheets2/12/126018_1.pdf’)
Pins 5,6,7,8 are all the drain (tied together)
P.S. When you move that wire put some heat sink compound under your star…mine came with none, it WILL get hot when you move that wire…count on it Smile
ohaya
WarHawk-AVG,
Ahh. So by moving the + lead to the other pad, and bypassing that bank of resistors, it’s basically really direct-driver + the Rds for the FET, on high mode?
And yes, I was thinking that I’d go to heavier leads while I was at it, and thanks for the reminder re. adding some thermal compound under the star.
EDIT: BTW, I don’t know if it’s just with the light I have, but I’ve noticed that there’s a bit of a doughnut hole in the center of the beam when it’s up close.
Looking at the reflector and centering ring, it seems like the centering ring might be a bit too thick, so the top edge of the centering ring is almost at the same height as the top of the XM-L dome. Has anyone tried tweaking the center ring piece, or maybe tried one of the butterfly-type insulators instead, or maybe even just some kapton tape instead of the centering ring?
WarHawk-AVG
Some have replaced that thick centering ring with a thinner centering ring/insulating gasket
wight
Last seen: 2 years 6 months ago
ohaya wrote:
WarHawk-AVG,
It’s DD either way. Nothing but the overall resistance of the light (including the driver) limits the current. Those resistors are there to reduce current, I simply wanted to point out that it’s DD with or without them. They don’t actually regulate the current, just reduce it.
Still fine, still on a break. One day I’ll catch up with you folks! previous wight catchup Wink
list of my drivers & variants (A17DD, FET+1 stuff, WIP stuff, etc)
nofearek9
nofearek9's picture
Last seen: 2 weeks 2 days ago
ohaya wrote:
nofearek9 wrote:
all those parallel resistors ,do they effect the current ? in case we add more on top of them.
See: http://budgetlightforum.com/node/31213#comment-579563
Apparently, you can move the + lead on the driver to the other output pad to get higher current…
desides that solution,i am talking if you want even more ,if there is a way to do it with those resistors.
Chicken Drumstick
Last seen: 2 hours 49 min ago
Has anyone else notice the beam is a little weird.
The hot spot is a perfect circle, odd for a LED with a square die. And the hot spot is larger than other XM-L lights I have (both bigger and smaller SMO reflectors).
Anyhow I removed the reflector and the white centring ring. The reflector then drops a lot further over the LED. But sadly this doesn’t improve the focusing, it makes for a very defused hot spot. You actually need to elevate the reflector a bit to get the best focus, but without the white centring ring the focus is still poor, not all that tight and ringy. Makes me wonder if this lens isn’t really optimised for an XM-L size emitter and output angle.
With the white ring back in place it returns to what on a white wall looks like a good hot spot, very round, very well defined and very large. But it must be an effect of the white plastic ring causing this. Shine another XM-L light next to it and you’ll see a slightly less round smaller hot spot but much more intense (even one pulling less amps).
This translates outside, the throw on my F13 is quite poor. My Convoy M1 OP reflector easily out throws it by quite a margin.
Not sure if any of this makes any sense of not. Probably easier to see in person than words.
ohaya
No, you are making sense. I did much the same experiment last night, by removing the centering ring and putting tape on the end of the reflector instead to insulate it. Just as a test, because without the centering ring, it was hard to get the reflector to center (it moved when screwing in the head). That got rid of the doughnut at close range, but the beam had lots of rings.
I noticed that the reflector has a kind of large flat area around where the emitter is, compared to other XM-L lights, which looks a little strange?
Jerommel
Jerommel's picture
ohaya wrote:
Jerommel wrote:
Quote:
P.P.S. I think I found the same light at FT, with reviews. Seems like it can take 10440s:
http://www.fasttech.com/reviews/1343701/2791
I wouldn’t put a 14500 in that.
It’s like all cheapies inside.
It’d be a 10440 rather than a 14500 :), but we’ll see…
Of course, 3.7Volts anyway, with which these ‘drivers’ can’t do anything useful.
You will smoke it..
ohaya
I moved the + lead to the other pad on the driver, and tailcap increased:
Battery 1: 1.26 amps => 1.7 amps
Battery 2: 1.69 amps => 2.1 amps
That was just with moving the lead. I didn’t change to different wires, because I wanted to be able to see the effect of just the one change.
FYI, the insulation on the factory wires doesn’t seem very heat resistant, so be care when soldering them.
downlinx
downlinx's picture
wow, that is quite the change. I wonder how much a difference it would be if you add 18g wiring.
BLF Community Battery Pull Thread http://budgetlightforum.com/node/32720
Gj
Gj's picture
Last seen: 1 month 4 weeks ago
Has anyone else notice the beam is a little weird. The hot spot is a perfect circle, odd for a LED with a square die. And the hot spot is larger than other XM-L lights I have (both bigger and smaller SMO reflectors). Anyhow I removed the reflector and the white centring ring. The reflector then drops a lot further over the LED. But sadly this doesn't improve the focusing, it makes for a very defused hot spot. You actually need to elevate the reflector a bit to get the best focus, but without the white centring ring the focus is still poor, not all that tight and ringy. Makes me wonder if this lens isn't really optimised for an XM-L size emitter and output angle. With the white ring back in place it returns to what on a white wall looks like a good hot spot, very round, very well defined and very large. But it must be an effect of the white plastic ring causing this. Shine another XM-L light next to it and you'll see a slightly less round smaller hot spot but much more intense (even one pulling less amps). This translates outside, the throw on my F13 is quite poor. My Convoy M1 OP reflector easily out throws it by quite a margin. Not sure if any of this makes any sense of not. Probably easier to see in person than words.
No, you are making sense. I did much the same experiment last night, by removing the centering ring and putting tape on the end of the reflector instead to insulate it. Just as a test, because without the centering ring, it was hard to get the reflector to center (it moved when screwing in the head). That got rid of the doughnut at close range, but the beam had lots of rings. I noticed that the reflector has a kind of large flat area around where the emitter is, compared to other XM-L lights, which looks a little strange?
I tried without the centering last night, too. I was surprised how much the reflector could drop and disappointed with the beam, but then I thought it might be very helpful with a de-domed emitter. Everyone complains about not being able to get the reflector low enough after de-doming, maybe this will turn out to be a plus.
ohaya
I don’t know yet, as I haven’t tried that. A bit of a time soldering still (eye surgery a couple of months ago), so I’m trying to take things easy, but I did just do the solder wick on the tailcap, and after that:
Battery 1: 1.26 amps => 1.7 amps => 2.1 amps
Battery 2: 1.69 amps => 2.1 amps => 2.6 amps
FYI, Battery 1 is an old laptop pull (dark blue wrap) and Battery 2 is a “20R” battery.
Also, I’m just using the normal meter leads, so the tailcap current is probably higher, right?
I know you all normally recommend doing the solder wick on the springs, but this is the 1st time I did it, and I’m kind of amazed at the difference it made :)!
ohaya
Gj wrote:
Has anyone else notice the beam is a little weird. The hot spot is a perfect circle, odd for a LED with a square die. And the hot spot is larger than other XM-L lights I have (both bigger and smaller SMO reflectors). Anyhow I removed the reflector and the white centring ring. The reflector then drops a lot further over the LED. But sadly this doesn’t improve the focusing, it makes for a very defused hot spot. You actually need to elevate the reflector a bit to get the best focus, but without the white centring ring the focus is still poor, not all that tight and ringy. Makes me wonder if this lens isn’t really optimised for an XM-L size emitter and output angle. With the white ring back in place it returns to what on a white wall looks like a good hot spot, very round, very well defined and very large. But it must be an effect of the white plastic ring causing this. Shine another XM-L light next to it and you’ll see a slightly less round smaller hot spot but much more intense (even one pulling less amps). This translates outside, the throw on my F13 is quite poor. My Convoy M1 OP reflector easily out throws it by quite a margin. Not sure if any of this makes any sense of not. Probably easier to see in person than words.
What did you do to insulate the reflector (prevent it from shorting)? Did you put tape on the end?
I keep thinking that an MT-G2 would fit nicely in that reflector opening, but don’t have an extra one at hand…
Gj
Gj's picture
What did you do to insulate the reflector (prevent it from shorting)? Did you put tape on the end? I keep thinking that an MT-G2 would fit nicely in that reflector opening, but don't have an extra one at hand...
It was just a quick look to see what difference removing the centering ring would do so I didn't insulate it. Not a problem with the small reflector and 20mm star. The opening is only 7mm, an MT-G2 needs 9mm just for the dome.
ohaya
What did you do to insulate the reflector (prevent it from shorting)? Did you put tape on the end? I keep thinking that an MT-G2 would fit nicely in that reflector opening, but don’t have an extra one at hand…
It was just a quick look to see what difference removing the centering ring would do so I didn’t insulate it. Not a problem with the small reflector and 20mm star. The opening is only 7mm, an MT-G2 needs 9mm just for the dome.
I was thinking that the F13 reflector has that rather large flat area around the emitter area, and that the opening could be opened up a few mm to fit an MT-G2…
Gj
Gj's picture
ohaya wrote:
I was thinking that the F13 reflector has that rather large flat area around the emitter area, and that the opening could be opened up a few mm to fit an MT-G2...
Not too difficult to get 9mm for the dome, might be tricky if you want to set down over the entire square package.
ohaya
Gj wrote:
Not too difficult to get 9mm for the dome, might be tricky if you want to set down over the entire die.
I have another (different) light that i put an MT-G2 into, where the reflector opening just barely fit the dome (the entire dome, but not the die), and that has a very nice beam… no rings, etc., so I think that the opening wouldn’t have to be large enough for the die, just the dome. Unfortunately, as I said, I don’t have a spare MT-G2 at this time to try it though…
wight
Let’s keep our terms straight. You two are referring to the ‘package’. The ‘die’ is something else.
ohaya
Sorry, you’re right :)…
Gj
Gj's picture
Right, edited to prevent future confusion.
The problem with just clearing the dome is the that the reflector can cut into the soft surface.
jmpaul320
jmpaul320's picture
Finally brokedown and ordered. Paid $7 after GB points Smile
Would you mind keeping the wrong flashlight?
Best wish, May
Tmart service team
Soumil wrote:
PLEASE HELP ME GEARBEsT! IM LITERALLY CRYING!
TheFlasher
Last seen: 3 months 4 min ago
Ordered one, this will be a hold me over and a comparitive flashlight for when I get this Xpower 26650 @FT
