Eneloop AA BK-3HCC 2450mAh (Black)
/DSC_5029.jpg)
Official specifications:
/Eneloop%20AA%20BK-3HCC%202450mAh%20(Black)-info.png)
Maximum temperature raise at different discharge currents: 1A:+1,2°C, 2A:+3,0°C, 3A:+5,3°C, 5A:+10,8°C, 7A:+16,4°C, 10A:+21,2°C,
The newest generation eneloop where the Panasonic name is in large types. I got these batteries from directly from Japan.
/DSC_5026.jpg)
/DSC_5031.jpg)
/DSC_5032.jpg)
/DSC_5033.jpg)
/DSC_5034.jpg)
/Eneloop%20AA%20BK-3HCC%202450mAh%20(Black)-Capacity.png)
Like last generation eneloop these batteries can handle high current draw.
/Eneloop%20AA%20BK-3HCC%202450mAh%20(Black)-CapacityTime.png)
/Eneloop%20AA%20BK-3HCC%202450mAh%20(Black)-CapacityTimeHours.png)
/Eneloop%20AA%20BK-3HCC%202450mAh%20(Black)-Energy.png)
/Eneloop%20AA%20BK-3HCC%202450mAh%20(Black)-PowerLoadTime.png)
/Eneloop%20AA%20BK-3HCC%202450mAh%20(Black)-CurrentTest.png)
/Eneloop%20AA%20BK-3HCC%202450mAh%20(Black)-Charge.png)
Conclusion
Like all eneloop I have tested this is very good batteries.
Notes and links
The batteries was supplied by a reader for a review.
Compare to other AA/AAA batteries: Alkaline/NiMH/Lithium
/DSC_5029.jpg)
- Cell size: AA / LR6 / R6 / MN1500
- Dimensions (radius x length): 14.5 x 50.4mm
- Mass: 30g
- Nominal capacity: 2550 mAh
- Brand name: Panasonic Eneloop Pro
- Cell type: LSD NiMH (low self-discharge nickel metal hydride)
- Memory effect: No (can be topped-up with no long-term capacity reduction)
- Cell voltage: 1.2V
- Colour: Black
- Charge retention after: 1 year 85% (stored at 20°C)
/DSC_5028.jpg)
/DSC_5026.jpg)
/DSC_5030.jpg)
/DSC_5031.jpg)
/DSC_5032.jpg)
/DSC_5033.jpg)
/DSC_5034.jpg)
Conclusion
Notes and links
Thank you for the tests!
http://eneloop.pl/uploads/BK-3HCC.pdf
Thanks HKJ, good work.
Still fine, still on a break. One day I’ll catch up with you folks! previous wight catchup
list of my drivers & variants (A17DD, FET+1 stuff, WIP stuff, etc)
Thanks as always great test
Fenix TK61 MOD> resistor, transistors, copper heatsink, Artic Cooling MX4, dedome, 3A > 5.7A ~ 1700 lumens > (600.000cd)
These seem to perform slightly better than the HR-3UWXB predecessor.
- LEDs & Other Stuff - - UI CheatSheets - - CRX Flashlight Builds - - CRX Stuff for Sale -
is there anywhere to buy these yet?
thanks for the test!
edit: found here http://www.ebay.com/itm/High-End-Model-Panasonic-eneloop-Pro-AA-2450mAh-...
but expensive and have to buy from overseas right now
http://budgetlightforum.com/node/25192
Yea, but just a bit. It’s only noticeable at high currents
He’s doing a GB soon
This difference might be due to the equipment (The difference is about 0.002 ohm).
I have switched to new equipment for these test and all future NiMH test. I have batteries for 8 more NiMH test, some of are already tested and will be published soon.
Cool, thanks
For those looking for a local source, these appear to be the same as the Duracell 2450mah NiMH rechargeable, Made in Japan, batteries available here in Canada (and I assume elsewhere).
The Duracell 2450mah NiMH MIJ batteries have identical end caps to the Eneloop pro 2450mah batteries, and are sold alongside the old white top 2000mah ‘Duraloops’.
I have a pack awaiting a Sunwayman F40A.
