looking for flashlight very short distance and very wide range and very fight from right to left
Hello,
I`m looking for flashlight very short distance and very wide range and very fight from right to left,
” i will walk on beach/shore to try to find crabs and other fishes so i will go in water untill 80cm max
so i want to use the flash light to see the water/ i mean underwater but i will not put my flash light underwater ” sorry my english
so the range will be very short like from my foots to 8m max i think
and i would love to find very wide range and all is light from right to left
thank you
thank you
Ugly as a mud fence….but waterproof
https://www.fasttech.com/product/1188302
Actually a mule light with no reflector might give you the widest flood vs any sort of reflector
Most flashlights will be water resistant to a point, but submersion you need an IPX7 rating or better
P Code Meaning & Test Standard of the ip 100 water inject flow
IPX0 No special protection
IPX1 Protected against falling water Equivalent to 3-5mm rainfall per minute for a duration of 10 minutes. Unit is placed in its normal operating position.
IPX2 Protected against falling water when tilted up to 15 degrees - Same as IPX1 but unit is tested in 4 fixed positions - tilted 15 degrees in each direction from normal operating position.
IPX3 Protected against spraying water - Water spraying up to 60 degrees from vertical at 10 liters/min at a pressure of 80-100 kN/m2 for 5 min.
IPX4 Protected against splashing water - Same as IPX3 but water is sprayed at all angles.
IPX5 Protected against water jets - Water projected at all angles through a 6.3mm nozzle at a flow rate of 12.5 liters/min at a pressure of 30 kN/m2 for 3 minutes from a distance of 3 meters.
IPX6 Protected against heavy seas - Water projected at all angles through a 12.5mm nozzle at a flow rate of 100 liters/min at a pressure of 100 kN/m2 for 3 minutes from a distance of 3 meters.
IPX7 Protected against water immersion - Immersion for 30 minutes at a depth of 1 meter.
IPX8 Protected against water submersion - The equipment is suitable for continual submersion in water under conditions which are identified by the manufacturer.
You don’t want a hotspot if your looking in the water.
convoy s2 +
yes i know, so much one you recommend me ? i can pay untill 150$
Isn’t the Ultrafire 502B supposedly water resistant?
P60 dropin with aluminum foil wrap mod, OP reflector
Video for the 504B water test
501B soaking in the bathtub
http://www.e2fieldgear.com/zebralight-flashlight-sc600-mkii-l2-neutral-white/#reviews
Of course there are a handful of budget lights we could suggest, my #1 pick in your price range is the ZL
Very bright, Great flood, NW tint, SOLID construction, awesome UI. IPX7 rated too.
He wants a flashlight that:
1. has a very wide field of view
2. is usable only for very short range
3. has no hotspot
This really sounds like he wants a mule flashlight with no reflector.
Elliptical. Elliptical is the word you are looking for. There are a few carlco optics that have an elliptical beam pattern if you want to build your own light from scratch, or just search google for “magicshine lens”. That will point you in the right direction. The results should look something like this:
i dont care about resistance much, but im looking for light that has short range , wide view and penetrate the water
i will not use it for diving
i just want to use it while im above water to see in the water like 80cm max range in the water
correct even if there is lil bit spot no problem but i want it to penetrate water for 80cm max if more its no problem
I use my Trustfire x100 out crabbing, and nothing else really compares. The flood helps you spot crabs in your peripheral vision, and the 16000mah battery capacity ensures you have decent run time since I’m often out there for hours. Using my c8 as a backup is like being in a black hole in comparison.
I just received a headlamp like this
The beam is very wide in flood mode, over 1.5m wide at 1m distance, more than 2m when I look into the floor with the head lamp on my head. Beam nice and even brightness, no artifacts.
The brightness is about 400-500lm. Modes are: High>Low>Strobe>Off. Build quality is ok. Works on 1 or 2 18650. Not water proof, probably not even splash-proof.
may i ask how do you know that this flashlight give wide view or spotted or long range or short range ?
i tried to look at products and this seems best i think ? big flood i think
maybe i can find big and more lighitng
have anyone saw this product ? it said Digital focus like mixed flood and spot
CLICK HERE
Found this zebralight h602w seems very wide angle :smiley: but i dont know if the light is good, i just feel its alil bit not hight light
thank you , i think Zebralight Flashlight SC600 MKII L2 - Neutral White is different than Zebralight H602w right ?
because i saw it on youtube Zebralight H602w has very very wide angle
you are looking for a “mule” (no reflector, so no hotspot, can still see 30 feet out) light it sounds like. Spark and zebralight have a few lights like that. Safe to use around water.
Or you are looking for an aspheric light. when zoomed out it also produces no hotspot. not sure about water tightness.
Look up those two kinds of lights in the search bar up in the top left of the page.
no need to worry about brightness. they will be very bright.
I just picked up the Carlco 20mm Elliptical TIR, and it sounds like it’s exactly what you want. I put it in my Convoy S2+, and I LOVE the beam. Super wide, and very narrow. I’ll try to get the beam shots tonight.
