A probably much cheaper “12 x XM-L” light from Trustfire would likely give the same or better performance at less the cost.
You think I’ll look silly taking the dog for a walk with this
And a lot more portable.
Is kicking the railway tracks the correct way of testing?
It has a built in tripod though
SK9800
I wouldn’t mind having one. The base and telescoping arm are nice for hands free lighting, the run time is huge, and the flood/throw reflector switching is nice.
how much is the thousand dollar question
Very hefty price. The MSRP: $999.00
Streamlight
Rapidly deployed and easily stowed, the Scene Light brings 3,600 lumens to your work area. With its narrow footprint and 72” extension pole, this light goes almost anywhere, from wide open places to tight, confined spaces.
Six C4® LED and wide reflectors produce a uniform flood pattern
Three user-selectable outputs:
High for a super-bright flood beam; 3,600 lumens, 31,000 candela, runs 5 hours
Medium for an intense beam and longer run time; 2,400 lumens, 20,000 candela, runs 9 hours
Low for when a less intense beam is ideal and for longer run times; 1,100 lumens, 11,000 candela, runs 18 hours
Selectable diffuser settings for two beam widths
Optimum peripheral illumination for scene lighting; 90° swivel neck allows you to aim the beam where you need it for task lighting
Sealed lead acid batteries, rechargeable up to 500 times
Batteries will continue charge while operating directly from an external 12V DC power source when using the remote cord so you can be confident that you will always have a light when you need it
Indefinite run time when using 12V DC power cord
Integral D-rings allow attachment of the included shoulder strap
Design allows for the light to be used in confined spaces and rugged terrain
Balanced design and easy setup:
Less than 30 seconds for full deployment
Pole extends to 72”
Cord built into the pole to avoid snags
Stabilization legs provide balance on uneven surfaces
Lead acid batteries provide ballast and stability
25 lbs (11.3 kg) provides weight stabilization, but is light enough to carry
Packs to a compact size (22”; 55.88cm) for easy stowage
High-impact thermoplastic housing; weatherproof construction
Available in Safety Yellow with AC and DC charge cords and shoulder strap
Assembled in USA
Limited lifetime warranty
I was accurate to 0.1% :bigsmile:
If you have to ask, you can’t afford it…
i knew that the minute i clicked on the thread
Looks like it’s price regulated at $619.95.
I could use one, but wow.
The concept is good and the runtime is great, but it weighs 11.3kg and listed at $999?
+1 on kicking the tracks to test it.
The only things that look interesting to me are the head. reflector switching and mode selection all in one. the base is interesting too
Perhaps the guy was kicking the clamp down sets, looking for loose tie downs or spikes. Reckon he knows his job better than I do, with all that light on him and the video rolling he should know to look busy right?
price is all wrong.
MSRP ~$22,000 USD, as 90% of their sales will be to the US Government (as is even indicated in the video), and they like to waaay overspend on things.
you’re probably pretty close, have to pay for all the red tape don’t ya know!
