-Forward voltage of- -ZLLS410- S4 diode. Edited- This is NOT a Zener mod
56 posts / 0 new
Rufusbduck
Rufusbduck's picture
Last seen: 7 months 1 week ago
Edit-Only need to know this to calculate the voltage on pin 7. Once that is done the diode will be pypassed for the voltage divider.
Thread covers a different type of higher voltage mode for an FET based converted 105C board. See Post 19 for a description and Post 35 for the beginning of the mod.
Has anyone measured the voltage drop on this diode in use ? It’s the one in the shopping cart for many of the Oshpark project boards. The data sheets indicate somewhere between .3-.4v depending on the current to the mcu. The actual value affects the choice of resistors for the voltage divider.
Scott
Edited by: Rufusbduck on 05/28/2014 - 06:43
Cereal_killer
Cereal_killer's picture
Last seen: 1 year 11 months ago
The one marked 4 1 correct? I haven’t but I can tonight when I’m working if no one else has the data.
Rufusbduck
Thank you C_k, I want to parallel RMM’s efforts on the voltage ladder for the Zener mod but it hinges on correct data for this diode and the existing Qlite diode(if different). The Qlite specs quoted from Mtnelectronics are 2.9-3v step down and 2.8v imminent shut off and I assume this is the voltage under load and accounting for the diode drop pin 7 should see less than that. I’ve heard .25v thrown around but the 41 shows to be more like .3-.4v so pin 7 might trigger when Vcc is as low as 2.4v or as high as 2.55. The actual voltage pin 7 sees is determined by R1&R2 and is somewhere around .47-.5v depending on the diode. If we keep the 4.7k R2 and just replace R1 then knowing the diode drop allows us to choose the correct value for R1. I’d like to order some 0805’s ASAP.
Scott
Cereal_killer
Will it matter if I measure on a 105c or a 17DD? Either would have stock resistor values.
None of my 105’s have one of those diodes, they all have stock S4’s but if that’s important I could swap one out to get a measurement on a 105.
Rufusbduck
Go ahead and measure the S4, please. I have some of the digikey cart diodes at home.
Scott
Rufusbduck
I compiled a list of different values for R1 keeping R2 the same at 4.7k ohms using different forward voltage drops on D1. This is for a Zener mod of drivers and firmware that use 19.1k and 4.7k for R1 and R2.
Assuming that the battery voltage under load trips lvp at 2.8v and that R/(R1+R2) = .1975 for those two values then when the voltage drop across D1 is:
Case #1, .25V pin 7 sees .1975 × (2.8-.25)=.50V
Case #2, .3V pin 7 sees .1975 × (2.8-3)=.494V
Case #3,.35V pin 7 sees .1975 × (2.8-.35)=.484V
Case#4, .4V pin 7 sees .1975 × (2.8-4)=.474V
I went to the mouser catalog and looked up replacement resistors for R1 that would give these same voltages when the battery voltage was 5.6V or (2 × 2.8V).
For D1= .25V, R1= 47.5k ohm
For D1= .3V, R1= 48.7k ohm
For D1=.35V, R1= 49.9k ohm
For D1= .4V, R1= 51K ohm
Mouser has these values in 0805 1% for ~ $.10 each so as soon as I get some decent values for VD1 I’ll order some to try out.
Even at a full charge of 8.4V pin 7 will still see less than 1.1V so I don’t expect to blow any mcu’s however…
I realize that this is somewhat different than what RMM did so I expect this will be all wrong and I’m not encouraging anyone else to try this but just posting what my plans are.
Scott
wight
Last seen: 1 year 8 months ago
Why is the voltage divider placed after the protection diode anyway? Seems to me that we’d be just as well off not having the diode in the mix other than providing VCC to the MCU.
Still fine, still on a break. One day I’ll catch up with you folks! previous wight catchup Wink
list of my drivers & variants (A17DD, FET+1 stuff, WIP stuff, etc)
Microa
Last seen: 6 hours 14 min ago
I thought they avoid to modify the Nanjg board. It should work to place the voltage divider after the protection diode.
wight
Microa – yes, after the diode does work. Results change when the diode is swapped for a different value. If we put the voltage divider before the diode (only use the diode for VCC) then we would have no need to worry about diode value.
Microa
Sorry my typo. I meant the voltage divider directly connected to VCC is OK.
wight
Gotcha!
Rufusbduck
The protection diode isn’t in this part of the circuit for the Zener mod but to calculate the correct voltage that pin 7 sees normally it no needs to be accounted for. If you were to remove it from a normal 105c then the protection wouldn’t register until the battery was dangerously low.
Scott
wight
My point is that you are setting yourself up for a job that will end up needing to be done again in the future. Why bother when we can eliminate the task you asked about (measuring vDrop on the protection diode and changing formulas in the firmware)?
You didn’t start the conversation about a normal 105c, it was about Oshpark boards. If we modify the design to supply the divider with BAT+ instead of hooking the divider up to the protection diode then we’ll simply need to adjust resistor values to achieve the appropriate ratio for the divider. That’s a one time job, changing brands or models of resistor in the future will not have an effect on the voltage supplied to the ADC (unlike changing brand/model of diode). VREF will be constant, unaffected by the diode or absence thereof. Hopefully you see my point now?
EDIT: adding pic for clarity, see below.
Rufusbduck
I saw your point before and it is my intention to bypass the diode for Zener mods but to correctly figure out what resistors to use I need to be able to account for any diodes being used now. Doing a Zener mod and keeping low voltage detection with any driver that has the diode in front of the divider requires knowing the voltage drop of the diode. Obviously if the diode doesn’t precede the divider then the correct values can be anticipated.
Scott
comfychair
comfychair's picture
Last seen: 5 years 7 months ago
I have not measured the diodes directly, but, when using the DrJ firmwares that blink out the battery voltage, it gives the same number of blinks as the original Nanjg S4 diode. That's only a resolution of 0.1v but it doesn't have to be that close. It's not like a cutoff of 2.8v/cell vs. 2.7v/cell will make a significant difference in actual use. I think nearly all cells get their factory capacity ratings from being run down to 2.75v anyway (some even cheat and run them all the way down to 2.5v).
wight
Sorry, I couldn’t see where you were coming from there. Now it makes sense to me!
Rufusbduck
I confuse myself sometimes. I should not have mentioned the digicart diode since the S4 is likely the only one I need to worry about but I wanted to solve the general equation before moving to specific examples. CC is quite right about the resolution here but since margin of error is additive I’d like to do what I can to not make it worse. Mainly I’m just stumbling along trying to figure this stuff out and posting my ignorance for all to see. Usually Texaspyro will come and save the day with dry wisdom. I was never shy about asking the stupid question in class.
Scott
Rufusbduck
I think the error factor might be more of an issue using two cells as slight cell imbalance combined with .1v or more error might be an issue. I guess it depends on how far apart the cells are when the combined voltage hits 5.6V.
Scott
wight
Do you mind restating, in it’s entirety:
  • what you are trying to achieve right now
  • what you need in order to accomplish it
Rufusbduck
In other words “get organized”(thank you Wallace&Grommit)
I will be using a 105C board with the 7135’s removed and the mcu replaced with one flashed for me by Dale.
It will have an Lfpak56 FET since I have some(rated for 100A) and fits the board with no overlap of ground ring. The pins don’t match the 70N02 so I won’t be using an Oshpark board.
Existing 4.7k R2 and new value for R1(somewhere between 47k and 51k).
The 7135 position closest too output traces cut, D1 as the jumper for Vin, a jumper wire from Vout to Vcc.
Voltage divider disconnected from Vcc and jumpered to Vin using current L+ pad or somewhere on the pwm trace after D1.
After all the work on the Oshpark boards by others I must be just a glutton for punishment. Here’s a pic of the board I’ll be modifying. Q3 is where I’ll put the voltage regulator and I’m thinking of drilling through the pwm trace for a direct path for L+.
Getting back to the main topic of the thread, if I connect the divider to B+ before the diode I need to know the voltage drop of the diode but if I’m using the same diode and connect the divider after the diode I just use 2.8v per cell to recalculate R1? This doesn’t seem right to me. I think you still need to know the voltage drop across D1 to get the correct value for R1 but wth do I know? Maybe you’re right in that not knowing VD1 won’t give you the exact value of the actual voltage read by pin 7 but will still give you the correct resistance value if you match that offset value. I think I need an Ervin translation. Smile
Scott
wight
Cool. Yeah, you are clearly in it for the pain. With your simple changes I’m sure someone here would be willing to generate a PCB if you had a change of heart.
  • You need to keep D1 because LD2981 does not have reverse polarity protection, right?
  • I think you’ll need a second fly wire to get from the protected side of the diode (towards the outside of the PCB) back to Vin on the LD2981.
  • You’ll need the support caps for LD2981 I suppose, so you’ll either need to keep C1 in place and add an input cap for the LD2981 somewhere or you’ll need to strip C1 and place both input and output caps somewhere for the LD2981.
  • In order to use C1 you’ll need to cut both of the other traces leading away from the via – the one that goes to D1 and the on that goes to R1.
  • Once you consider your cap needs it seems easiest to me to cut the trace that feeds the divider and use a fly wire to attach the divider to BAT+.
So that looks like 3 fly wires to me, several cut traces, and stacking 1 cap (the input cap) on top of the pins for the LD2981.
Rufusbduck
This is a mod I worked out originally almost 2 years ago(minus the FET and divider correction in 7135 drivers with higher voltages and yes it requires some caps and jumpers. Here is a pic of how that mod was done. It ran 3 XML’s in series from 12V input. I ended up just stacking the caps on the pins of the regulator. This was before I knew of the MTG (before Gen1) and I never used it because of the lack of low voltage detection. It’s kind of exciting to finally be almost in position to use this idea after so long.
Edit-oops! Here’s a pic with the regulator in place sans caps. It appealed to me because of the sot89 package.
At the time I was also toying with better heat sinking for 7135’s.
Scott
wight
Your drawing shows D1 as “remove”. That’s fine, but you’ll have no reverse voltage protection.
You’re still talking about a diode though, so I suppose you plan on putting it back… somewhere?
Rufusbduck wrote:
[snip]Getting back to the main topic of the thread, if I connect the divider to B+ before the diode I need to know the voltage drop of the diode but if I’m using the same diode and connect the divider after the diode I just use 2.8v per cell to recalculate R1? This doesn’t seem right to me. I think you still need to know the voltage drop across D1 to get the correct value for R1 but wth do I know? Maybe you’re right in that not knowing VD1 won’t give you the exact value of the actual voltage read by pin 7 but will still give you the correct resistance value if you match that offset value. I think I need an Ervin translation. Smile
You seem to have it backwards. With the divider attached like a stock 105c of course you need to know the drop across the diode. That’s why it’s accounted for in our existing firmwares! Once you connect the divider to BAT+ you no longer care about drop across the diode.
The reference voltage produced by your ATtiny13A is completely unaffected by D1 – it will always be 1.0v +/-0.1v. (yeah, that’s a +/-10% tolerance… eww). The voltage coming out of a divider fed directly from BAT + will be whatever the divider ratio dictates.
Rufusbduck
Yes, I realized later that I could use D1 as the jumper for the regulator.
I probably have this all wrong but with the diode dropping .25V and a cell at 2.8V and with R1 and R2 at 19.1k and 4.7k pin 7 will see (2.8-.25)(4700/23800)= .5V
To get low voltage regulation to work I need to be able to show pin 7 – .5V when Vb=5.6V.
If the voltage drop across the diode is some value other than .25v then .5V is the wrong target for the divider.
Do I ignore the diode in the calculation? 2.8 × .1975= .55V.
5.6(4700/R1+4700)=.55
5.6(4700)=.55(R1+4700)=.55R1+.55(4700)
(5.6(4700) – .55(4700))/.55 = R1 = 43155ohms
Using R1 = 43155 and accounting for the same .25v diode drop pin 7 should actually see .5V. Let’s try it.
(5.6-.25)(4700/(43155+4700)=.53V not .5V.
This was assuming the voltage divider was left connected after the diode and the voltage drop across the diode ignored.
Try again with a target of .5V and connecting again after the diode.
(5.35(4700) – .5(4700))/.5=. R1 = 45684 ohms.
And one more before the diode
(5.6(4700) – .5(4700))/.5 = 47940 ohms .
I have the feeling I’ve missed something crucial but at this point I figure I’ll just try some different values for R1 and see what happens but to me it looks like with R2 at 4.7k and
Divider connected after the diode, R1 = ~ 45.7k ohms.
Divider connected before the diode, R1 = 47.9k ohms
Whether you put the divider before or after, I don’t see how the diode can be ignored.
Scott
wight
I had some trouble following your post, but let’s wade into this mess:
This is how the stock divider on a 105c works when the battery hits 2.8v:
4700/(19100+4700)*(2.8 – 0.25) = 0.503v
Exactly as expected. Of course, this leaves you in a situation where changing the diode potentially changes the voltage reading. This is what I was commenting on earlier.
In order for a 2s battery LVP to work correctly without the diode we just need change a resistor. Swap the 19.1k for a 48.1k to get 0.498 out of the divider before the diode like this:
4700/(48100+4700)*5.6 = 0.498v
This will cause LVP to kick in at 5.617v
When I say “before” the diode, I mean that the diode is connected between MCU’s VCC and BAT+. I consider BAT+ to be “before” VCC. I think that’s pretty standard phrasing, anyone can feel free to correct me on that though if they know better. Once you have connected Vin for the divider to BAT+ (“before” any diodes or any other things) the diode is no longer part of the calculation for the divider circuit.
I have no idea what makes you think that a diode that isn’t in-circuit with the divider can make a difference, but it simply isn’t true. If you make a complete circuit with a voltage divider (it has Vin, Vout, GND) and the diode isn’t in there… it DOES NOT NEED to be accounted for in your math.
I’ve lost my skills at solving equations, so I don’t do it. I use a solver such as this one: http://www.raltron.com/cust/tools/voltage_divider.asp
Rufusbduck
It was the first thing we both did to get the .5V we both started with. That’s what I mean by accounting for it. Yes, of course if the divider is tapped into the circuit before the diode then it’s not part of the circuit but to get that .5v we both started from the assumption was a diode drop of .25v and if that is incorrect then the new value of R1 will be incorrect.
My appologies since my intent was to gain a better understanding rather than argue over a misunderstanding. I think we agree but are looking at different ends of the elephant.
Scott
Rufusbduck
Please avoid using phrases of the type “I have no idea what makes you think…” As they are a bit antagonizing and just show that you did not understand me. Just say you don’t understand. Just about everything in your last post was covered above in mine so I don’t think we really disagree. There was a typo between my last calculated value of 47940 and the 47.k. 47.9k and 48.1k aren’t too different.
Scott
Rufusbduck
Here’s another pic of a 105c from back then. I think it was the last one I did and shows the diode turned and used to connect to the input of the voltage regulator. The white wire goes from Vreg out to Vcc and you can see the caps stacked on the regulator pins.
I’ll show a board that’s been cleaned up and has the proper traces cut in a week or two when I get back to this part of the project.
Scott
wight
Sorry, I shouldn’t antagonize. Once I read “Whether you put the divider before or after, I don’t see how the diode can be ignored” I became really frustrated with this situation.
Now, upon looking very carefully back over the thread (more than once), I think I’m starting to see where we went wrong. I think you’ve been assuming that I meant to attach an unmodified divider (19.1k / 4.7k) to BAT+ and then use an unmodified firmware. When you kept saying that the diode can’t be ignored, I suppose you meant that the diode makes a difference – when present it reduces voltage and when absent it does not.
If my new understanding of the situation is correct, I’m still at least a little frustrated! When I jumped into the discussion you were already talking about changing resistor values to suit different diodes. So all that needed to be done when you get the divider Vin from BAT+ is to change the resistor values to suit that.
The bottom line remains that if you hook divider Vin to BAT+ and divider GND to BAT- then the diode is not present in the math for the divider.
EDIT: slightly less antigonizing on this post too. Wink
wight
Nice work squeezing the regulator, 2 caps, and diode all into that tiny space btw. If you hadn’t specifically said that the diode was there I wouldn’t even have seen it.
Rufusbduck
I was sorry to see your frustration growing since all along I had been assuming I was going to connect the divider before the the diode. My typo was in the number I typed at the end. My original question was “what’s the voltage drop of this diode?” which I needed to know to calculate the (.5v) number and for nothing else. I’m fine with solving a simple equation for x or locating which trace to cut where. I kept picturing you banging your head saying “who is this idiot?” while with each post we were operating with different assumptions. You have been very helpful typing long posts affirming things I already knew while I couldn’t seem to make clear my question.
This second is the sole reason for my post. We assume a certain value for the voltage drop across the diode to make the first calculation of the voltage on pin 7 on boards as they are now configured.
In post 5 I listed 4 different new values for R1 to show how a different value for D1 in the first calculation affects the value R1 in the second even though the diode is bypassed. Please note that we agreed then and still agree now that if the diode drop is ~.25v then R1 should be ~48k when bypassing the diode.
Is the .25v assumption a correct one?
Scott
