Test/Review of Xtar 14500 800mAh (Black)
3 posts / 0 new
HKJ
HKJ's picture
Last seen: 7 hours 11 min ago
DSC_5301
Official specifications:
  • Capacity: 800mAh
  • Nominal voltage: 3,7V
  • Charge voltage: 4,2V +-0,05
  • Discharge voltage: 2,5V
  • Positive pole: Button top
  • Protection circuit (BMS): yes
  • Chemical composition: LiNiCoAlO2
  • Diameter: 14,3mm ± 0,2
  • Height: 50,5mm ± 0,5
  • Weight:28g ± 1
  • Charging method: CC-CV
Xtar%2014500%20800mAh%20(Black)-info
AA sized 3.7 volt LiIon battery from Xtar.
DSC_5300
DSC_5302 DSC_5303
DSC_5304
DSC_5305
Xtar%2014500%20800mAh%20(Black)-Capacity
The two batteries tracks fairly well for 14500 batteries, but definitely not perfect. The capacity is 800mAh at low loads but drops at higher loads.
Xtar%2014500%20800mAh%20(Black)-CapacityTimeHours
Xtar%2014500%20800mAh%20(Black)-Energy
Xtar%2014500%20800mAh%20(Black)-PowerLoadTime
Xtar%2014500%20800mAh%20(Black)-TripCurrent
Xtar%2014500%20800mAh%20(Black)-Charge
Conclusion
The battery has an acceptable performance, but it is possible to find better performing battery (That are slightly longer).
Notes and links
Comparison to other LiIon batteries
WarHawk-AVG
WarHawk-AVG's picture
Wow…is that typical voltage drop off from Li Ion? I thought they usually hold up better than that…dang
Excellent review as always HKJ! Noone does it better!!
HKJ
HKJ's picture
WarHawk-AVG wrote:
Wow...is that typical voltage drop off from Li Ion? I thought they usually hold up better than that...dang
Try using the comparator and compare to Keeppower 14500 840mAh, it is incredible what 1.5mm extra length can do to performance.
