Review: Brass ART (1x AAA or 2x AAA: XP-G R5-5C)
Brass ART
Reviewer's Overall Rating: ★★★★★
(Mouse Over for 1x AAA, Mouse Out for 2x AAA [Extension])
Summary:
Battery: 1 x AAA or 2x AAA with extension tube.
Switch: Reverse Tailcap Clicky
Modes: 3: High, Medium, and Low
LED Type: XP-G (5C - Neutral leaning towards warm)
Lens: Glass
Reflector: Medium Orange Peel
Tailstands: Yes
Price: $25.00 (5-28-2014)
Provided by:
CNQualityGoods
Pros:
1 or 2 AAA option.
Superb Machining:
  • Threads well cut, clean, and smooth (Very little 'play' while threading)
  • No nicks/errors in the machined brass
  • No rattling of any kind (switch/batteries/etc)
Firm switch (Accidental turn-on unlikely), yet switch is easily accessed for purposeful turn-on (Big/Small fingers, no problem).
Well spaced modes.
No audible PWM
2 Slots in the tailcap for lanyard/keyring.
Cons:
Gets rather hot if left on high with little to no air circulation indoors.
Function/UI:
Tailcap current (Amps):
Cells High Medium Low
1 2.400 .800 .090
2 1.050 .370 .055
(Eneloop AAA 3rd Gen)
The UI:
Reverse tailcap clicky switch.
A click of the tailcap clicky and the light will be on in High.
A half press of the clicky will switch to medium.
Another half press will switch to low... etc.
A full click in any mode turns it off.
Runtime test:
Simple duration test. I set the light on a platform facing a light meter at about 1meter distance.
Ambient Temp: 80*F
2x Eneloop AAA 1.40v
Mode: High
Initial start up measured 1200lux. A slight thermal sag occurred during the first 5 minutes when it stabilized at 1130lux. Very small variations occurred up until the 35minute mark where there was a sudden drop off to 100lux. The high and medium modes are now only slightly brighter than Low. I stopped the test a few minutes later, cells measured 1.1v
Pictures:
The light arrived in a bubble mailer and inside the mailer was it wrapped with ample extra bubble wrap.
It came with the 2x AAA extension tube, 1x AAA tube, 5 extra O-rings, and a replacement glass.
Side view of the tailcap and down the side. The finish is slightly dull (great for EDC), not super shiny/reflective.
A look at directly at the tailcap. You can see some slight machining marks macro-zoomed in the slots on the left side.
A look at the emitter. OP reflector.
Size Comparison:
1/2 AAA, Eneloop AAA, S3 (1/2 AAA XPG - BLF), NCR18650B, Brass ART, SK68 Clone, OTR C70, Convoy S2+
Mini Breakdown:
Square Tailcap threads, few in number but very well machined. Smooth as butter. :)
Beamshots:
Brass ART
Low - Medium - High
Here you can see the nicely spaced modes and the beam profile. A large hotspot with some corona surrounded by a fair amount of spill. A profile great for short ranges, definitely not meant to be a thrower.
S3 (1/2 AAA XPG - BLF), Maglite Solitaire, Brass ART, Mini C8 (AAA), L2 P60 (18650, XP-G2)
Here you can see the Brass ART's comparatively very smooth beam and neutral tint
Note: The tint is slightly warmer in person, and the transitions between hotspot, corona, and spill are less apparent in person as well.
Conclusion:
This is a great 1x AAA/2x AAA flashlight that outputs a lot of light for its form factor, with a very useful beam profile. It comes stock with a nice set of modes and a superb build quality throughout. It has some nicely machined brass parts for you guys tired of the same old black anodized or plain stainless steel lights.
I rate the Brass ART a 5 out of 5.
Does it work with a 10440? I bet it wouldn’t handle the heat very well…
I was tempted by this one… but it’d probably be a shelf queen. I already have a DQG Tiny AAA IV on my keychain, and the AAA battery requirement would make the runtime and output a bit lacking for non-keychain use. I’d also want to swap the emitter because 5C is too warm for my taste and I’ve gotten a bit spoiled by high-CRI neutral lights lately.
However, this item is indeed very pretty… and I really like bare metal. It might be a really nice host for some later project.
You and your 10440's. :P I'm going to have to get one one of these days!
I'm not sure if the driver could handle a 10440, but if it can I similarly doubt it would handle the heat well. In my experience stainless/brass lights in general, aren't very good candidates for Li-ion usage.
I've updated OP with some Beams. Hoping for some decent weather for more pics/testing.
Hahaha!! I’m always on the lookout for something better than the Led Lenser M3R for my keyring, as it only puts out something like 200 lumens! But I like it’s form factor and zoomable beam.
Updated OP with a runtime test and my rating. Great little EDC.
I was hoping to have my lumen tube up and going, but I’m not getting the consistency or accuracy I was hoping for. Needs more testing and tweaking before I integrate it into my reviews.
Wish I could think of a reason I need one. It looks almost as slim as the Solitaire, and with a tail switch it is shorter than the Solitaire with a spare bulb.
+1
Stylish, little, reasonably inexpensive, and … completely redundant for me. Still, maybe it’d be nice to have around as an unallocated gift. ’cause, you know, I only have four 1xAAA lights left to give away. :slight_smile:
Thank you for the review. Sounds like a great driver in this one. Anyone know if they are awailable without the host??
I have yet to see a pic of this light tailstanding… will it do it or does the button stick out a tiny bit?
Review says it tailstands.
I missed that in the reading… Thanks, must have rushed through to much. Will be picking this one up, with the newer gen. 2 it now has the XP-G2 and l/m/h.
I see it now, read the review not the manufactures blurb…
Doh!
