-Resistor- mod for- olight sr51 driver now running my 2D Magmod
31 posts / 0 new
Cereal_killer
Cereal_killer's picture
Last seen: 1 year 11 months ago
Could anyone help me ID the correct resistors to change/add/bridge to up the current from my SR51's driver. Currently the emitter is getting 3.4A, I'd like to really push it.
Sr51
Edited by: Cereal_killer on 06/26/2014 - 01:56
comfychair
comfychair's picture
Last seen: 5 years 6 months ago
What's that metal bar at the bottom? Anyway, down there is where you need to look, the part not shown, around the main FET (the AO4468).
Cereal_killer
Its just a big ass jumper, there arnt any resistors down there and the only things hiding under the smaller board are two larger SMD ceramic CAP’s and a 8 pin ic (which is identical to the one under the big cap right next to it). I don’t see any main FET’s and none with that marking, only see three baby FET’s on the whole thing.
Some more pic’s:
comfychair
http://75.65.123.78/sr51.jpg
http://75.65.123.78/AO4468.pdf
The big metal bar IS the sense resistor, looks like. It goes from the source drain pins on the FET to GND, right? And LED- connects to the pins on the other side of the FET?
Cereal_killer
Ah ok, the drain pins of the FET go to the bar, the other end of the bar is LED-. Source (3 pins) go direct to batt-. G (one pin) goes to the right most resistor marked “010” in the biggest bank of resistors down on the bottom right (in that pic)
What options does that give me, either move the LED- direct to the FET drain? Jumper the resistor on the gate?
Thanks for helping so far.
comfychair
The metal bar sense resistor is probably already very very low, you can try replacing it with fat wire or a ~.040" thick strip of copper, but I doubt there's much left in there to find. That's the same FET used on the 3-toroid SRK drivers, they won't do more than about 4.1-4.2A with the resistors bridged, and that's when powered by four cells in parallel. The FET's on-resistance is just too high. You might could find another SO-8 FET with a Rds(on) down around 3-4mOhms that would work as a drop-in replacement, otherwise I don't think there's much to be done there.
Cereal_killer
What about a different package FET if I was up for some finanglein’?
Is there a different approach to bumping this driver up, somewhere else to make some improvements?
Here’s where we are now, I measured that bar and it was only reading  photo 9EE30C91-FE4E-46BF-BB82-40FEDFF0ED64.jpg
comfychair
Lower resistance FETs in that same package are common, no need to kludge in something different. It's a really straightforward circuit, the only things in the path between LED- and ground is the FET and the sense resistor, and if the sense resistor is already down at something like 0.0015 ohms, the only thing left is the FET.
What's the battery config on this light? I checked the Olight site and can't figure how you get a light that uses either six CR123s or two 18650s...
Cereal_killer
On 18650’s its 2S, not sure how it runs the 6×123’s.
Got my bench setup swapped out with a proper copper mounted xml2, it’s reading 4.78, I think the 6A+ reading before it died was runaway.
Every solder connection in this light is way over loaded with the solder, I’m going to clean up all the connections and swap the 20AWG wire for 18, if I can get 5A I’ll be happy for now while I look for a lower resistance SOIC FET. So is the 8A rating just a joke or what’s the deal with that?
Edited to add: hmm, the driver no longer has low, still has the hidden strobe tho (double click from on)
comfychair
The current rating in the spec sheet is for running a load that's not dependent on voltage like a LED is. Since more voltage = more current, resistance in the FET lowers the voltage which also lowers the current. A different kind of load like a DC motor or a straight resistive load doesn't work like that.
Losing modes is pretty common when bridging resistors on a lot of drivers. It'll need at least some small amount of resistance there to go back to working again. A better FET will let you use a reasonable sense resistor and still get more output current. The 4468 is something like 23-25mOhms (for comparison, the Vishay 70N02 is 4.5mOhms).
see here: http://www.digikey.com/product-detail/en/IRF8734TRPBF/IRF8734TRPBFCT-ND/...
Cereal_killer
Thanks for all your help again man.
I’m not to concerned about low, its a dedicated thrower now that its dedomed, wtf do I need low for lol.
The final report-
Stock was 3.4A to the emitter for 58kcd
Modded & dedomed it’s running 4.7A for 123kcd (see post 14) and a much more pleasing tint.
comfychair
You're lucky it wasn't one that (mis)behaved like this one: http://budgetlightforum.com/node/23867 xD
ImA4Wheelr
I just received my SR51 yesterday.  Really like the beam pattern, but the UI and modes suck.  Really high low and not much mode spacing between High and Low.  After reading this, I may just going to swap out the whole driver.
Nice to know how to resister mod the stock driver though.  Thanks for this thread.
The 18650 holder is 2S.   The CR123 holder is 3P2S.
EDIT:  Unfortunately, the battery tube can't take 3 18650's and it's too thin walled to bore out.  What a shame, there is plenty of vertical room to rig up a 3S carrier in there.
Cereal_killer
Don’t overlook the stock MCPCB, while it’s really nice looking all copper clad and huge it’s not direct bond, after getting it all back together and measuring lux it didn’t even make it threw the 10sec reading lol. Beam started out nice and neutral and almost instantly there was a major blue shift followed by instant death.
Cereal_killer
Would it be possible to get any gains from leaving the big bar sense resistor but swapping in a better FET so it would retain factory modes?
Now that I’ve got a new U2 1A dedomed on a XM20 it’s doing 134kcd, I’m happy now and gonna leave it alone but I’m still wondering about the question above.
comfychair
Yes, that was what I was suggesting earlier. With the high resistance FET and very low sense resistor, it was already running near wide open in stock form. Swapping that around, a low resistance FET and maybe even a higher sense resistor would net you more output while leaving more safety margin.
DayLighter
DayLighter's picture
Last seen: 4 years 6 months ago
Dang it C_K.. now you make me want to purchase one too Tired
The only way to do a great work is to love what you do.
ImA4Wheelr
Man that driver looks complicated.  I like the idea of swapping out the FET and also replacing the MCU.  Won't be touching the light until after I finish my scratch build though.
If you get a chance, it would be nice to see some beam shots.  I think your the first to install dedomed emitter in this light.
Cereal_killer
So it turns out there is a low still, its just barely dimmer than high lol, its not useful at all and its such a small difference out in the open I couldnt even tell, only when I went into a tunnel was I able to notice.
Beamshots here-
http://budgetlightforum.com/node/31971#comment-595199
comfychair
There's what looks like another FET opposite the AO4468, can you get the number off that one, or a pic with the big cap more out of the way?
http://75.65.123.78/sr51-2.jpg
wight
Last seen: 1 year 8 months ago
Maybe 3*17650?
Still fine, still on a break. One day I’ll catch up with you folks! previous wight catchup Wink
list of my drivers & variants (A17DD, FET+1 stuff, WIP stuff, etc)
Cereal_killer
I just tried and 3 17650’s do fit but 17650’s suck. It wouldn’t be worth it to do 3p 17650’s over 2p 18650’s. The only possible reason I can imagine to use 3× 17650 is if it was 3s.
3p 1600mAh 17650’s is >30% less WH than 2p 3400mAh 18650’s, even using high drain 2500mAh 18650’s 3× 17650 is still ~25% less than that.
wight
No argument from this corner. 3s is the only reason you’d do that.
wight
I knew I'd seen some higher capacity skinny cells recently.  It turns out they weren't 17650.  They were 16650.  HKJ has reviews of 3 different ones on his site, here are Keeppower's protected Sanyo cells.  They still only make sense when in series, but I thought I'd throw that out there while we were on the topic.
Cereal_killer
I’d not seen those yet, thanks for posting them, now I have to get some for my quark.
Cereal_killer
Dissapointing news, the driver has been out of the light (replaced with a 17DD) for awhile now but I’m looking at using it for my 2D to 6AA maglight mod since the input voltage off 6sAA will be right so I finally got around to swapping out that FET (and swapping back to the stock sense resistor) and it runs at the exact same 3.4A to the emitter.
ImA4Wheelr
Bummer.  For shits and giggles, you should take those DMM leads with the alligator clips out of the equation.  Just jam the emitter and driver leads directly into the DMM.  You could use wood skewers or dowels to wedge the wires in tight.  May not make a difference in this case, but it's the best way to roll.   Well, maybe the best, but the easiest best I know of.
comfychair
Add a 10 ohm pot in parallel with the existing flat-bar sense resistor, see how far it'll go now before losing the modes?
Cereal_killer
ImA4Wheelr wrote:
Bummer.  For shits and giggles, you should take those DMM leads with the alligator clips out of the equation.  Just jam the emitter and driver leads directly into the DMM.  You could use wood skewers or dowels to wedge the wires in tight.  May not make a difference in this case, but it’s the best way to roll.   Well, maybe the best, but the easiest best I know of.
I originally tested with my external shunt resistor DMM but switched to this setup for further [easier] testing. This DMM’s leads are 14AWG wires soldered to the banana connectors inside the body of the DMM and the emitter / battery wires are 20AWG.
I ended up putting the driver at stock drive currents (and with stock modes) into my first 2D maglight build, that took a ton of work to make it fit, it’s not coming back out lol.
I choose it cause it’ll run on either my 6sAA battery carrier or 2 io-ions end to end.
Cereal_killer
Well here’s where the driver is now, best part is in a few weeks I’m doing another SR51 so I’ll have another one of these drivers to use in something, maybe a cool white 2D mag.
anyway it took some work to get it to fit, I had to grind down the main PCB so much I actually had to run a wire to replace the outer trace, I also had to remove two large sections of the H22A heatsink. That blob on the heatsink is a piece of large copper wire I swaged in a hold I drilled for a good path to ground.
The mechanical clicky was replaced with an e-switch for the olight driver, its a sparkfun tact switch on a BLF 12.2mm oshpark board. The emitter is an L2 S6 7D3 on a 14mm copper board that I converted to direct bond, the MCPCB is the same size as the pedistal and fits right up in the head so the beam is adjustable just like stock.
ImA4Wheelr
Cool Mag mod. Smile
