Great price on a very useful flashlight from Lowes
14 posts / 0 new
Mike11148
Last seen: 1 year 9 months ago
http://www.lowes.com/pd_498288-34170-63453_0__?Ntt=498288&UserSearch=498...AID=10926682&PID=1225267&SID=479151a7270d45e0bf25be8368cbcf03&cm_mmc=AFF_CJ-_-1225267-_-1122587-_-10926682
Hard to pass up this flashlight with the rechargeable lithium battery and charger built in.It also comes with an additional battery carrier that takes standard double a batteries.I picked up 1 last year when they were 29.98 and use it very often. For 6.98 its a steal.I picked up several more today for gifts.
musicmagic
Last seen: 6 years 7 months ago
do you know what battery it uses?
If you can’t blind them with your brilliance, baffle them with your bullcrap.
The real currency in the world is not money, it’s trust.
WarHawk-AVG
WarHawk-AVG's picture
Last seen: 1 year 4 months ago
Whoah…that’s pretty neat
blueb8llz
Last seen: 2 hours 19 min ago
it says 17.99 for me
unknown00101
My guess would be regional sale price like Homedepot does. I was seeing the $6.98 price with a ton of stock at both the Lowes near me, but now the page seems to be broken.
Crux
Crux's picture
Last seen: 3 weeks 1 day ago
I just brought one home and gave it a quick once over.
Appears to be an XPE emitter, rotating focus optics, ring of small leds all the way around the white band on the head (six pairs), 2Ah (claimed) LiIon cell with built in charger (slide out US prongs), additional battery pack holds 3 AA cells (double A's not included), swivel head, flexible goose-neck between battery and head can be removed and head connects direct to battery with two included adapters.
Kind of neat focus mechanism is rather stiff to turn, but won't change focus by itself! Changing focus doesn't change outside length, the emitter moves up and down internally. This design isn't good for heat dissipation, but it's only driven with 1 Watt so it'll do.
Four modes: High about 350mA, medium 50% duty cycle of high, ring of leds around the head only - about 220mA, and these same leds in beacon or slow flash. I measured 0.2uA (0.0002mA) off state current! That is probably the most impressive feature!
Magnets on battery case, and yes, they could be stronger as was mentioned. Also a rather weak magnet in the swivel joint of the head which may be designed to hold small magnetic parts during a repair... I'm not sure I would trust it to hold anything securely.
Final verdict: Very little mod potential, though I may try to center the emitter better, but I'll keep it.
Regards,
Crux
ImA4Wheelr
Last seen: 1 month 6 days ago
Nice find. I bought a couple. One for me and one for my father.
EDIT: Fixed typos.
Hagg911
Last seen: 5 years 3 months ago
The batteries are samsung, ICR18650-22F M Samsung SDIEM 5D4A
Sorry no pics. Not to hard to disassemble. 7 small screws and it slides out.
downlinx
downlinx's picture
says $6.98 for me, i might have to pick one up.
BLF Community Battery Pull Thread http://budgetlightforum.com/node/32720
ImA4Wheelr
I already started using mine in my shed.  Handy utility light.  Was trying to cut something and needed more light from an odd angle.   I can tell I will be using this light a lot.
They should sell it with 2 heads since it has 2 battery packs.
kuoh
Last seen: 6 hours 55 min ago
The goose neck offers good placement flexibility and the lion battery means it will still have a useable charge when I need it, even if it’s a year later. It’s not the brightest light, but at $6 it’s definitely worth it to have in the garage or even the car. I’m tempted to go get a second one.
KuoH
Muto
Last seen: 22 hours 5 min ago
Just wanted to update this thread, Got 3 of these and may return for more for gifts.
I pulled off the goose neck and use it in the shorty mode in the garage.
Buy of the year at $6.98
Never tried the 3 AA battery pack and as long as the rechargeable pack works it will not get used.
Look on the Lowes site and search other locations if your local store is out.
HTH some folks
The difference between Hoarding and Collecting is the illusion of Organization
“History doesn’t repeat itself, but it sometimes rhymes,” Mark Twain
After the Apocalypse there will be only 2 things left alive, Cockroaches and Keith Richards
DB Custom
DB Custom's picture
Last seen: 20 hours 24 min ago
That link shows up at my local store for the same $6.98. My kid would love one of these! Am going that way later this morning, will see if they have one….Thanks for sharing! Smile
Hill
Hill's picture
Hagg911 wrote:
The batteries are samsung, ICR18650-22F M Samsung SDIEM 5D4A Sorry no pics. Not to hard to disassemble. 7 small screws and it slides out.
How many cells are in there?
FT has those for $7.55/pair.  If there are at least 2, then it's a great deal just for the batteries alone.
My lights here and here
