Home Depot Deal Alerts & Discussion Thread
2614 posts / 0 new
kennybobby
kennybobby's picture
Last seen: 1 hour 52 min ago
The driver board is 1.25” diameter, there is a Q1 N-FET NCE2060K, and U1 is an 8-pin ic that has been sandblasted to remove the part number, and U2 is a 5-pin with tab ic, D7136. i don’t like that big solder ball, it indicates lack of wetting of the solder to the wire and the device and is likely to fail as a cold-solder joint.
The battery carrier has 3 spring-loaded pins on each end and can be inserted either direction, it is polarity insensitive.
Now i used to think that i was cool,
drivin' around on fossil fuel,
until i saw what i was doin',
was drivin' down the road to ruin. --JT
dchomak
Last seen: 2 years 9 months ago
I went to a local store to see if they had any of the hand held spot lights. I had already searched with the site provided by Sigster and only 1 local store came up
Here is why, they have pennied out!
What this means is that if your local store does NOT come up, then it could be it has pennied out there also.
Find one and it could be a penny.
Here is the one store in my area that had stock.
Also, here are a couple of other deals I came across.
It is very unusual to see anything at 90% off
These Dewalts are 30% off
These Fisker loppers are $19.97
But right around the corner was this display with the same long handle lopper with FREE pruner for only $4.92!
See, they are the same.
I bought 8, friends took 7.
Maybe I should have bought them all? (there were 32)
kennybobby
The Defiant led puck lights have 3 modes: hi, lo, and flashing strobe.
Like before the 8-pin microcontroller has the part number etched off—seems that’s their practice. There is a 20V, 2.3A P-mosfet A1SHB, and an S4 Schottky blocking diode. Makes 110 lemons and runs 8 hours on 3 AA cells, throw is 6 meters. Here is led array under the diffuser and the circuit board.
Muto
Last seen: 3 hours 18 min ago
Hit up Home Depot today and No discounts on any of the Christmas special bins.
Anyone know what date they will start based on past years?
The difference between Hoarding and Collecting is the illusion of Organization
“History doesn’t repeat itself, but it sometimes rhymes,” Mark Twain
After the Apocalypse there will be only 2 things left alive, Cockroaches and Keith Richards
vwpieces
vwpieces's picture
Last seen: 2 months 12 hours ago
Been waiting for a post to this thread since Xmas, looking to see what deals are found.
15*F out and don’t wanna go out unless I get a deal.
No spot lights within 50 miles of me. Sad
ImA4Wheelr
Last seen: 1 month 1 week ago
I hit the Harbison Blvd (in Columbia, SC) HD last night.  No Christmas gift items were discounted significantly yet.  I imagine they would probably have folks try to return at full price and buy back at discounted price in mass if they discount so close to Christmas.
EDIT: Gift items like drills and flashlights.  Not Christmas decorations.
kennybobby
That whole pallet of spotlights near me is already gone, but i found another store with a pallet of 180 that they don’t know they have…good deals don’t last.
ChadB
XMAS stuff around here is 50-75% off
if you live near an ACE hardware theirs is 75% off
I bought 3 spools of LED lights 300 count multi colored for $4 a spool this AM
going back in the AM to see what else I can find. I bought some of those projector spotlights from ACE for $4 as well and some giant LED snowflakes for $2
dchomak
Yeah, after I saw your post I dashed over to HD after supper. Got some Christmas lights for 75% off.
I also grabbed one of the 3C spot lights. Earlier in the week my store had 18 of them. 14 were in plain site with the gifting displays but were not priced. The other 4 were on the bottom of the flashlight shelves in hardware. Last night the whole display of 14 were gone, but those other 4 were still there. So I figured is was now or never……………
dchomak
A friend of mine halfway across the country sent me this picture today. He was out scouting all the Christmas light stuff that is 75% off and came across this.
A Lithium powered Snow Blower!
It comes with 2 – 56V, 5Ah batteries. I have seen the insides of those EGo batteries and each one would contain 28 2.5Ah cells
This is a single stage blower, the kind with the paddles. I use a 26” Toro 2 stage thrower and a Toro CCR 4 cycle blower for the walkway and trim. I just wonder how that EGo would perform if I were to use it to replace that CCR.
Pete7874
Pete7874's picture
Last seen: 6 hours 35 min ago
Interesting snow blower. I see people reporting about 30 min runtime on 2 5Ah batteries. Enough to clear a small driveway. Probably a good idea to have two more batteries on standby.
dchomak
So you are saying 15 minutes per 5.0Ah battery. (I first read that at 30 minutes per 2.5Ah battery) Facepalm
Pete7874
Pete7874's picture
That’s just what one of the reviewers said:
Quote:
Unit runs 30 minutes with two 5AH batteries
dchomak
Yeah, snowblowers and cars shouldn’t be run on batteries Big Smile
ChadB
Seems like for $220 a battery Id be using an extension cord or a can of gas. But luckily I’m in Florida and just need a leaf blower for the beach sand.
dchomak
Right now, Home Depot (and Lowes) are selling these motion lights for $2.50 each. Home Depot had them originally for $9.98 and Lowes got $19.98
In each there are 3 LED’s of different colors depending on the model with a slowly spinning lens. There is an additional lens built into the dome. I took one apart so that we could all see what’s inside.
I almost forgot, the include a stake so that they can be used outside. Trouble is, in my opinion they are not bright enough for that. More useful inside, so a made some bases out of wood.
This particular model was called multicolor and 3 LED’s, Red, Green and Blue. Only way to get a shot of the 3 LED’s was to place a diffuser over them.
At this price, they won’t last long, it could be fun to pick up a couple to play around with.
Heck, parts alone are worth it!
garrybunk
garrybunk's picture
Last seen: 17 hours 29 min ago
I will confirm these aren’t worth crap outdoors. I wouldn’t even take them if the store paid me to take them. I was absolutely disgusted with wasting good money on these last year.
-Garry
My Bike Lights Thread, Optics (TIR) Comparison Beamshots, Diffusion Techniques
, MTBR’s Lights & Night Riding Forum
NOTE: Now hosting my photos from my Google account. Post up if you can’t see them. Older photos hosted on Photobucket or Flickr may disappear (PM me if you want access to them).
dchomak
-Garry
paid $19.98 each did ya? Silly
I remember you complaining about them last year, I think you got them on clearance then too.
I think these are GREAT indoors It does help alot it they are shown on a white surface like a ceiling or off white colored wall.
garrybunk
garrybunk's picture
Ours came from Big Lots at $15ea I believe. Of course the receipt was thrown away before we saw how bad they were. I did try them inside after seeing them outside and you’re right, they were acceptable at a short distance to a white wall. I’m just not sure why anyone would want them indoors. I left a scathing review on Amazon too.
BTW – Home Depot (Lowe’s too, though HD’s are better) has plastic shelving units on seasonal sale (Lowe’s stocks them year round) – 36”×18“x +/-55” tall for $19.97 (Lowe’s regular price is about $35. This is the best after Christmas deal I’ve seen. I love these shelf units, esp. for my basement (won’t grow mold, can’t be damaged by water, etc.).
-Garry
kennybobby
Those lights are at $4.98 down here—they have a bunch of them too, i’m hoping they will drop to 50% off that price to match your price up there in CT.
dchomak
Are you sure your not seeing the price for the 2 packs. For some reason a 2 pack of multi color was $4.98 while the 2 pack of white ones were $4.97
dchomak
Here are a couple 4 second videos that I took with my cell phone, First one is of 2 bulbs, 1 white and 1 red pointed at about a 45 degree angle towards the ceiling. The second video is of 2 multicolor bulbs, the one at the far end of the room is pointing straight up and the other is at about 45 degrees.
Blackbeard
Blackbeard's picture
Last seen: 38 min 19 sec ago
I think this year they sent all the xmas stuff back to distribution centers, was at one yesterday and evrything was gone, seems they arent playing the discount post holiday game this year.
fishymamba
Bought the husky spotlight today when I went to pick up some other stuff. Only $5 so I had to get it, now to see how I can mod it.
Opened it up and it has a led on a 20mm star, that makes things easy. Is that an XP-L in there ?!?
S8 Triple - 219c, MTN-17DDm
M1 - XP-L 7a, 105c
C8 - XP-L HI, A17DD-L
garrybunk
garrybunk's picture
My guess is it’s an XM-L2. More profit margin for them to choose the XM-L2. I swore someone posted a close-up earlier, but I don’t see any.
-Garry
fishymamba
Its definitely a XP sized led. Bad tint, but at $5 can’t really complain. Not too experienced with the xp-g series, but this looks more like the XP-L to me. Knockoff maybe?
M1 - XP-L 7a, 105c
kennybobby
Maybe they will drop the price on the motion projection lights, but i went ahead and got a couple for testing anyway. If they drop price and i catch it, i’ll just pull the 90-day return trick. They only have the single units down here, no 2-paks in several stores that i checked. The HD online doesn’t even show the number of units at any store, so they will be clearing the shelves soon i’m sure.
One thing i have noticed is that the body of these lamps heats up quite a bit—much more than i was expecting. Likely from the internal motor rather than the LEDs, but it was somewhat startling to grab it, and then wanted to quickly drop it. They are like tiny disco balls, and they would be fun at dope smokin’ parties…
dchomak
kennybobby wrote:
Maybe they will drop the price on the motion projection lights, but i went ahead and got a couple for testing anyway. If they drop price and i catch it, i’ll just pull the 90-day return trick. They only have the single units down here, no 2-paks in several stores that i checked. The HD online doesn’t even show the number of units at any store, so they will be clearing the shelves soon i’m sure. One thing i have noticed is that the body of these lamps heats up quite a bit—much more than i was expecting. Likely from the internal motor rather than the LEDs, but it was somewhat startling to grab it, and then wanted to quickly drop it. They are like tiny disco balls, and they would be fun at dope smokin’ parties…
Sorry for the confusion. I messed up on the price.
I did get mine at $2.50 each at Home Depot but only because I found the 2 packs at $4.97. You are correct, the single packs are $4.98 in all the stores. What made it confusing to my feeble little mind is that I DID get them for $2.50 at LOWES. Over there they had a 75% off sale on the Christmas stuff that was already marked down 50%. In other words, 87.5% off. The lights that were originally 19.98 at both HD and Lowes, were $2.50 at Lowes.
To make things even more confusing for me is that I had bought these same type lights at a Halloween closeout a couple of months ago and already had some single packs from that. Those lights had Halloween colors like orange and purple. That picture I posted of single packs were a combination of Halloween lights and LOWES lights. The arrows point to LOWES SKU numbers. The others are HD
I was out yesterday and there are still stock available at HD. 2 packs are $4.97 and single packs are $4.98 Sick
dchomak
In Connecticut, it was -7F yesterday. What a perfect time to check garden for clearance deals Wink
As I pushed open the door to the garden area outside, I could feel the chill even before the doors swung open! I thought who but a NUT would be out here under these conditions. Smile
But I was rewarded, hows $5 per 42lb, 14,000 foott bag of SCOTTS fertilizer? I found stock at both the stores I went to. I also found a few Evergreen fertilizer spikes, also marked down more that 90%
kennybobby
Thanks for clearing up the pricing and the SKUs— i had noticed the different numbering but didn’t realize it was HD vs Lowes.
