Test/Review of YLE ICR17500 1100mAh (Orange)
1 post / 0 new
HKJ
HKJ's picture
Last seen: 1 day 18 hours ago
DSC_5712
Official specifications:
  • Typical capacity: 1100mAh
  • Minimum capacity: 1050mAh
  • Nominal voltage: 3.7V
  • Internal impedance: Energy: 4.07Wh
  • Charge method: Constant current with limited voltage
  • Standard charge: 4.20V, 220mA, 33mA cut-off
  • Quick charge: 4.20V, 770mA, 11mA cut-off
  • Charging voltage: Max 4.25V
  • Standard discharge: 220mA (0.2C) 3.0V cut-off
  • Continuous discharge: 1100mA (1C)
  • Max. pulse discharge: 3300mA (3C) Battery weight: 34g or less.
  • Battery dimension: Height: 48.9 +/-0,2mm Diameter 16.6 +0.3mm/-0.1mm
YLE%20ICR17500%201100mAh%20(Orange)-info
This is a 17500 cell, i.e. it is both thinner and shorter than a 18650 cell
DSC_5711
DSC_5713 DSC_5714
DSC_5715
DSC_5716
YLE%20ICR17500%201100mAh%20(Orange)-Capacity
I did test this battery with a much higher current than it is rated for. Below or at rated current it does very good, it does also work very fine at 2A and 3A current (But expect shorter lifetime).
YLE%20ICR17500%201100mAh%20(Orange)-CapacityTimeHours
YLE%20ICR17500%201100mAh%20(Orange)-Energy
YLE%20ICR17500%201100mAh%20(Orange)-PowerLoadTime
YLE%20ICR17500%201100mAh%20(Orange)-TripCurrent
YLE%20ICR17500%201100mAh%20(Orange)-Charge
Conclusion
The battery does easily handle the speficed current and more, i.e. performance is good.
A usual this type of battery gets an acceptable rating.
Notes and links
The batteries was supplied by ENERDan for review.
