Below is the drop in and link to it, But id like to know which of my P60 style lights would you put this module in? I dont have the UF 504B or the KD C8 here yet, But they will arrive when the drop-in does.
I feel pretty confident the M20s is thermally much better designed to take the heat this light will put out. But i also dont want to take a perfectly good and bright module out for a small gain in lumen's. By the specs it looks like the UF 504B would benefit the most with an upgrade. With the great reviews ive read on the drop-in i may have to order a second one as i feel the 504B and M20s both would benefit from this item.
Also does anyone prefer a OP reflector with this one or should i just stay with the smooth one for better throw?
One last question, Do these Solarforce copies at DX have as good of quality as a real Solarforce? I have an L2r which is top notch quality even compared to the $100 M20s. Soon im gonna pick up a 8.4v XM-L so i can run 2x 14500's in it. You cant beat the price of these UF clones for $15 with a drop-in installed, Even tho it may not be the brightest.
Ultrafire Cree T6 3-Mode Memory LED Drop-in Module (4.2V max)
UltraFire 504B HA-III Cree R2-WC 5-Mode 220-Lumen LED Flashlight (1*18650)
KD C8 CREE XML T6 1000 Lumen 5-Mode LED Flashlight (1*18650)
http://www.kaidomain.com/ProductDetails.aspx?ProductId=11097
Olight M20S R5 Warrior (270 lumen's)
http://www.olightworld.com/product_list.asp?bid=77&sid=89
