TheStar - BLF driver firmware for a GB light - What options do you want to be selectable by stars?
96 posts / 0 new
_the_
_the_'s picture
Last seen: 3 weeks 6 days ago
Disable Mode memory
20% (12 votes)
Change Mode order (L->H vs. H->L)
34% (21 votes)
Disable Moonlight (Lowlow) mode
2% (1 vote)
Disable Hidden blinky modes (note: these are well hidden by default!)
11% (7 votes)
Disable Turbo timeout
26% (16 votes)
Other (please tell more in comments)
7% (4 votes)
Total votes: 61
=the=
_the_
_the_'s picture
I got so fed up with the driver problems of a previous group buy that I decided to write a better one.. Wink
The driver features implemented so far are:
- High PWM (~19kHz, totally unnoticeable & silent)
- Four modes: LowLow-Low-Med-Turbo (0.2%, 2%, 25%, 100% = 2.8A)
- Turbo timer (ramp down to about 1.4A after 2min to prevent over heating)
- Memory kicks in after 1s on
- Low voltage protection (step down in multiple steps + finally shut down the light)
- Ability to choose mode order: Low to High by default, or High to Low with star soldered
- Ability to disable LowLow mode by soldering another star
- Ability to disable mode memory by soldering yet another star (starts then always on 1st mode: LowLow, Low, or Turbo, depending on the other settings)
- Three hidden strobe modes (loop through all modes twice without over 1s pause to access: Strobe -> 1s beacon -> 10s beacon)
But the question is: Are the stars used for the features that require most changes? Or would it be more important to disable turbo timer for bicycle use? Or maybe to permanently disable the hidden blinky modes? If yes, which option should be removed?
Or are there other changes which would be required before we announce the GB?
Please vote for the most important one and tell other two in your comment. Thanks!
=the=
Old-Lumens
Old-Lumens's picture
Last seen: 5 years 5 months ago
Well, that's "Other".Laughing
My PayPal address: oldlumens (insert the @ sign here) gmail.com
My YouTube Flashlight Video Channel
The BLF Modding Links Thread
http://imageshack.com/a/img922/1374/jQ2wdL.jpg
nofearek9
nofearek9's picture
Depends the light is it a small edc or a big like c8 or more
_the_
_the_'s picture
Probably a well built 26650 zoomie.
=the=
Pok
Pok's picture
Last seen: 2 years 9 months ago
26650 zoomie like these Wink
edit :
If using in 26650 zoomie.
Turbo time out
Hi , depand on using mass aluminium can handle heat until battery down.
Low
Hidden blinky modes
_the_
_the_'s picture
Pok wrote:
26650 zoomie like these Wink !http://i1157.photobucket.com/albums/p585/PokkyPB/Flashlights/TG2/07-In-H...
Why not, if you want to build "some dozen", and sell them low enough.. Wink
But I was thinking of this one:
=the=
WarHawk-AVG
WarHawk-AVG's picture
Last seen: 1 year 11 months ago
STAR firmware by JohnnyC does this as well
http://budgetlightforum.com/node/29150
Alot of us have used the source code from JohnnyC and thru “tweaking” certain parts of the code reversed pretty much all the options, different builds that have H>L reverse with star or L>H reverse with star, every option that you can imagine
I built a custom Ultrafire 602C w/ the 4*7135 driving a XP-G, 1 min turbo timeout, H>L, w/ moonlight modes, and no memory it works quite nicely and since there are no “stars” to solder I had to build the firmware to behave default w/ no stars how I wanted it to behave w/o soldering stars by using JohnnyC’s firmware.
_the_
_the_'s picture
WarHawk-AVG wrote:
STAR firmware by JohnnyC does this as well... http://budgetlightforum.com/node/29150[/quote]
Right. I should have mentioned that my version of the firmware is originally based on JonnyC's STAR.. Just refactored it here and there, heavily optimizing for size, adding hidden blinky modes, voltage monitoring which works also in blinky modes etc.
..but the idea of GB is that also those members who can't program their own drivers would get a most optimal firmware in their GB lights => that allows changing three options by soldering (or marking with pencil, or conductive paint, or..).
This poll is about which three options are the most wanted ones. Smile
=the=
hank
hank's picture
Last seen: 1 week 6 days ago
Assuming mode memory applies to the strobe setting, once it’s accessed — it’s fine as is.
(I carry a light as a pedestrian, turn it on in crosswalks — always to strobe before stepping off the curb, because I’ve had cars come up so fast I didn’t have time to puzzle through multiple clicks on other lights. I always carry one I can leave set on blinkenlight).
djozz
djozz's picture
Last seen: 52 min 35 sec ago
If used with the suggested 26650 zoomie, I do not think I would like a timer step-down, it can handle the 2.8A continuously.
The rest of the UI: I love it!
Solar
I would like to see the option for number of modes. For example no star one mode, full on. Star 1= 2 modes etc.
WarHawk-AVG
the wrote:
WarHawk-AVG wrote:
STAR firmware by JohnnyC does this as well… http://budgetlightforum.com/node/29150
Right. I should have mentioned that my version of the firmware is originally based on JonnyC’s STAR.. Just refactored it here and there, heavily optimizing for size, adding hidden blinky modes, voltage monitoring which works also in blinky modes etc.
..but the idea of GB is that also those members who can’t program their own drivers would get a most optimal firmware in their GB lights => that allows changing three options by soldering (or marking with pencil, or conductive paint, or..).
Ah shoot…I guess having the hidden clickies…would like to see a double tap and hold for flashies, release back to mode before you double tapped to get strobe
Other than that…good on ya…most awesome!
Werner
Werner's picture
Last seen: 2 years 7 months ago
Do you plan that the seller flashes the driver or do you want to order them to your home flash and then send them to the users?
nofearek9
nofearek9's picture
H/M/L
no memory
no turbo timer
no need for firefly
M4D M4X
M4D M4X's picture
Last seen: 9 months 3 days ago
i use conductive paint to connect the stars…
easy to remove (when on Batteryside) with some thinner and a Q-tip Wink
so playing around with the funktions is easy…
PLEASE NOTE
i do not work in "reviews, deals and codes" for the time being
maybe M4D M4X will return one day, but until then:
THANK YOU FOR YEARS OF YOUR SUPPORT AND FRIENDLY CONTACTS!
DanielM
DanielM's picture
Last seen: 1 year 1 month ago
L/M/H
no memory
no turbo timer
firefly please
Old-Lumens wrote:
I love modding, but I don't have much use at all for flashlights in general.
M4D M4X
M4D M4X's picture
cpfdaniel wrote:
L/M/H no memory no turbo timer firefly please
this is exact what i like!
PLEASE NOTE
Tom E
Tom E's picture
Last seen: 16 hours 26 min ago
the - where'd you get that zoomie? Look'n for better quality zoomies, but still budget. You got a link? More specs?
_the_
_the_'s picture
hank wrote:
Assuming mode memory applies to the strobe setting, once it's accessed -- it's fine as is.
Yes, also the blinky modes are memorized. You are fine as long as you use it more than 1s at a time.
Seller (or manufacturer) flashes the drivers.
See your PM. Smile
Half time results:
Judging by the answers so far, it seems like the three settings which can be modified with stars would be:
1. Mode order
2. Mode memory
3. Turbo timer
..which would leave the lowlow mode enabled and hidden modes available. At least I would be ok with those settings. Any objections?
I have to add that turbo timer is a requirement by the manufacturer. They say that 6x7135 is the maximum they are willing to do, or warranty will be void. 8x7135 + turbo timer should be ok for them. That would leave the buyer the option to disable the turbo timer and thus void the warranty. Wink
=the=
Fritz t. Cat
Fritz t. Cat's picture
Last seen: 3 years 5 months ago
Disable turbo timeout: 2.8 amps is not that much for a large light with good heat management, say direct thick copper star, well fitted to a solid pill screwed into a finned hard anodized head. Also, as mentioned at the top, air flow such as on a bicycle improves cooling.
Change mode order.
Disable mode memory.
For example, if you use it in a place that is very dark you would want it to start very low, not to lose night vision, or if you use it indoors a lot to supplement room lighting you would want it always to start on turbo.
Flashlight designers should look at lighthouses and pottery.
这些谁设计的手电筒应该看灯塔,以及在陶器。
troisanh
Last seen: 1 year 3 months ago
Like the looks of the zoomie the. Could you pm the link too, thanks.
Linh
_the_
_the_'s picture
troisanh wrote:
Like the looks of the zoomie _the_. Could you pm the link too, thanks. Linh
Please be patient. We are still negotiating with the reseller and the manufacturer. Group buy will be announced as soon as we get into agreement.. Smile
=the=
M4D M4X
M4D M4X's picture
I am interested!
and not very patient… Big Smile
PLEASE NOTE
Gj
Gj's picture
How will they prove you've disabled the timer, voiding the warranty? Couldn't they just deny most claims saying you must have disabled it?
totilde
totilde's picture
Last seen: 1 month 1 week ago
If you get a good price I am in for this
Mooooooo
zelee
zelee's picture
same here Smile
Fritz t. Cat
I might be in, depending mostly on price.
Customscene
Last seen: 7 years 8 months ago
I like having a strobe, but not part of the selections. I’d make it where it comes on whenever you hold the button down for more than 5sec or something regardless of what mode you’re in. Then just turn off and back on to reset.
scottyhazzard
scottyhazzard's picture
Last seen: 2 years 11 months ago
Disable mode memory, change mode order either ascending or descending. If capable of getting a host that can have a momentary button I would like that so that I can use the double tap for strobe.
"Those who hammer their guns into plows will plow for those who do not."
Serifus
Honestly i would love to see dip switches used instead of soldering stars although im not sure there a sets of 3 available or how that would work, but i can dream.
