Test/Review of YLE ICR18500 1700mAh (Orange)
3 posts / 0 new
HKJ
HKJ's picture
Last seen: 6 hours 11 min ago
DSC_5700
Official specifications:
  • Typical capacity: 1700mAh
  • Minimum capacity: 1600mAh
  • Nominal Voltage: 3.7 volt
  • Internal impedance: <80mOhm
  • Energy: 6.29Wh
  • Charging method: Constant current with limited voltage
  • Standard charge: 4.20V, 1190mA, 17mA cut-off, 25°C
  • Charging voltage: Max. 4.25V
  • Standard discharging: 340mA (0.2C), 3.0V cut-off, 25°C
  • Continuous discharging: 1700mA, 45°C or under
  • Max. pulse discharge: <5sec, 4100mA (3C)
  • Discharge cutoff: 3.0V
  • Operating temperature standard charging: within 0 to 60°C, 45 to 85%RH
  • Operating temperature quick charging: within 10 to 45°C, 45 to 85%RH
  • Operating temperature standard discharge: within -20 to 60°C, 45 to 85%RH
YLE%20ICR18500%201700mAh%20(Orange)-info
A 18500 battery, the 1 mm more thickness compared to a 17500, do increase the capacity significantly.
DSC_5699
DSC_5701 DSC_5702
DSC_5703
DSC_5704
YLE%20ICR18500%201700mAh%20(Orange)-Capacity
The curves looks very good, as long as I do not overload the battery.
YLE%20ICR18500%201700mAh%20(Orange)-CapacityTimeHours
YLE%20ICR18500%201700mAh%20(Orange)-Energy
YLE%20ICR18500%201700mAh%20(Orange)-PowerLoadTime
YLE%20ICR18500%201700mAh%20(Orange)-TripCurrent
YLE%20ICR18500%201700mAh%20(Orange)-Charge
Conclusion
The battery looks very good when stating inside the rating, but it can deliver considerable more current.
A usual this type of battery gets an acceptable rating.
Notes and links
Edited by: HKJ on 06/30/2014 - 13:30
lagman
lagman's picture
Last seen: 2 weeks 3 days ago
You can get twice the capacity with a cell the same diameter and only 15mm longer. Shocked
My English isn’t perfect but I’m trying to improve it. If you see something that doesn’t sound right or is just plain wrong, please feel free to point it out! Smile
HKJ
HKJ's picture
lagman wrote:
You can get twice the capacity with a cell the same diameter and only 15mm longer. :O
Yes, 18650 are the premium cells, both larger and smaller cells has less capacity for the volume.
