Pink new 2600 Samsung 18650s for $2 each, free postage!
78 posts / 0 new
Ubehebe
Last seen: 6 years 11 months ago
I have SERIOUS battery hoarding issues (300 li-ions and counting), so when I saw these I couldn’t resist. Ordered three packs from this guy and all are as expected — Pink 2600 Samsung 18650s. No date on any of the packs I got, but all were charged to 2.5-2.9. As we have tried before to decipher the date codes on the cells themselves, I won’t be doing that foolishness again. All efforts ended in muddled confusion, so date of manufacture is unknown on these pinks. All batteries charged right up in the expected time and work as expected.
As the “outside” pack labels say 5200 and say that the batteries are made in Korea, pink 2600 Samsungs are about all the batteries therein could be, except for maybe LGs, which would be even better.
These pink Samsungs are some of my favorite 18650s, so my little hoarding mitts were almost aflutter when I saw these listed. For me, the fashionably colored pinks hold a charge next to forever. 4.2v two months later is 4.18 or even 4.19, unlike some Panasonics that drop to 4.15-4.17 in a few days or weeks. But more importantly, for me, they put out max power at startup for the longest of just about any battery before sagging out. YMMV, but I have tested many of my pack pulls (new and used) in high-power lights with a meter 15 feet away, and the pinks really seem to be among the best for initial holding power. And they’re no slouch in general-use output. PLUS, of course, Samsung has done extensive torture testing on intentionally shorting and overheating their batteries, supposedly without flame-outs and explosions, unlike some other manufacturers. Of course, these short-circuit immolation tests were done in open air, not with the shorted batteries in a sealed aluminum tube, but still Samsung cell safety seems to be some of the best.
Packs are about average to open. Not the easiest, not the hardest. Minimum of white goo on the cells rubs off easily with the angle edge of a wooden chopstick without hurting the label. Laser contact welds are easily removed with a couple Dremmel touches (BE CAREFUL to not go through the thin neg end on the cell with heavy-handed dremmeling.
Considering how tough it can be these days to find a decent 18650 battery, these packs tentatively receive the Ubehebe three thumbs up, but YMMV because it is afterall ebay. Of course, the resultant pack pulls are unprotected 18650s. If you are new to pack pulling, please read the various posts here and elsewhere about how to do it safely without burning a hole through your worktable or reducing your house to a pile of smoldering ashes.
http://www.ebay.com/sch/i.html?_odkw=5200+new+laptop+battery+acer&_osaca...
Link no workie? Search for 5200 new laptop battery acer oem on the flea bay.
Hope this helps!
Edited by: Ubehebe on 07/01/2014 - 15:56
downlinx
downlinx's picture
Last seen: 6 months 4 weeks ago
thanks for feeding my battery horde needs, hehe. I have a complex of lion horde. I have had to cut myself back to only keeping batteries that are 2500mah and above.
BLF Community Battery Pull Thread http://budgetlightforum.com/node/32720
Ubehebe
Ditto, but I have a soft spot for the green 2200 Samsungs, which are pretty good for general use, but not in the league of the almighty 2600 Samsung pinks or purple 2800s. (The gray Samsung 2400 18650s —- imho — are the woofers of the Samsung line; subperformers all.) And of course I’ll always grab the world-famous gray-green 2400 Panasonic CGR18650Ds, but they have been out of production for quite some time now, so finding any in new or lightly used packs is pretty rare.
I think the pinks last longer on a charge, sag less and store better than the Samsung 2800s (but not by much), although my tests are a little low-tech with just a light meter and a stopwatch.
Jerommel
Jerommel's picture
Last seen: 1 year 4 months ago
Wow, i found one free shipping to EU (at least to NL) for only 15 bucks!?
Too good to be true?
Next EU free shipping offer is 32½ bucks, many offers actually..
But it’s about time all those obsolete laptop packs get out there cheap, also for EU countries.
I find you can chew off the welding spots with good side-cutting pliars that can touch the surface, if you can understand what i mean..
dangerous
dangerous's picture
Last seen: 6 years 7 months ago
I’m considering trying this for my first laptop pull. Do you really need a dremel to get the tabs off?
BLF
Jerommel
Jerommel's picture
EDITED!
No, you can tear them off.
Fold over and pull with somewhat pointy pliers.
By the way, i put a nice blob of solder on the top, so that covers those welding spots there, and the bottom ones i managed to remove with the side snipper. (i’m lost for the correct words here…)
I used a file too for the last bits iirc.
Ubehebe
Absolutely not. They can be pulled off by rotating (more) and pulling (less) at the same time with needle-nose pliers, but little pieces of metal (devilishly SHARP little pieces of metal) inevitably get left behind, so the dremmel is to remove those those nasty bits left behind. Other people get rid of ‘em in different ways; maybe someone else will chime in with other methods.
And yes solder blobs on the flat-top positive terminals is a great idea (that’s what I do). But you have to just drop a blob of solder on there without preheating the pos. pole in ANY shape or form. DO NOT PREHEAT THE POSITIVE POLE. The solder blob will stick just fine without the preheating (I have hundreds and hundreds of nicely shaped blobs to prove it).
Why not preheat? The battery catalysts are inside the cell case rolled up in an ultra-thin plastic bag, sort of like a jelly roll. If that VERY thin bag gets melted or punctured, air gets in, and nastiness results. The worst that can happen is the infamous “venting with flames.” The least = dead battery. So don’t preheat the battery. No reason to anyway.
Legolas Jr.
Legolas Jr.'s picture
Last seen: 1 week 6 days ago
Look what you’ve done, Ubehebe! Now I have to buy more batteries!
…………..just kidding, thanks for the heads up. :bigsmile:
“Strive to be a warrior and a scholar. Be forged in fire and tempered by knowledge. If not, you will either lack the courage to fight for your ideals or lack ideals worth fighting for.”
ChibiM
ChibiM's picture
Last seen: 2 hours 33 sec ago
If anyone has the time of the world, maybe make a Laptop pulls overview thread. with name/model of the battery pack (laptop, power tools) together with What cells are inside.
I like overviews, all useful info in 1 thread!!
especially with BLF growing bigger and bigger, many threads get buried.
Old-Lumens
Old-Lumens's picture
Last seen: 4 years 9 months ago
Well, I've never done laptop pulls, but I went ahead and bought one. I will do a video of the tear down and results in case anyone wants an FYI and how "not to".Tongue Out
My PayPal address: oldlumens (insert the @ sign here) gmail.com
My YouTube Flashlight Video Channel
The BLF Modding Links Thread
http://imageshack.com/a/img922/1374/jQ2wdL.jpg
downlinx
downlinx's picture
I like overviews, all in 1 thread.
I like this idea, maybe we should do an all in one thread. Name of laptop battery+type of battery inside. Also, show the easiest way to open.
BLightSam
Last seen: 2 years 9 months ago
Recipient of two nasty cuts from the devils!
Ubehebe
My worst cuts from pack-pulling are from the plastic, which is also like razor blades, althought it doesn’t look it. Sharp edges come from packs being slowly peeled off piece by piece with needle nose, or at least that’s what I do. Go at removal too aggressively and the battery covers get marked up, so slow and careful is the way for me. Or REALLY aggressively and even the thin-cell wall can get dented, and that’s a definite no-no. One dent in one of my cells, and it’s in the trash. Too big a chance of puncturing or malforming the catalyst bag. In fact, most li-ion manufacturers say to just plain throw the cell away even if you just drop it.
So I always wear work gloves when pack-pulling. Know it seems like overkill, but it really ends thinking about what is sharp, and allows me to go at it without worrying about cuts. Haven’t had one cut since, and I had a couple almost to the bone from that *&^&^%$#$ plastic before the gloves.
downlinx
downlinx's picture
exactly, i am sitting here with one cut from a NIcd from last night because i didn’t put my gloves on.
Muto
Last seen: 1 hour 12 min ago
Use the cut off saw wheel and start very near seams and it goes better, Gloves are a must.
The difference between Hoarding and Collecting is the illusion of Organization
“History doesn’t repeat itself, but it sometimes rhymes,” Mark Twain
After the Apocalypse there will be only 2 things left alive, Cockroaches and Keith Richards
downlinx
downlinx's picture
I usually use a dremmel with a 1/8th” gauard so i know i don’t cut too deep.
Ubehebe
Yes, I use dremmel cutting wheels, but these acer packs are constructed to torment deconstructors. One seam is easily cut, but the other one is too close to the cells for a cutting wheel, at least it is for me. But I’m pretty fast ripping away with needle nose once I know my hands are protected with those gloves.
MoZuKa
MoZuKa's picture
Last seen: 3 years 5 months ago
Old-Lumens wrote:
Well, I’ve never done laptop pulls, but I went ahead and bought one. I will do a video of the tear down and results in case anyone wants an FYI and how “not to”.Tongue Out
May the light be with you…
leaftye
On the packs I have right now, an x-acto blade can be fit under most of the seams and cut the glue.  On the sides it could be popped open by fitting a screwdriver along the seam and prying up along the direction of the seams--not into the seam towards the batteries.  Then the pack almost opens like an oyster, although the amount of glue they put on the cells makes a huge difference.  Even so, I still got lots of cuts even after getting the process figured out about as well as I can imagine.  Then there's grinding the weld points down, adding solder blobs or brass discs to the positive end if desired, cleaning off all the glue, and replacing torn wrappers.  It really sours the value of the deal if you also value your time, but it's great if you have time to kill or have the magic touch that I very much lack when it comes to doing this.  Everyone should try one though, ideally while checking initial voltage and internal resistance before pressing those cells into service.  It almost makes me feel dumb for buying a bunch of packs with these cells in the past.  I was going to sell some of them, and now it's feeling like a burden.
Btw, if you pack pullers are up for it, I'd love to recycle your solder tabs if paying postage is enough to get those mailed instead of going into the trash.  Just the silver tabs, not the copper between them.  I'm using the nickel tabs for nickel plating as an intermediate layer for copper plating.  Or if you're planning to do some electroplating too, you'll definitely want to hold onto those tabs.
The low mode should be lower.
dangerous
dangerous's picture
I bought one. I’m not really doing it to save money. I just want to see how hard it is – seems like a fun little trial. I plan on using: gloves, screw driver, pliers, solvent, and file.
BLF
downlinx
downlinx's picture
Screwdriver and needlenose pliers will be all you need for these battery packs getting ready to do an HP pack tonight, I might take some pics
leaftye
dangerous wrote:
I bought one. I'm not really doing it to save money. I just want to see how hard it is - seems like a fun little trial. I plan on using: gloves, screw driver, pliers, solvent, and file.
That's a good reason to do it.  It's part of the hobby.  I just wish I was lucky enough to find free packs like some members here.  That would get me way more excited about laptop pack pulls.  Free price is best price.
downlinx
downlinx's picture
leaftye wrote:
That’s a good reason to do it.  It’s part of the hobby.  I just wish I was lucky enough to find free packs like some members here.  That would get me way more excited about laptop pack pulls.  Free price is best price.
I tell you what, you pay shipping, I will send you the pulls I don’t want.I get 1 or 2 packs free every couple weeks and I only keep pulls that are 2500 or 2600 mah or more.
leaftye
Hey, I'd be totally up for that, thanks!  There was someone else that was willing to do that, I think it was Bigwood, but he's up in Canada and the postal fees were ridiculous.  I'll be sure to do some giveaways with those to give back to the forum.  I'm overdue for one anyway.
Muto
Heat is your friend with glue, if you have a heat gun that is even better provided you do not over do it.
Once you get the glue separating they can open up like a clam.
HTH
Happy hunting!
leaftye
That sounds much better than my first attempt.  My brilliant idea for my first pull was to use an old soldering iron like a hot foam knife.  That soldering tip still has plastic I can't get off it, and to add insult to injury, the heat spot welded one of the seams.  I'm pretty sure I cut myself on that pull too.
dangerous
dangerous's picture
I got my battery. I was able to get all the cells out in under 20 min. There was one casualty.
How smooth does the top and bottom have to be? I got it smoothe enough so that it won’t cut you, but you can still feel the bumps…
I found it to be a very easy process overall if you don’t mind possibly damaging 1 cell. I did not need a solvent to get the dried glue off, it came right off just by scratching it.
BLF
downlinx
downlinx's picture
Should be fine, you don’t need to take the welds off if you don’t want too. Just make sure the the pieces of metal is flat so you cut yourself
Old-Lumens
http://budgetlightforum.com/node/32594
Video of my opening a pack for the first time. Might not help anyone except myself.Laughing
light dispels d...
Last seen: 6 years 8 months ago
Received my two packs. Got both open pretty quick. All cells had 2.6v. Charging them and see how it goes.
mp3jeep
Last seen: 3 years 6 days ago
got my pack, sustained 2 cuts – slipped with the screw driver H) second was the metal tab – razors
2.6v for 4 cells and 2.5v on the other 2 cells
