Test/Review of Xtar 18650 2100mAh (Black)
5 posts / 0 new
HKJ
HKJ's picture
Last seen: 14 min 16 sec ago
DSC_5307
Official specifications:
  • Typical capacity: 2100mAh
  • Minimum capacity: 2000mAh
  • Nominal voltage: 3,6V-3,7V
  • Charge voltage: 4,2V ± 0,05V
  • Discharge voltage: 2,5V
  • Max. charge current: 4A
  • Max. discharge current: 15C = 30A
  • Chemical composition: LiNiMnCoO2
  • Protection circuit (BMS): No
  • Positive pole: button top
  • Diameter: 18,4mm ± 0,2mm
  • Height: 67,0mm ± 0,5mm
  • Weight: 46g ± 0,01g
  • Charging method: CC-CV
Xtar%2018650%202100mAh%20(Black)-info
This is a high current 18650 battery from Xtar.
DSC_5306
DSC_5308 DSC_5309
DSC_5310
DSC_5311
Xtar%2018650%202100mAh%20(Black)-Capacity
The two cells tracks very nicely and has nearly constant capacity up to 15A, but they are not really suited for 30A continuous draw.
Xtar%2018650%202100mAh%20(Black)-CapacityTimeHours
Xtar%2018650%202100mAh%20(Black)-Energy
Xtar%2018650%202100mAh%20(Black)-PowerLoadTime
Xtar%2018650%202100mAh%20(Black)-TripCurrent
Xtar%2018650%202100mAh%20(Black)-Charge
Conclusion
The batteries is a good battery with acceptable performance, but the 30A specification is a bit misleading.
Notes and links
The batteries was supplied by Akkuteile.de for review.
Major
Major's picture
Last seen: 6 years 6 months ago
Thank you for the review
Calmaja
Last seen: 2 years 5 months ago
Oops, may be must change the label Big Smile
Thanks you HKJ
HKJ
HKJ's picture
Calmaja wrote:
Oops, may be must change the label :D
Over rating the cell, or maybe using pulse rating it not only done by Xtar. It looks like it is on the raise, probably due to vapers that wants very high power.
I do not see it as a problem using pulse rating, but it must be specified that it is pulse rating and for how long pulse and preferable also a rest time or a repetition rate.
Calmaja
Too far compare than this one. May be, can stand discharge at 30A, is better description in the label. Blushing
