STARTED: GBGB: Stainless steel AAA clicky with a clip (CQG S1 "clone")
627 posts / 0 new
lekvar
Mine finally arrived! The machining is great, though I think the threads are nicer on my CQG AAA. The light is very warm and the clip feels sturdy. IT’s a bit stouter than the CQG and feels good in my hand. The clicky’s great though of course that makes tailstanding nearly impossible.
Over all, a great littl light!
Gj
Gj's picture
My second order(July 21) arrived today, 4xNW. All working well, same warm tint as before, no logos this time.
(edit:fixed date typo)
Muto
Last seen: 12 min 9 sec ago
Well, I could sit here is say ohhh, it’s China junk, it won’t work on AAA.
But maybe it would have had I not fired it up on a 10440 and it looked good but as expected, got hot quick.
Before a AAA was tried, an Efest at around 4.04 volts was inserted and nothing??
Well, the top looks real close in appearance to the bottom and when you are in hurry, you can figure out the rest.
Must not have reverse polarity protection or maybe it did and that is what burnt?
Head got hot just that quick, pulled the batt and the flashlight tube she smells real burnt.
Anyway, thanks to the for showing all the parts and directions on dis assembly I was able to discern that the spring got hot and compressed some. Pulled that back out a bit and reassembled.
It seems to pull just over 1 amp on the Efest 10440 which is now down to 3.94, but will not run on a AAA alkaline or lithium.
So, I fried or hampered something on the driver apparently.
I only planned on using the higher voltage cells anyway, so live and learn.
Very nice light however, took exactly 1 month to get here.
Thanks,
Keith
The difference between Hoarding and Collecting is the illusion of Organization
.“I will get one of flashlight from patrol car”
“History doesn’t repeat itself, but it sometimes rhymes,” Mark Twain
After the Apocalypse there will be only 2 things left alive, Cockroaches and Keith Richards
tkmckay
Last seen: 2 days 20 hours ago
I had my order in the mail box when I got home last night, 2 cw and 2 ww. The ww’s had no branding on them while the cool whites did. For $6 each I am really impressed to tell you the truth. I really, really like the warm white ones alot, enough so that I think I will be placing another order for some stocking stuffers/gifting ideas. This is now my new at work pocket light. Big Smile
lionheart_2281
lionheart_2281's picture
Last seen: 16 hours 26 min ago
Thanks,
Keith
Did you insert the battery with the negative end pointing toward the led?
Boaz
Boaz's picture
Last seen: 4 hours 37 min ago
The clips from the Dqg /S-1 are so much better .
Bought about 5 when I bought the s-1.
 think they were about  a buck extra
http://www.cnqualitygoods.com/goods.php?id=1891
                 υμεις εστε το φως του κοσμου ου δυναται πολις κρυβηναι επανω ορους κειμενη
downlinx
downlinx's picture
wish the code was still good, i would order a couple more of these.
BLF Community Battery Pull Thread http://budgetlightforum.com/node/32720
_the_
_the_'s picture
Last seen: 2 months 4 weeks ago
Isn't it? I asked GB to extend the buying period and they agreed to do so.
Edit: Tested and works. Smile
=the=
downlinx
downlinx's picture
the wrote:
Isn’t it? I asked GB to extend the buying period and they agreed to do so.
i must have typed it wrong, thank you
_the_
_the_'s picture
No prb. Happy to enable. Smile
=the=
Cereal_killer
Cereal_killer's picture
Last seen: 2 years 9 months ago
Guys with non-working lights- in a few weeks when my GAW lights get here I’ll have 9 stock drivers, if you guys need I can supply you replacements then. (I’ll also have a couple spare tiniest10’s left I could sell you if you want modes/adjustable output / 10440 only)
Major
Major's picture
Last seen: 7 years 3 months ago
Received my 2 x CW and 2 x NW a few days ago. Took about 15 days to the UK.
very impressed at the obscenely low price. The perfect finish. The tail cap join is impossible to see unless you know exactly where to look.
Head to head with a 9 led cheapie also on alkalines it’s slightly brighter on ceiling bounce and blows the 9 led cheapie away on throw and has nicer tint. Should have bought all CW’s, something like these little lights you just want as bright as possible.
raven38571
raven38571's picture
Last seen: 1 month 4 days ago
Finally got my lights today. Smile
downlinx
downlinx's picture
4 more ordered
Tom E
Tom E's picture
Last seen: 1 month 1 week ago
Rcv'd my two CW pieces today. Stock amps was about 0.98A on a charged TrustFire 10440 @4.10v, lumens was 153 @start and 126 @30 secs, dropped pretty good -- there was no grease or epoxy whatsoever under the MCPCB. Couldn't wait too long - here's my start:
These 10 mm SinkPAD's are great to work with - easy to sand/file down. I did a similar mod to my Tank007 E09. I trimmed the outer edge with a dremel sanding drum. Used 150 sand paper to take down the height from 1.55 mm to ~1.15 mm - sand paper on the bench, rubbing the SinkPAD over it by hand, and used a small round file to make the wire indents deeper. The stock MCPCB is about 1.0 mm thick. Since the pill is brass, I'll just trim out the wire holes to get rid of the edge bumps, sand it down lightly, them I'll probably reflow the SinkPAD to the pill. I'd like to keep the SinkPAD a little thicker than the stock one to help on the heat. Have a few more things to do - little more sanding of the edge to fit easy in, angle file the edges along the wire pads to ensure no grounding, ensure I got enough space for the wire (maybe 24 AWG I'll try), then the biggest problem:
  • decide on an emitter, choices: Nichia, XP-G2 warm/neutral, XP-G2 1A, or the new XP-G2 S2 2B
Richard's XP-G2 Q2 7C4 at 90+ CRI looks pretty awesome, available bare.
On 10440's, these little guys get hot really fast, even on 0.80A, and maybe a not-so-great pill mount. Think I'll just leave the stock driver for now, and use thermal/electrical conductive grease around the pill.
Ohhh - be careful with the tailcap off - the edges on the body tube are super sharp. I cut up my hand pretty good when trying to open up the bezel end (stupid me...). I put the tailcap back on, then broke out the $4 rubber coated gloves - then it came off real easy...
Since I got 10 mm XML SinkPAD's, for the 2nd one I think I'll file out the hole in the reflector - it has a flat surface at the bottom, so I think an XM-L2 or XP-L would work pretty good.
zeremefico
zeremefico's picture
Last seen: 3 hours 7 min ago
received mine two days ago.
nice build but the emitter is way off centre.
will come back with photos.
₪₪₪₪ ΟΥΔΕΝ ΚΡΥΠΤΟΝ ΥΠΟ ΤΟΝ ΗΛΙΟ ₪₪₪₪
My YouTube channel
Flashlights & edc gear
K40M F16
unknown00101
If you loosen the bezel a bit you can kind if tap it a bit to get it to center.
That or remove the bezel and the o-ring and the glass and reflector will slide out. Reassemble and center the emitter. Just takes a few minutes.
antiparanoico
Last seen: 3 weeks 5 days ago
CSgearbest wrote:
antiparanoico wrote:
freeme wrote:
… Coupon expired
Dear all,
Sorry for the mistake and our coupon is now available Wink You can just buy this cute light at $5.99 still!
Works. Thanks.
The second ordered…
If anything can go wrong, it will.
Matter will be damaged in direct proportion to its value.
Tom E
Tom E's picture
Oh boy.. Ordered 8 more... They will make a nice gift - very pleased with the 2.
southland
southland's picture
Got 4 today, kind of neutral on these, there OK but nothing special or pretty nice but not that nice, if you know what I mean. These 4 will do, no reorder. The cw looks pretty good but the nw is very yellow.
Edit: After playing with them a little more, I like them better, buy one.
ImA4Wheelr
Last seen: 1 year 2 weeks ago
Thanks for the mod info here Tom E.  Looking good.
I received 2 more today of the 6 I ordered.  So I'm up up to 3 NW received.  All have no logo and look and work great.  I have 3 CW's on the way.  Betting they have a logo give the above.  I may try to polish them.
Tom E
Tom E's picture
I finished my SF-348 mod from post #434. Don't have all views, but here's some:
Ok - think this mod is almost useless on a good Efest IMR 10440. Here's specifics:
  • XP-G2 S2 2C (from FT) on a 10 mm SinkPAD sanded down
  • high qual thermal grease under the SinkPAD
  • replaced wires with 24 AWG
  • NO-OX-ID around the pill, Nyogel on the threads
Light
Cell
Volts
Amps
Lumens (@start-@30s)
Stock SF-348
Primary Lithium
1.8v
0.50A
47-46
XP-G2/SinkPAD
Primary Lithium
1.8v
1.60A
82-72
Stock SF-348
Efest IMR10440 V1
4.14v
1.17A
160-138
XP-G2/SinkPAD
Efest IMR10440 V1
4.14v
2.70A
415-260**
Mod'ed light with the Efest goes into some sort of over-temp mode, because it starts blinking output in like 20 secs, and the top end of the light is extremely hot. Looks great though for the first 10 secs Smile. So, what's going on? Seems like the driver is in DD mode, but not sure if it's something I caused by the mod or not.
Ohh - my amps/lumens measurements are very close to what's listed in the FAQ section on the product page listing on GB (gearbest.com SF-348). Wonder where they got those #'s from...
_the_
_the_'s picture
Nice mod! Thanks for sharing.
Who would use the light more than 10s anyways? Big Smile
Maybe from post #50? Wink
=the=
Tom E
Tom E's picture
_the_ wrote:
Maybe from post #50? ;)
SmileSmile - stupid me, of course!
antiparanoico
freeme wrote:
… Coupon expired
Dear all,
Works. Thanks.
The second ordered…
Shipped…!!!
jopat
Last seen: 7 years 9 months ago
@GearBest
I still haven’t received mine, ordered on July 16.
Order No.:W1407102226414145
downlinx
downlinx's picture
jopat wrote:
@GearBest
Gearbest has really slow shipping so it maybe some time.
raven38571
Just wait a little longer. I didn’t get mine until August 7th. I ordered them on July 7th.
dangerous
dangerous's picture
Last seen: 7 years 7 months ago
I would like to see this light in a 2AAA form factor. It would be nice with XPG2.
BLF
Jerommel
Jerommel's picture
Last seen: 2 years 4 months ago
1 arrived, 1 not yet…
Ordered seperately because the coupon only worked for 1 at a time at the time..
Guess it’ll be here when i get back form 2½ weeks France (Charente), hope so..
Clearly NW = WW and CW = NW
The WW is very warm, very much yellow, even orange-ish.
Unbranded flashlight, which i think is nice.
