Test/Review of Keeppower IMR26650 4200mAh (Black) 2014
6 posts / 0 new
HKJ
HKJ's picture
Last seen: 1 week 6 days ago
DSC_5850
Official specifications:
  • KeepPower IMR 26650 3.6V/3.7V 4200mAh High Drain Li-ion Rechargeable Battery
  • Type: Li-Mn
  • Min Capacity: 4100mAh
  • Typical Capacity: 4200mAh
  • Normal Voltage: 3.7V
  • Quality Lithium Ion rechargeable cell
  • Maximum Capacity and Reliability
  • Ultra Discharge Current: 50A
  • 4.2 volts max voltage and 3.6-3.7 volts nominal voltage
  • Flat top: Yes
  • Dimension: (D)26.50mm*(H)67.000mm
  • Weight: Max. 95.0g
Keeppower%20IMR26650%204200mAh%20(Black)%202014-info
This is a high current 26650 battery, but as the test shows, the current rating is too optimistic.
DSC_5849
DSC_5851 DSC_5852
DSC_5853
DSC_5854
DSC_6208
One of the batteries got rather hot during my test and melted the shrink-wrap
Keeppower%20IMR26650%204200mAh%20(Black)%202014-Capacity
Looking at these curves the cells does track nicely in capacity and can handle 20A, but 30A is too much.
The 50A may be meant as a pulse rating, but the specification does not say it, a pulse rating must also include a pulse time and preferable a repetition rate.
Keeppower%20IMR26650%204200mAh%20(Black)%202014-CapacityTimeHours
Keeppower%20IMR26650%204200mAh%20(Black)%202014-Energy
Keeppower%20IMR26650%204200mAh%20(Black)%202014-PowerLoadTime
Keeppower%20IMR26650%204200mAh%20(Black)%202014-TripCurrent
This test "only" goes to 15A and the battery handles it fine.
Keeppower%20IMR26650%204200mAh%20(Black)%202014-Charge
Conclusion
The battery has good high current performance for a 26650 battery, but not as good as the specifications promises.
The cell looks like good quality and as usual my rating will be acceptable, but do not run it at 50A.
It is also interesting to compare it to some of the best high current 18650, the large size has advantages at 20A.
Notes and links
Compare to 18650 and other batteries
Compare to 26650 and other larger LiIon batteries
RaceR86
RaceR86's picture
Last seen: 5 years 9 months ago
I just did a product request for KP IMR3500, and now this already beats it in both capacity and with slightly less voltage sag under load.
This cell is a winner! Nice to see that 26650 cells now are catching up to their true potential.
BLF LED database – collaboration spreadsheet and latest news about where to buy LEDs
http://budgetlightforum.com/node/19342
Ejected Filament
Ejected Filament's picture
Is it wrong to assume these are just a KK inside?
Or is it obvious from the readings it is not?
Thanks as always HKJ for another helpful review.
Richie086
Richie086's picture
Last seen: 1 hour 26 min ago
Great job HKJ. Considering the price compared to my EnerPower 26650’s, I think I may give some of these a try in my high power lights. From the sizing chart, they should fit perfectly in any of my 26650 lights just as well as the EnerPower’s or MNKE’s.
Richie
RaceR86
RaceR86's picture
Ejected Filament wrote:
Is it wrong to assume these are just a KK inside? Or is it obvious from the readings it is not? Thanks as always HKJ for another helpful review.
These have slightly lower capacity, but are considerably better at higher amps.
Cant be compared to KK.
You can compare cells here:
http://lygte-info.dk/review/batteries2012/Common26650comparator.php
Werner
Werner's picture
Last seen: 2 years 2 months ago
The available 26650 4200mAh seem to have a different wrapper?
Is this a new cell or just anew wrap?
I ordered one from GB in their latest coupon promotions:
http://www.gearbest.com/chargers-batteries/pp_104846.html
Coupon: Keeppower
Comes to 12.74$ total with shipping.
