Keeppower IMR26650 5200mAh (Black) 2014
Official specifications:
- Min Capacity: 5100mAh
- Typical Capacity: 5200mAh
- Type: Li-Mn
- Normal Voltage: 3.7V
- Quality Lithium Ion rechargeable cell
- Maximum Capacity and Reliability
- Ultra Discharge Current: 20A
- 4.2 volts max voltage and 3.6-3.7 volts nominal voltage
- Flat top: Yes
- Dimension: (D)26.50mm*(H)67.000mm
- Weight: Max. 95.0g
This is a high capacity unprotected 26650, that is supposed to deliver 30A. It does not do that.
There is a fairly good tracking between the cell, but they do not deliver 30A, they are more in the 10A to 15A range.
Conclusion
The cells works fine as unprotected high capacity cell, but they are not really super high current cells.
Notes and links
Compare to 18650 and other batteries
Compare to 26650 and other larger batteries
