http://www.dealextreme.com/details.dx/sku.39359
Well what do you make of this thing? The UltraFire WF-501B at DX claims 800 lumens of output. Sounds a bit extravagent to me. And what's the scoop on the "M" bin type?
The M bin for the MC-E is the current brightest at 430-490 lumens out of 350mA. Probably 800 lumens is credible if the thing can lose enough heat - not something the P60 layout is good for - and if the driver can really sustain 2A into the LED. 2.8A is the maximum current it can handle. Driven at that, 1000 lumens might be possible with a good enough driver and a big enough heatsink. Considerably more than you could ever want to know about these LEDs is to be found here.
http://www.cree.com/products/xlamp_mce.asp
The numbers from my light tests are always to be found here.
https://spreadsheets.google.com/ccc?key=0ApkFM37n_QnRdDU5MDNzOURjYllmZHI...
Thanks for the info! That looks like a very good price to me if it really comes close to that output.
It probably will for a while, then drop back to around 400 lumens. Still enough to stun armadillos at some considerable distance.
I would get it just for the dropin....lol. It is a nice light but the claimed lumens on a small head like that will kill the emitter i would think.
With Darkness, there will always be Light.
Just ordered one - probably my last new light for a while. Will report once they get around to sending it to me.
I suspect it won't be any brighter than the KD MC-E dropin I already have but the meters will tell the story. Heatsinking is the real issue with such things - a lot of tinfoil and some heatsink goo should sort this out. The KD MC-E dropin I have once heatsinked properly does warm up the light quite considerably. Better that than cooking itself though.
I may have to get one and swap the emitter/driver with my C8 when i get it. Though I will have to wait awhile still have my 6v latern to 5 mode Q5 project to start when the emitter gets here
Why not just get yourself an emitter. $16 from DX Cree XLamp MC-E K0-WG 370~700-Lumen LED Emitter on 20mm Star Board (MCE-WG-K0)
For another $4 I get another 501b spare parts ect.
If it works for you... I notice you also get an alleged M bin instead of a K bin so it might be a bit brighter depending on the driver.
Even Better
Will be awhile B4 I do it though. Too many domestic things to do...
