This will be the build thread for my newest project, its quite a ways off from firing up for the first time but I have the emitters ordered as of today and am working on the driver board and I already have the heatsink (solid copper) built and installed in the host and the reflector holes opened up for the SST-90's domes. The driver is a FET based driver ran by an ATTiny85 which at first will be supplied by DrJones and his FW till I'm able to write my own (also looking at the possibility of using a PIC MCU from tterev3 like used on his MLEV)
edit 8/7 new RGBW driver (not for this project) in post 101, an independent channel driver that takes a PIC MCU bought from tterev3 preloaded with his MELD UI.
Anyway dont expect daily or even weekly updates, just teasing you for now but I will update this thread as things progress.
I posted these same two pic's in the OSHpark thread, this is my first real project, could of choose something simple but nope, thats not my style, I go balls out!
So here you can see the DPAK FET, the MCU and the other components on the front of this 22mm board:
looks good right? But wait, whats that on the back side?
Its just two more FET's! Running the 3 SST-90's together in parallel would be bright sure but I could do that with an existing BLF driver, this one has independent channels for all the cool color mixing and other functionality both DrJones' and Everett's UI's are capable of. Any of the 3 channels can be ran at any level independent of the other channels, one, two or all 3 emitters can be on at any time and all 3 can be on for "white".
This will be my second RGB only (no white emitter) light and I'm really liking the idea, sure colors arn't true but its just to fun to matter plus strobe is much more effective than white only, you literally cant walk when having a 19khz RGB strobe blasted at your face (ask all my friends if you dont believe me, it literally makes you loose your sense of equilibrium). Last weekend we took my RGB light out to the river and shining it down at the ripples on the water while walking on the beach made it even worse, my one [albeit slightly inebriated] buddy went down in the water about 3 steps after turning the strobe on lol.
Anyway thats all for now, check back for updates and stuff but this is probably gonna be a few month project, customer orders come first especially over my "toy's". For you're guy's entertainment I'll try to get some pic's of the shiny heatsink and the host up today too.
RIP SPC Joey Riley, KIA 11/24/14. Now I am become death, the destroyer of worlds.
Reserved
shockli great imr batteries
BLF ≠ B-grade Flashlight Forum
NOICE!!!
Here’s the HS, its perfectly slip fit and has 2 screws from the bottom to hold it even tighter, the ano under it was chemicly stripped.
It’s polished to 2000 grit (you can see my ugly mug in it!) but I finished it last week and it’s got a hazy layer of oxidization on it already, I’ll re polish it when it comes time for assembly after drilling the wire holes.
The bottom of the SL3 reflector is nearly flat and will be almost impossible to fit the large Ga wires the current levels require so I’ll be using 28ga copper strips sheathed in heatshrink tubing.
One more pic for now, this is how the Noctigon’s have to be shaved to be able to fit them all (this is just a white SST-90).
this project looks extremely interesting to me!
Mooooooo
This project is great ! And this driver has more uses than just as an rgb driver (not sure what yet...)
link to djozz tests
Thanks man, I knew you would like it!
The driver could be useful for tint mixing of white emitters too, or emitter mixing and it wont be hard to mod it to 4ch for an XML color. With the big FET’s it’ll be overkill for a lot of projects (including pretty much anything XP based or an XML color) but I plan on adapting it down to 17mm using SOT-23 package FET’s (such as the IRLM2502 we use on 15/12/10dd’s), in that case instead of “white” being RGB all on at once white would have its own channel and its own emitter/die.
I love that idea of making a 17mm rgbw version with small FETS, (dream: especially if you manage to squeeze everything on one side of the board, that makes it suitable for more hosts).
Two concerns: 1) apart from those SST90 monsters there are no colour leds that can handle direct drive from a li-ion, so there must be space reserved on the board for current limiting resistors. 2) designing the board is a lot of work probably, and the group of people these boards are targeted at must be very small I guess?
link to djozz tests
I can mill wire clearance areas/pockets in the base of the reflector, if that would simplify things.
Man that thing is going to be sweet…Googled what a Shadow SL3 looked like
Daggum…and that is an INCREDIBLE job for your first Eagle design man!
CC is that an offer or your just saying its possible? If its an offer I'll definitely take you up on that! I'm not looking forward to trying to shove all the copper banding in there, the driver compartment on this thing is only 10mm tall so there is very little room.
Thanks man, I made a few library parts last week but I pretty much went from knowing nothing to having that board made up in <48 hours, I made eagle my bitch lol.
this is my host, its a really nice grey color (excuse the very dirty lens, the reflector under it is perfect tho).
Not sure if its true with every SL3 but this one has an actually stainless bezel instead of aluminum. I’ll probably end up heating it up to turn it rainbow to match the RGB aspect before its back together.
What are the reflector dimensions? I have at least one spare 3x SRK reflector, but I think the SL3 is bigger.
Total diameter is 56mm and each of the cups are larger / deeper as well.
weeellll doggy! I'm pulling up a chair, popcorn, and beer for this one.
A disco in your pocket!
17mm for direct install into lights without having to be piggybacked (yes I forgot to bStop the bottom batt+ pad but thats where the spring would go). This one has the correct size MCU pad (for the 85-20SU) and 2502 FET’s!
There are several known problems (and probably several more I dont yet know about) but I’m working on it. just wanted to show off for now. The bank of resistors at the top are limit resistors (right most is C1).
I just realized, the forward voltages of the color SST-90’s are different.
Red has the lowest, followed by blue and then green.
Driving them with FET’s may cause a problem.
Pages 12-14 on Luminus’ datasheet: http://www.luminus.com/products/Luminus_SST90C_Datasheet.pdf
The green and blue will be allright, the red @ 2v is as issue tho I’m running a RGB light with XP-E2’s now and it works allright, the red is by far the brightest. Thats what the addition of the limit resistors are for on the 17, I’m gonna start from scratch and do another 22 tomorrow.
I’m figuring I’ll use one or two 1206 pad per channel and I can stack them on top of each other if more are needed.
So R G B leds will be near white light? Anyways, WOW this needs to have video!!! 3 FETs on a board lol.
I’m sure it’ll be a heck of a light. Good luck with the build!
He has a working RGB right now…Cereal you should post it up to see what they are gonna get…just BIGGAH!
These are XP-E2’s at ~1.2A each (that’ll soon be raised to 2.4A) the strobe it 19hz however each color only pulses at 1/3 that rate cause it does RGBRGBRGB (the iphone camera has no chance, video just doesn’t do it justice)
Thanks for the video!
Poor dog, getting blasted with RGB light.
Did you mean 19Hz instead of 19kHz, because that would be something like PWM, not strobe.
Wooo doggies! ;D
If only i can see it in person! A guy on the “other forum” posted about strobe.
Study of Tactical Strobe
Most important part:
Having said that, the right strobe needs some clear specs.
We found, that with a slow or changing strobe, the opponent was able to (slowly) move their hands without being detected. The strobe is still very disorienting from the slower 5hz to 12hz and even higher, but the effect seems to get less when going much faster than 24hz.
We worked the strobe up to around 18hz to 20hz and that problem (noticing movements)was tackled. At 18hz to 20hz, the strobe was still extremely disorientating and the opponent could not move a finger without detection.
So, strobes at 8hz, 10hz, 12hz etc ARE very disorienting, but could have unwanted negative side effects for the LEO.
Thats why we chose for the 18hz to 20hz, less unwanted side effects.
Do you think you can do a “no delay strobe” as in, there is no time delay between the color switching? maybe that could be pretty cool.
Poor doggies, they were never designed to suffer anything like that
You are lightning fast CerealK! I can't have a night sleep and the first version of a new rgb fet-board is done!
What is the driver now in that rgb-xpe2 light in the video?
link to djozz tests
About the values of the current limiting resistors on the little rgb(w) board: perhaps it is best to tune it while measuring output current. It will be dependant on the used battery and other resistances in the used host. I'd say, better be a bit on the low side with the resistors
, then it still gives good output with lesser hosts/batteries. It looks like 2A is perfect for all xpe2's (and xml-colour dies) if on copper/Sinkpad, and it seems that up to 3A is still handled fine.
link to djozz tests
Yes 19*Hz*, sorry bout the multiple typo’s, my phone insists on changing Hz to kHz every time I type it, it must assume nothing runs at JUST Hz anymore… I wish I have a video camera that could show it, its intense to say the least.
As for the driver, let’s just say its proprietary lol…
That thread you linked is the exact reason 19hz was choose. BTW a new driver is in development for the current light (with the assistance of my buddy tterev3) that will do even more (that’s why the drivers in this thread use the 8k tiny85 so I can program it AND have lots of room to play with) but the new one for the tk45 will be based on a PIC MCU to fit even more programming for fancy stuff.
I love you guys but please don’t expect much info on it, I’ll show it off sure but its one light I intent to keep the spec’s / production info on hush hush, atleast for awhile.
