Could you clarify some of the text from the web page?
If you have the flashlight handy, you can check these things — if you have a batch of them all the same:
The web page description says these things I quote; my comment indicated with —>
“2. Intelligent control circuits, five-mode memory dimming circuit”
—> does it remember the mode last used, so next time I turn it on again it comes back at the same mode?
—> (or does it always restart on the next mode, or always to the first mode?)
and
“Lens Type: High strength orgnic glass lens”
(spelled “organic” in the illustration)
—> Possibly a translation for “clear plastic” but that’s just a guess
and
“3.Do not let the torch’s glasses direct sunlight.”
—> Does the lens material melt, or crack, if left in direct sunlight or overheated?
and
“4.Do not use the direct without the protection of rechargeable lithium batteries.”
—> My guess is, this needs protected rather than unprotected cells.
—> Can you confirm exactly what it requires and what you are shipping with it?
Dang, this sounds like a pretty good deal - pretty much a FandyFire ST-V6 or T13 equal, head size same as a Yezl Y3, HD2010, or T08, maybe slightly bigger than a STL-V6, but of course the Y3 is a slightly bigger reflector, and I'd expect this to be as well. If classic SupFire, than quality should be a step up from a HD2010 or T08, or T13, but 18650 cell size is somewhat limiting. I don't have a STL-V6 to compare to.
there's no batteries included - batteries are mentioned for size only, meaning it can be run on 1 or 2 cells (95% sure )
I'm pretty sure it's got mode memory like the other SupFire's, but we should get that confirmed
organic glass - funny -- it's glass!
This could make a pretty awesome 2 series cell style thrower light, potential nice MT-G2 host. Looks like a threaded alum pill, just dunno the size, but should fit a piggybacked BLF17DDZ pretty well, I'm thinking/guessing...
Some replys:
In this selling, the batteries are not included, the selling includes 1 flashlight, and 1 lanyard
Supfire X6-T6 has memory function,it remembers the mode last used
The lens is definitely glass, “organic”, maybe some trasnlation misunderstanding
“Do not let the torch’s glasses direct sunlight”, it is wrong description
Supfire X6-T6 also has the protection function of battery reverse mount, it can use the li-ion batteries with protection or without protection
the discription is old one, I didn’t update it, sorry for some misunderstanding
