Test/Review of Imedion AAA 950mAh (Black)
Official specifications:
  • Battery size: AAA
  • Nominal Voltage: 1.2V
  • Dimensions: 10.2mm (Diameter) X 44.5mm (Height)
  • Rechargeable: up to 1000 times
  • Chemical composition: Ni-MH
  • Capacity: 950mAh
  • Low self discharge cells: loose 2% a month to self discharge
Maximum temperature raise at different discharge currents: 1A:+2,1°C, 2A:+5,3°C, 3A:+8,4°C, 5A:+12,6°C
This is LSD cells with fairly high capacity.
They have a good high current cability for AAA cells.
Conclusion
These cells looks good.
Notes and links
Compare to other AA/AAA batteries: Alkaline/NiMH/Lithium
Another great cell review. Thank you HKJ.
I've been using Imedion AAA's for maybe a year now, but I don't think they are the 950mA version you tested. They are the same LSD line and work great.
Thank you for review! Looks great!
I need some AAAs. Probably I will take them over Eneloops.
From what I see, this is better than an eneloop for use in a wireless mouse!?
