The two I currently use are the Nitecore i4 and the Thrunite MCC-4. I like the Nitecore because it has always been reliable for me but the problem is it is painfully slow. Especially when trying to charge 4x 18650 3400mAh Panasonics. The Thrunite can charge at 1A but it has never been reliable in terms of stopping at 4.20v. It will stop anywhere between 4.15-4.22v which I don’t like. So I looked at HKJs review of the new Opus charger and there was a number of issues which he brought up which made me think maybe I should keep looking.
So I have decided I might as well just bite the bullet and step up to a decent hobby charger. I found a thread which mentioned the iCharger, Accucell-6 and imax B6. So my first question is, is it worth paying the extra for the iCharger? I am happy to spend up to about $120 possibly more if absolutely necessary, which I believe would cover all of them. Secondly, is it possible to buy a holder to use with these hobby chargers which I can just place 4 batteries into at once and charge them all at the same time? or will i need to just stick with the magnets etc? Lastly I want to be able to charge everything from an IMR10440 to at least a 26650.
An Accucel 6 or B6 will be faster, and an iCharger will be even faster than those. Since you're in Australia, buy the iCharger 206b clone from Hobby Kings Australia warehouse. I wish the US warehouse had some in stock.
You can use a parallel battery holder, but it won't give you individual readings for each cell. Balance charging in series will give you individual readings, but will be slower.
If you want fast discharge tests, then get either the Opus, iCharger or iCharger clone.
I have both the iCharger and the Opus BT-3100. The best advantage of the Opus is that it can take 4 up to 70mm long cells at the same time, programmed differently at each bay, in any combination, whether charging/discharging each bay up to 1A, (2A in bays 1 and 4 only) refresh, regardless of cell size and chemistry, gives the correct discharge capacity, etc., among the other features it shares with the iCharger.
There are 4-bay battery cradles I bought from FT (available in series or parallel connected) but only for unprotecteds. I think the longest that can fit is 66mm only.
Yes, but in li-ions, most people prefer to do it in parallel. I have tried both and doing it in parallel sort of balances the different starting cell voltages in the end. Series is recommended for niMh though.
You mentioned in your OP you have up to $120 budget…why don’t you get an iCharger 106B+ AND a BT-3100!
If you were using the same 4 cells in a given light and never split them to use in other lights so they were all the same age with the same life cycle then you could do the above. BUT they would still need a balance charge every 3th - 4th charge.
I would actually advise never to charge any type of cells in series without proper balancing cables attached. Not worth it when parallel charging is so much easier.
I haven’t seen 26650 parallel cradles though, I usually charge my individual cells with a magnet with wires soldered to it.
After a while you get a feel for the battery. How hard you push them affects how soon/often you need to balance them. Of course, there are horror stories of batteries blowing up (literally) but there are thousands more that die more peacefully. I’m not worried about any of my batteries blowing up.
If you don’t understand much about balancing then best to start with parallel charging like suggested.
The small battery in the pic is a single cell so it doesn’t need a balance tap but the others are more than one cell so have balance taps.
Lithium batteries are more prone to different discharge rates (when in a pack) than nimhs. These small differences means you have cells with different voltages when the pack has run flat. If you were to charge them as a pack without balancing then the differences would magnify as the higher voltage cells would be over charged while the lower ones wouldn’t reach full charge. The balance tap has a wire running from the + and - of every cell in a pack so the charger can see which ones are higher voltage than the others and will drain from that cell through the balance tap while the pack is still being charged as a whole.
I hope I was clear enough but not to basic for you
