Recommendations for cheap R2 thrower + gun pressure switch
8 posts / 0 new
gorann
Last seen: 9 years 9 months ago
Any recommendations fior cheap R2 (alternatively q5) )thrower, and compatible pressure switch/pad  (maybe also a gun mount for it).
If it receives 18650 AND 3XAAA is a rather big +. (I know its not so bright with 3XAAA, but I have my reasons. )
First I was looking at this http://www.dealextreme.com/p/ultrafire-wf-501b-cree-r2-wc-250-lumen-led-...
with this switch http://www.dealextreme.com/p/superfire-gun-mount-pressure-pad-1025
But I really dont know, more experienced members will maybe have some better suggeestion or some even better deal suggestion...
Edited by: gorann on 07/14/2011 - 19:04
Tas62
Last seen: 6 months 1 week ago
with 28mm aspheric (DX SKU 5297), pressure switch from MF http://www.manafont.com/product_info.php/pressure-switch-for-ultrafire-5... and  Universal Mount (DX SKU 5819).
I blanked the reflector with a black paper cone (gets rid of nasty artifacts). It throws a great spot out to ~200m.
junkiexl
junkiexl's picture
Hi, I'm been reading the forum for a while and this is my first post.
I have almost the same setup:
UltraFire WF-501B Cree R2-WC:
http://www.dealextreme.com/p/ultrafire-wf-501b-cree-r2-wc-250-lumen-led-flashlight-black-1-18650-2-cr123a-16240
Glass Optics for Flashlights (28mm):
http://www.dealextreme.com/p/glass-optics-for-flashlights-28mm-5297
Superfire Gun Mount Pressure Pad:
You can paint the reflector with black paint to reduce led artifacts. Very bright and cheap thrower!
gcbryan
Last seen: 11 months 1 day ago
gorann wrote:
What are led artifacts? (something like spill? Can you show me on some picture which is on the net?)
 How long is that cable on the pressure switch?
Reflector in that R2 light is OP, wouldnt the smooth one be a better solution?
Tnx for all the advices, Ill probably buy it right now, probably there isnt any cheaper light like that...
I believe that so this R2 is biggest thrower among such cheap lights...
The Cree XR-E R2 is the biggest thrower among all lights (XR-E, XP-E, etc) the other variables are just how hard it's driven and how large the reflector/optic diameter is.
Artifacts are things like rings  or even worse the "disco ball" effect. I don't know of a link to a picture right off the top of my head.
A SMO reflector will throw further than an OP but if you are using an aspheric lens you don't want a reflector as that causes the "disco ball" effect and does nothing for throw when using an aspheric.
In many lights you can't removed the reflector since the light is using it as a spacer to keep the pill in place. If the pill is screwed in to the body of the flashlight you can just remove the reflector. Otherwise you need to remove the effect of the reflector. You can do this by painting it flat black or as others have suggested try putting a piece of cone shaped black paper in the reflector.
If you aren't going to be using this light in any way other than as an aspheric just paint the reflector black.
gcbryan
gorann wrote:
Tnx.
And I suppose that in this combo, wf501b and this aspherical lense, the lense is at exactly correct focal length, or do I need to fiddle with that? Do I need some rings or something (because I dont have them right now, I didnt need them)
 I don't have that particular light but I assume it's a standard P60 light. I've had a P60 light in the past with which I used that aspheric and it is at the correct focal length when used as a direct replacement for the standard glass lens so you should be fine.
When I did the same thing you are trying to do it took me just minutes. I just painted the reflector and put it back in the light, switched out the flat glass lens for the aspheric and screwed everything back together and I had a thrower!
You can make the beam look even better if you want to do a little more work but you may not find it necessary. I eventually ended up painting out the "Cree ring" as well. If you get a small bit of paint on the base of the dome while doing this you can take some Scotch "Magic" tape and from the flat side of the aspheric lens mask off only the outer edge and this will eliminate any artifact created by any paint you might have gotten on the base of the dome.
You don't need to do any of this if you don't want to however so the basic conversion is easy. I'm just giving you more details if you find if helpful after you've received this light.
junkiexl
junkiexl's picture
Here are some pictures showing the artifacts effect
http://club.dealextreme.com/forums/Forums.dx/threadid.563063
As gcbryan said (great post btw), you can avoid this effect painting the reflector
Regards
gcbryan
gorann wrote:
Thanx to all of you for your great help Smile
SO If I paint the reflector with black marker I wont have anything except hotspot? Great! Big Smile
I'd use flat black spray paint and give it two coats. You'll have that outer ring unless you use a small hobby brush and also paint out the silver ring around the emitter. Your call on that one. I did it and it works.
cabfrank
Last seen: 3 months 4 weeks ago
it works very well, and i highly recommend it if you want a thrower.
