YEZL Y3 CNQUALITYGOODS Group buy. 3 Versions. See post 274 for delivery details.
570 posts / 0 new
ImA4Wheelr
What size lens does this light have?  Or maybe the question is.  What size lenses fit?  I already have quite few AR lenses and would like to know if any of them will do before  ordering.
penumbra
penumbra's picture
Last seen: 1 year 8 months ago
56,8 mm and no the hd2010 (58 mm) can’t fit.
will manners
will manners's picture
I’m really undecided right now. Should I buy the Yezl Y3 or the Xintd X3? Smile
MRsDNF
MRsDNF's picture
I believe the question would be do you want a single cell light or a multi cell. Life can be so complicated sometimes. Wink
_the_
_the_'s picture
Last seen: 2 days 21 hours ago
If you can't decide, buy both! Tongue Out
=the=
Ejected Filament
Ejected Filament's picture
Last seen: 11 months 3 days ago
I would think the answer was obvious being as you live in NSW.
MRsDNF
MRsDNF's picture
Ejected Filament wrote:
will manners wrote:
I'm really undecided right now. Should I buy the Yezl Y3 or the Xintd X3? :)
What, move states. I heard Tassies a good place.Smile
Ejected Filament
He would be an outcast with his half of one head.
Tassie is stunning IMO.
will manners
First world problems aye Silly To me it doesn’t really matter. I’m more concerned about throw, anodizing, build quality and value for money.
the wrote:
If you can’t decide, buy both! Tongue Out
That’s what I originally had in mind. But alas I have to choose one. Otherwise I would have bought every single GB light Wink
Lol Silly
southland
southland's picture
Last seen: 1 day 22 hours ago
Yezl will throw farther.
gadabout
I've been mulling this over for a while.  I already have a couple of nice throwers that see little use (but then it's not really about need is it!)
Trying to curb my spending but also keen to try making an MT-G light and thought this might make a good host.  Not much discussion on that topic in this thread unfortunately.
Sorry if this has been asked but do we know the driver size/diameter?
Thanks for pulling this together MrsDNF.  Do we know if this is strictly 20 units only or was the talk of 50 more accurate.  Don't want to order now but then find out later that they are all gone?
Edit: found here http://budgetlightforum.com/node/27889?page=2#comment-546578
LED MCPB 25mm
Driver 23mm
Gj
Gj's picture
Last seen: 10 months 3 weeks ago
Seems to be 23 sold already if the counter on the product page is accurate.
ImA4Wheelr
will manners wrote:
. . . to me it doesn’t really matter. I’m more concerned about throw, anodizing, build quality and value for money.
In that case, this clearly is the light for you.  The larger reflector will make this a be better thrower.  Also, you can't fully drive an xml with one cell.  The higher voltage of 2S and 3S cells gives you the overhead you need to fully drive the emitter.
Just make sure you know how to safely use Li-ion in series.  A couple more precautions are needed.
Tom E
Tom E's picture
Last seen: 4 days 6 hours ago
Gj wrote:
Would Tom E please tell us the price of the one from Flashlightlens?
It's listed at $7.00 plus shipping - it's a UCLp 56.8mm x 2.25mm. I ordered two and it came to $16.50 total.
Here: http://www.flashlightlens.com/index.php?app=ecom&ns=prodshow&ref=UCLp_AR, then choose the size from the pull-down. Yes, they are rather pricey. I'm thinking what RIC has going on here: http://budgetlightforum.com/node/32906 sounds interesting for the Y3 as well. His AR lens in the past performed decently in independent tests, not as well as UCLp's but close (http://budgetlightforum.com/node/23993, http://budgetlightforum.com/node/22472) and they will certainly be cheaper, free shipping, Int'l shipping, etc. Problem is his stating the min qty of 50, so without someone organizing it, I don't see how this will work out.
will manners
ImA4Wheelr wrote:
In that case, this clearly is the light for you.  The larger reflector will make this a be better thrower.  Also, you can’t fully drive an xml with one cell.  The higher voltage of 2S and 3S cells gives you the overhead you need to fully drive the emitter.
The only thing that’s turning me off the Y3 is the low drive current. 2.5A is not much for a host of this size and many members have said that the driver is not modable to increase drive current. And while the two button interface is nice, it does not leave many options for a driver replacement.
dangerous
dangerous's picture
Last seen: 6 years 11 months ago
I was going to order, but then I noticed OP reflector and aluminum-mounted LED… XinTD X3 is SMO with LED on copper, is driven harder at stock, smaller, lighter…
BLF
Ejected Filament
It was discussed earlier, the reflector is smooth, not OP. Also, its 5th line down in the first post. Most people mod the crap out of these so the stock circuits are only partially relevant, not that Im certain what you said is true anyway, or that it matter much at the amps. If you want amps, you would change most if not all of it anyway.
As for X3 v Y3, read this post by TomE http://budgetlightforum.com/node/30212#comment-561423
If you want a smaller light, then the X3 is the one. If you want throw, the Yezl is it.
will manners
What would be a suitable driver replacement? Since I recall a few members saying you lose the ability to use 1 cell once you’ve modded the stock driver for higher amps.
ImA4Wheelr
You may be recalling correctly, but what I recall was that modding the driver does not result in current increases with one cell.  The mods figured out so far do increase current with 2 or more cells, but you can still use it with one cell.
Not sure why one would want to replace the driver.  I have read it has a nice UI and Tom E (I think) modded it to 7ish amps with just a small resister change.
EDIT: Sorry that doesn't answer your question.  Just throwing out some thoughts.  I too would like to know if there are any good driver replacements out there.  Options are always nice.
Tom E
Tom E's picture
dangerous wrote:
I was going to order, but then I noticed OP reflector and aluminum-mounted LED... XinTD X3 is SMO with LED on copper, is driven harder at stock, smaller, lighter...
Don't get confused - the Y3 is definitely SMO, not OP - no doubt, 100% sure, etc... The X3's copper is the cheap kind sold at DX, FT, and other places - it's not bad though, better than aluminum. Here's the #'s I measured:
Yezl Y3 (from WB), on fresh EVVA KK cell: 2.50A tail, 830 OTF, 61 kcd  (no issues)
XinTD X3 (from Group Buy):
#1 - 2.85A tail, 972 OTF, 47 kcd  (reflector imperfections around the emitter - doesn't seem to effect anything)
#2 - 2.85A tail, 952 OTF, 45 kcd  (not centered LED, quick drop in output noticed in 1st second)
The X3 is more pocketable but the heavier weight may be an issue to pocket. I see and read of more quality problems with the X3's for sure.
Here's some weight measurements I just did:
Yezl Y3 #1: 287g, Yezl Y3 #2: 290g
XinTD X3 #1: 300g,  XinTD X3 #2: 297g
Stock HD2010: 292g
 So, bottom line - Y3 at lower amps throws much better than a X3 (should be expected from the bigger reflector), but the X3 has more lumens because of the higher amps. The Y3 can take long batteries - I even fit 26700's, like the new KK 5000 26700 that test at 5300 mAh!! The X3 is short length cells only. Both are superior designs with a nice SS bezel, pill-less design, both have exc. heat sinking.
Though the Y3 is slightly lighter, I feel the heat sinking is located better. HD2010's for example have lots of wasted metal and thicker bezel which keeps the outer diam. large, but has a reduced I.D. of the reflector - not as optimized as the Y3.
ImA4Wheelr
It appears that my account shows 2 lights ordered, but I only ordered one.  Is this what it looks like if you order just one light?
NO.TimeTotalStatusOperate
xxxx2014-07-26 09:12:38$32.00Unconfirmed,Unpaid,UnshippedCancel order
yyyy2014-07-26 09:12:38$32.00Confirmed,Payed,UnshippedConfirmed
Please mark me down for an AR lens.
EDIT: Cancelled the mystery order in the first row above.  I probably just accidentally ordered another one.  I think I recall losing my internet connection while I was placing the order.
dangerous
dangerous's picture
Tom E wrote:
Don’t get confused – the Y3 is definitely SMO, not OP – no doubt, 100% sure, etc… The X3’s copper is the cheap kind sold at DX, FT, and other places – it’s not bad though, better than aluminum. Here’s the #‘s I measured:
  1. - 2.85A tail, 972 OTF, 47 kcd  (reflector imperfections around the emitter – doesn’t seem to effect anything)
  2. - 2.85A tail, 952 OTF, 45 kcd  (not centered LED, quick drop in output noticed in 1st second)
    The X3 is more pocketable but the heavier weight may be an issue to pocket. I see and read of more quality problems with the X3’s for sure.
    Here’s some weight measurements I just did:
    Stock HD2010: 292g
Ah, that’s interesting that the Y3 is lighter while being larger. The bigger reflector definitely makes this one a better thrower, thanks.
BLF
DB Custom
DB Custom's picture
Last seen: 3 weeks 1 day ago
Just ordered Version B of the Yezl Y3, I think. I was logged in at cnqualitygoods.com and used PayPal, but it was one of those instances where PayPal kinda hangs up and doesn’t finalize. So I cancelled in PayPal and was returned to the page asking to pay. Clicked it, went back into PayPal and it went through. Then it returned me again to cnqualitygoods.com and it said the paid failed.
So I’m not exactly sure I got Ver B ordered…
DB Custom
DB Custom's picture
Order is confirmed. Smile Thanks Ric and Steve, looking forward to this one. Wink
Gj
Gj's picture
Thanks for the link.
I agree, min. qty of lenses = max. qty of lights available. We'd have to buy 100% of the lights and get 100% participation for the lenses. Very unlikely.
DB Custom
DB Custom's picture
Since this is being discussed here…I put an UCLp in my Courui and took it from 341.25Kcd to 369.25Kcd, not bad for a lens swap!
DrJones
DrJones's picture
Last seen: 5 years 8 months ago
I also ordered one. Had the same message about failure after the payment went through, but I had that with other orders recently, too, but those got shipped anyway.
CarbonCrew
Last seen: 1 month 6 hours ago
Ordered a Version A!
MRsDNF
MRsDNF's picture
yyyy2014-07-26 09:12:38$32.00Confirmed,Payed,UnshippedConfirmedPlease mark me down for an AR lens.EDIT: Cancelled the mystery order in the first row above.  I probably just accidentally ordered another one.  I think I recall losing my internet connection while I was placing the order.
It may pay to contact Ric if your not sure. I dont know how accurate it is but if you go into order note it has a list of people who purchased the light. If theres any hassles let me know.
MRsDNF
MRsDNF's picture
There is only 22 lights shown as ordered. This does not sound right to me. It may pay to check with Ric or again check on the webpage under order note.
