Test/Review of Led4power 5A linear driver LD-1 (prototype)
30 posts / 0 new
HKJ
HKJ's picture
Last seen: 23 hours 44 min ago
This driver is a prototype version and during the test I got an update to it.
DSC_6338 DSC_6339
DSC_6340 DSC_6341
Official specifications:
  • Input voltage 2.8-4.35V
  • 5 Amperes(default) current
  • off-time mode memory
  • no components on spring PCB side!
  • place for decent size (up to 8mm bottom diameter) spring on spring side pcb
  • PWM-less TRUE CONSTANT CURRENT on all modes-no acustical or EMI noise
  • significantly longer run-times on lower modes compared to PWM-based(FET or AMCs) drivers-even >2x possible
  • stays in regulation on lower modes for longer periods of time compared to PWM-based(FET or AMCs) drivers
  • 6mohm power mosfet
  • pmos reverse polarity protection
  • calibrated voltage reference
  • less than 100uA parasitic current in sleep mode (40uA typ.)
  • enough space for easy led wires soldering(up to 20AWG,22AWG recommended)
  • 2.6mm total thickness(including 1.6mm PCB),16.9mm diameter
  • simple, intuitive UI, no disco modes
  • modes: 0.3%-1.5%-20%-100%,standard half press to increase mode
  • 0.3% disable via solder "moon" 1 (no solder mess on gnd ring anymore)
  • "turbo" mode option (140%@4.2V,drops linearly to 110%@2.8V),turbo enable via solder moon 2
  • tailcap switch and electronic side switch capable, independently or both at the same time with single firmware!
  • three separated e-switch user interface types(rather than one complicated)
  • 2-step low voltage protection(3V-restricted power; 2.8V-sleep)
  • over-temperature protection (threshold change possible by user)-disabled by default
For a full description of the driver see: BudgetLightForum
After the test, led4power did a modification to the driver, I have done a few measurements on the updated driver
Measurements
Tested with: Cree XM-L2, 3xCree XP-G2 and Luminus SST50.
Diameter: 17mm
Max. height: 2.8mm (May change in the final version)
Can be used with power switch alone or a mode switch can be connection for more possibilities.
With power switch: 3-5 brightness settings, remembers last mode.
With separate mode switch: 3 different UI's:
        UI1: 3-5 brightness settings, always starts from low.
        UI2: Ramping
        UI3: Simple on/off, use double click to change brightness.
Standby current at 3.6 volt is 42uA
When using battery switch it will remember last mode.
It is possible to disable 0.3% mode with soldered link #1.
A "Turbo" mode can be enabled with soldered link #2 (I did not test this mode).
UI and working mode
ModeChanges
The drive has some modes and settings that can be changed by holding down the mode switch.
UI will be changed after 7 seconds.
Over temperature step down will be changed after 12 seconds.
Over temperature reset to default after 15 seconds.
And if the button is pressed for more than 20 seconds the driver wil shut down.
Ramping%20UI
The ramping user interface works with the mode button. First turn the light on the hold the mode button to change brightness.
It is very important to release the button when high is reached, or the light will change UI mode.
HeatReduction
The driver will reduce the current when it gets hot.
Oscillations
The driver does have some invisible oscillations while doing this (sometimes).
Brightness
The different brightness settings and a step down without oscillations.
HeatReduction2
Led4power did not like the oscillations and found a fix. The above curve is done with the fix installed.
There is no trace of any oscillations anymore and the driver is not nearly as sensitive to temperature.
BrightnessFactor
One of the nice features about a linear driver without pwm is the better efficiency of the led. Here I have tried to measure it with a lux meter. First I measured lux at 5A and defined that as 100%, after that I measure lux at the lower settings. With pwm the efficiency of the led would have been exactly the same, because the current is the same, but only applied part of the time. With this driver the current is reduced and the efficiency goes up. At 1A the brightness is supposed to be 20%, the lux is 30% of max, i.e. about 50% more brightness than a pwm driver would have given.
The huge improvement at lower currents is because it is compared to 5A current, if maximum current had been 3A the improvement would have been smaller.
Temperature
Usual I will not do temperature check when testing drivers, because it is difficult to use the camera in my test setup and my cooling does not reflect the working conditions in a flashlight.
But this time I decided to try.
Temp941
M1: 51,3°C, HS1: 68,8°C
With a 4.35 volt input voltage the power transistor (HS1) get very hot, very fast. This is about 30 seconds after I turned the driver on and the microprocessor (M1) has already limited the current.
Temp942
M1: 53,8°C, M2: 44,3°C, HS1: 62,3°C
Reducing the battery voltage to 4 volt fixes the heat problem, this time it is the current sense resistor that gets hottest (But not to hot).
100% SST50
Led4power%205A%20linear%20driver%20100%25%20SST50%20HL
First test at full (normal) power. The driver is supposed to deliver 5A, but that did not last long enough for me to start the test.
The problem is the input voltage and the low Vf of the led, the driver reduces current very fast at high input voltage.
At 3 volt the driver steps the power down and flashes a warning and at 2.8 volt it will turn off.
Led4power%205A%20linear%20driver%20100%25%20SST50%20HLDriver
Led4power%205A%20linear%20driver%20100%25%20SST50%20HLLed
Led4power%205A%20linear%20driver%20100%25%20SST50%20HL%20B
Starting at a lower voltage allows me to see the 5A, but only for a short time.
Led4power%205A%20linear%20driver%20100%25%20SST50%20HL%20BDriver
Led4power%205A%20linear%20driver%20100%25%20SST50%20HL%20BLed
Led4power%205A%20linear%20driver%20100%25%20SST50%20LH
Starting from a lower voltage and working my way up works better. Here I get to 3.5 volt, before the driver gets to hot.
Led4power%205A%20linear%20driver%20100%25%20SST50%20LHDriver
Led4power%205A%20linear%20driver%20100%25%20SST50%20LHLed
100%25%20SST50
Sometimes the driver has oscillations on high.
100% SST50 with fix installed
Led4power%205A%20linear%20driver%20100%25%20SST50%20HL%20C
After the fix was installed the driver is much less temperature sensitive, and works fine with the SST50
Led4power%205A%20linear%20driver%20100%25%20SST50%20HL%20CDriver
But it does require a lot of cooling, especially if the battery can keep a high voltage at 5A load.
Led4power%205A%20linear%20driver%20100%25%20SST50%20HL%20CLed
20% SST50
Led4power%205A%20linear%20driver%2020%25%20SST50%20HL
When reducing the power, the driver does not have any heat problems. At 3 volt the driver steps the power down and flashes a warning and at 2.8 volt it will turn off.
Led4power%205A%20linear%20driver%2020%25%20SST50%20HLDriver
Led4power%205A%20linear%20driver%2020%25%20SST50%20HLLed
20%25%20SST50
1.5% SST50
Led4power%205A%20linear%20driver%201.5%25%20SST50%20HL
In the low mode the driver is a bit slow to adjust brightness, giving the saw tooth that can be seen in the current.
This is related to the resolution of the AD converter used.
Led4power%205A%20linear%20driver%201.5%25%20SST50%20HLDriver
Led4power%205A%20linear%20driver%201.5%25%20SST50%20HLLed
0.3% SST50
Led4power%205A%20linear%20driver%200.3%25%20SST50%20HL
The driver has a stable 0.3% output. The steps in the input current, is due to my equipment, not the driver.
Led4power%205A%20linear%20driver%200.3%25%20SST50%20HLDriver
Led4power%205A%20linear%20driver%200.3%25%20SST50%20HLLed
100% XM-L2
Led4power%205A%20linear%20driver%20100%25%20XM-L2%20HL
First test at full (normal) power. The driver is supposed to deliver 5A, but they did not last long enough for me to start the test.
The problem is the input voltage, the driver reduces current very fast at high input voltage.
Led4power%205A%20linear%20driver%20100%25%20XM-L2%20HLDriver
Led4power%205A%20linear%20driver%20100%25%20XM-L2%20HLLed
Led4power%205A%20linear%20driver%20100%25%20XM-L2%20HL%20B
Starting at a lower voltage works much better, this time I do get 5A as long as I have enough voltage for the led.
Led4power%205A%20linear%20driver%20100%25%20XM-L2%20HL%20BDriver
Led4power%205A%20linear%20driver%20100%25%20XM-L2%20HL%20BLed
Led4power%205A%20linear%20driver%20100%25%20XM-L2%20LH
Starting from a lower voltage and working my way up does also work. Here I get to 4.1 volt, before the driver gets too hot.
This will work perfectly with any LiIon cell, they cannot maintain a voltage above 4.1 volt when loaded with 5A, even 4.35V cells.
Led4power%205A%20linear%20driver%20100%25%20XM-L2%20LHDriver
Led4power%205A%20linear%20driver%20100%25%20XM-L2%20LHLed
100% XM-L2 with fix installed
Led4power%205A%20linear%20driver%20100%25%20XM-L2%20HL%20C
With the fix installed the driver had no problems with the voltage range.
Led4power%205A%20linear%20driver%20100%25%20XM-L2%20HL%20CDriver
Led4power%205A%20linear%20driver%20100%25%20XM-L2%20HL%20CLed
20% XM-L2
Led4power%205A%20linear%20driver%2020%25%20XM-L2%20HL
At reduced power the driver has no heat problem and keeps a stable output.
Led4power%205A%20linear%20driver%2020%25%20XM-L2%20HLDriver
Led4power%205A%20linear%20driver%2020%25%20XM-L2%20HLLed
1.5% XM-L2
Led4power%205A%20linear%20driver%201.5%25%20XM-L2%20HL
The regulation at low is not completely stable with changing battery voltage. This is related to the resolution of the AD converter used.
Led4power%205A%20linear%20driver%201.5%25%20XM-L2%20HLDriver
Led4power%205A%20linear%20driver%201.5%25%20XM-L2%20HLLed
0.3% XM-L2
Led4power%205A%20linear%20driver%200.3%25%20XM-L2%20HL
Here I did catch the 3 volt warning flash, but because it is lowest mode there is no step down.
Led4power%205A%20linear%20driver%200.3%25%20XM-L2%20HLDriver
Led4power%205A%20linear%20driver%200.3%25%20XM-L2%20HLLed
100% 3xXP-G2 with fix installed
After installing the fix I also decided to do a fast check with 3xXP-G2 leds.
Led4power%205A%20linear%20driver%20100%25%203xXP-G2%20HL
These leds has lower Vf than a single XM-L2, but with enough cooling the driver can handle them.
Led4power%205A%20linear%20driver%20100%25%203xXP-G2%20HLDriver
Led4power%205A%20linear%20driver%20100%25%203xXP-G2%20HLLed
50% 3xXP-G2 with fix installed
Led4power%205A%20linear%20driver%2020%25%203xXP-G2%20HL
Led4power%205A%20linear%20driver%2020%25%203xXP-G2%20HLDriver
Led4power%205A%20linear%20driver%2020%25%203xXP-G2%20HLLed
1.5% 3xXP-G2 with fix installed
Led4power%205A%20linear%20driver%201.5%25%203xXP-G2%20HL
The saw tooth in the regulation shows up again.
Led4power%205A%20linear%20driver%201.5%25%203xXP-G2%20HLDriver
Led4power%205A%20linear%20driver%201.5%25%203xXP-G2%20HLLed
0.3% 3xXP-G2 with fix installed
Led4power%205A%20linear%20driver%200.3%25%203xXP-G2%20HL
And at the lowest level the resolution of the current meter in my power supply can be seen.
Led4power%205A%20linear%20driver%200.3%25%203xXP-G2%20HLDriver
Led4power%205A%20linear%20driver%200.3%25%203xXP-G2%20HLLed
Conclusion
The driver is a linear driver, this means the efficiency will depend on the voltage drop across the driver, making the driver better for XM-L2 leds than SST50 leds, because XM-L2 has higher voltage at high current. The driver does not use PWM to regulate brightness, this improves the efficiency in low modes.
The different UI's is interesting and works well (Just be careful not to hold down the button to long time).
I believe that the temperature trip point is too low, especially when using a high battery voltage (Led4power will change this).
With a few small adjustments this will be a good driver.
With the fix installed, this is a good driver and the problem with the temperature trip point has nearly disappeared.
Notes
The test was done with a fan to cool the driver, this cooling does not necessary match the real life condition.
The driver was supplied by a Led4power for review.
How do I test a led driver
List of all tested drivers
Werner
Werner's picture
Last seen: 2 years 2 months ago
Thanks very nice review.
I like the small efficiency table, you should make this in all Tests.
djozz
djozz's picture
Last seen: 1 hour 47 min ago
Thanks HKJ, you measure so much more than I was able to do. Very nice review!
HKJ
HKJ's picture
It is the lumen output at different currents from the led datasheet. Of course, I measured the values for the one in the review.
With a lot of equipment linked to a computer, it is easy to do curves.
musicmagic
Last seen: 6 years 9 months ago
Thanks for the review. Now I am definitely going to get one when they come out.
I only have one question: Why did you not test turbo mode?
If you can’t blind them with your brilliance, baffle them with your bullcrap.
The real currency in the world is not money, it’s trust.
RaceR86
RaceR86's picture
Last seen: 5 years 9 months ago
Excellent review as always!
BLF LED database – collaboration spreadsheet and latest news about where to buy LEDs
http://budgetlightforum.com/node/19342
HKJ
HKJ's picture
I was worried enough about my XM-L2 led with 5A, I did not want to increase the current
WarHawk-AVG
WarHawk-AVG's picture
Last seen: 1 year 6 months ago
Interesting review…I wonder if potting and/or heatsinking would stabilize some of the fluctuations
Interesting, any idea why it wouldn’t/couldn’t maintain the 5A, it seems to quickly drop down after it first powers up
Still, the efficiency at lower currents/lower levels means the batteries will last quite a bit longer than PWM based drivers
Great review as always HKJ…got lost in the graphs Smile
HKJ
HKJ's picture
WarHawk-AVG wrote:
Interesting review...I wonder if potting and/or heatsinking would stabilize some of the fluctuations Interesting, any idea why it wouldn't/couldn't maintain the 5A, it seems to quickly drop down after it first powers up
I do not see that many fluctuations.
The first version of the driver did reduce the current early, i.e. before it got really hot. When the fix it has no problem with the 5A, except when it gets to hot or it is close to the Vf of the led. The 3 different leds I tested has different Vf and that means the driver will drop out of regulation at different voltages.
Tom E
Tom E's picture
Last seen: 1 min 34 sec ago
Great review! Was "the fix" just the cap change or was there a firmware mod as well? Sorry if I missed it if mentioned.
Not sure if possible some how, but, do you think it's possible to measure resistance of the driver, or is that really a voltage drop? For example, one driver at 5A may be able to achieve 5A with a XM-L2, but another could not achieve 5A, assuming same cell, same other components (i.e. wires, mounting, etc.).
HKJ
HKJ's picture
It was just the capacitor.
That can be discussed. The best way to find it is to look at the first curve with current, find the minimum voltage where the driver can sustain the 5A, the look at the "Driver" curve for the voltage drop across the driver at that voltage. I will say somewhere between 0.15 and 0.20 volt is minimum loss. This includes the (short and thick) wires I mounted on the driver:
Tom E
Tom E's picture
It would be interesting for sure. We discussed how stacking/adding 7135's adds voltage drop because each 7135 adds to it, but think it was written off as being insignificant. I think comfy did a great job finding a low resistance FET we are using in the custom Atmel Tiny13A BLF boards, but that's of course is a DD design, using PWM's for lower modes. The popular boards right now for single cell use for us are:
  • Nanjg/Qlite (same design), w/optional stacking or an off board 7135 "farm" slave board
  • the BLF17DD, and other derivations
  • this LD-1 driver (will BE popular!)
  • the BLF15DD (similar to the BLF17DD but different small footprint FET)
Would be nice to know who they compare.
led4power
led4power's picture
Last seen: 14 hours 35 min ago
You can measure parasitic resistance of LD-1this way:
Use xm-l2 and set power supply voltage such that driver supplies 2A on high(or 3A,doesn't matter,it's only important that driver can't supply 5Amps to led,so you have kind of direct drive).Now measure voltage drop between mosfet drain(place where you solder - led wire) and gnd close to sense resistor. Parasitic resistace is Rpar=Vdrop/I.
You can also do that with other drivers.
wight
Last seen: 1 year 8 months ago
Tom E wrote:
[snip] We discussed how stacking/adding 7135’s adds voltage drop because each 7135 adds to it, but think it was written off as being insignificant.[snip]
I think it was written off because it’s not true.. You are thinking of battery voltage sag, that happens more as you put them under a heavier load. [and batteries sagging under load clearly applies to all drivers] AFAIK Voltage drop is the same no matter how many 7135’s you put in parallel. That said, I hope we find voltage drop to be lower with the LD-1 than 7135 based boards.
Use xm-l2 and set power supply voltage such that driver supplies 2A on high(or 3A,doesn’t matter,it’s only important that driver can’t supply 5Amps to led,so you have kind of direct drive).Now measure voltage drop between mosfet drain(place where you solder – led wire) and gnd close to sense resistor. Parasitic resistace is Rpar=Vdrop/I.
Thanks, I guess that’s a straightforward application of Ohms Law but I would not have thought of it by myself. That seems much more useful than coming up with an arbitrary “this is the voltage drop” figure. I guess it’s not that simple when it comes to switching drivers such as buck designs? Can we assume Rpar=Vdrop/I to be true basically anytime Iin = Iout?
Still fine, still on a break. One day I’ll catch up with you folks! previous wight catchup Wink
list of my drivers & variants (A17DD, FET+1 stuff, WIP stuff, etc)
Tom E
Tom E's picture
wight - yes, you are right about the 7135's! My freshly charged KK cells in the HD2010 can't get to 5A, the older ones are hitting ~4.25A, and newer ones maybe ~4.5A or so. I'm thinking/speculating the LD-1 might be higher resitance than a maxed out Nanjg/Qlite. I see O-L just posted a HD2010 for sale with a 16x7135 Qlite driver, so it's at least 5.8A configured - wonder if he had any cell that could achieve the max. The max I measured on the LD-1 was 5.35A with turbo enabled, using a fresh charged LG HE2 and 20 AWG LED wires.
FlashPilot
FlashPilot's picture
Last seen: 4 hours 1 min ago
Sorry if this was already mentioned somewhere, but can this driver run 3 x XML in parallel @4 or 5A each? Or would it be something like 5A/3 = 1.6A each?
Tom E
Tom E's picture
It would be 1.6-1.7A each - the driver won't know there are 3 LED's out there in parallel, just that it restricts output to 5A, unless you have turbo enabled of course. He's got turbo working like DD.
wight
I’m not sure if this is what you were asking, but it definitely can’t do that in the stock configuration. The stock configuration certainly won’t do 12A or 15A (what you asked about). It would be the 5A/3 = xx each.
FlashPilot
Oh well. Thanks from the quick replies.
wight
Why do you ask?
FlashPilot
wight wrote:
Why do you ask?
Just a few ideas I had mulling around. I use a modded SRK for a bike light with a 24 × 18650 parallel remote pack. While it does a fantastic job as a bike light that runs continuously without voltage sag, the idea of having the greater efficiency of CC in the lower modes would justify the mod. Ive also thought about hacking apart the SRK, then mounting a large CPU heat sink on the back of the emitter mounting plate so it could run at higher sustained amps. The driver would then be remote mounted on its own sink. I also thought about asking if 2 slaves could operate off one master driver, but at that point it would be hard to justify. Ive already considered vF matching the emitters if necessary. (I have at least 75 L2’s on noctigons so its not a concern) lol
wight
FlashPilot wrote:
wight wrote:
Why do you ask?
I thought you might say something like that. Why not simply wire them in series and use a buck driver?
FlashPilot
For safety and versatility. Its soldered 4.2V and I use it to power many other devices. I have no ambition to build a large capacity serial pack, deal with balance charging and then hang it under my seat. Especially considering the high G-shock it is constantly subjected to.
wight
I’m curious what other devices you run off of this monster pack?
led4power
led4power's picture
Turbo is theoretically cca 10Amps but it's designed only for single xm-l2 or xp-g2.Don't drive triples with turbo!
If you want to get 15Amps,you'll need external mosfet and sense resistor,it's possible.
You need two 10mohm sense resistors+one mosfet(I recommend you nxp psmnXXX series with maybe little lower resistance than stock).Those can should be mounted on separate pcb and heatsinked.Connect them in series with led and power supply(thick wires).On driver you need to remove sense resistor,and bring sense voltage from new (2x10mohm) sense resistors;connect gate pin on driver to gate of external mosfet,and connect driver to + battery voltage(all thin wires).I'll post schematic later.
scottyhazzard
scottyhazzard's picture
Last seen: 2 years 6 months ago
This was already a great driver. Now you have really made this into a must have if you can achieve 15 amps for 3 XMLs or 3 XPLs.
"Those who hammer their guns into plows will plow for those who do not."
FlashPilot
led4power wrote:
Turbo is theoretically cca 10Amps but it’s designed only for single xm-l2 or xp-g2.Don’t drive triples with turbo!
If you want to get 15Amps,you’ll need external mosfet and sense resistor,it’s possible.
You need two 10mohm sense resistors+one mosfet(I recommend you nxp psmnXXX series with maybe little lower resistance than stock).Those can should be mounted on separate pcb and heatsinked.Connect them in series with led and power supply(thick wires).On driver you need to remove sense resistor,and bring sense voltage from new (2×10mohm) sense resistors;connect gate pin on driver to gate of external mosfet,and connect driver to + battery voltage(all thin wires).I’ll post schematic later.
Thank you for giving this some serious thought. Im not sure if I could fab my own. Being able to supply 3 emitters @5A each + CC would be extremely useful for many of us. Once you finalize the design of your single version, could you please consider building a triple version? I think you’d sell many of them. This is starting to get very exciting! :bigsmile:
Ledsmoke
Ledsmoke's picture
Just a heads up. I sent a BLF17DD driver to HKJ this morning. After he has tome to test it yall will have all the graphs in the world to look at Smile
~ Ledsmoke ~
Dutch humor:
[quote=djozz]
 I do not think that the BLF-community ben
Tom E
Tom E's picture
Ahh, cool! Thanx LedSmoke!!
Serifus
Last seen: 7 months 4 weeks ago
I am already drooling at the thought of using this for a tripple/quad xpl
