The Peacekeeper Dual Ouput LED Flashlight from Surefire is a 15 and 800-lumen dual ouput LED rechargeable flashlight. A silent tactical tailcap pushbutton switch allows both momentary and constant-on modes. A precision reflector focuses the white LED light into a smooth, intense beam that can be momentarily activated by pressing the button down once for high output, twice for low output, and you can click either for constant-on.
The Peacekeeper is O-ring and gasket sealed for weather-resistant performance. It is powered by an included Li-ion battery which can be recharged with its AC wall charger or DC cigarette-lighter vehicle adapter. The Peacekeeper is made in the USA.
Light Performance •Low: 15 lumens
•High: 800 lumens
•White LED emitter
•Precision reflector
•Smooth, intense beam
Switching •Location: tailcap
•Type: dual-output click-type
•Momentary and Constant-on modes
•Press once for momentary high, twice for momentary low, click either for constant-on.
•Shroudless pushbutton switch for comfortable, easy use
Construction Details •1.4” diameter bezel
•Aluminum housing
•Mil-Spec hard anodized finish
•Weather-resistant, o-ring and gasket seals
•Tempered window
