i have to many headlights now. i still have not found my “perfect” Headlight yet, one with 2 or 3 modes, ( no strobes or hidden strobes) a good tint main emitter ( or moddable) and an additional switchable emitters with both red and U/V, and have a flip-down or slide-over diffuser for flood use.
I wonder that too.
I have the $7 headlamp and it came DOA. Upon checking the very thin + wire was not connected. After soldering it, it worked perfectly.I also put a DC Fix - like patch on the outside of the lens and the beam is so much better!
This new item is slightly different. The switch is on top instead of the back.
I received my $7 headlamp and it's the best $7 I've ever spent on a light. An incredible deal at $7 and still incredible at $8.90! The top switch on this makes it even nicer. I got mine in about 2 weeks time with the free shipping and no tracking.
It’s a frosted film which you put on house windows so people from the outside cant clearly see the inside. Got a 12x24 film for around $2 converted in a local thrift shop. The beam is now more similar to a sipik sk98 whem zoomed out. The hotspot is barely visible and all i see is a diffused circular wall of white light.
It works VERY well at diffusing the spot beam…makes the headlight PERFECT for in close work but still be able to blast enough light out to see if you need to far away (without the hot spot throwiness)
I have no clue since I don’t have this one but it looks exactly like the $7 one I just for except for the switch placement on the head. I would bet that is exactly the same driver.
redheadlight coupon doesn't work anymore ... Tried 1 hour ago, was working went back to review this thread, now it appears to be "Dead" .... missed out on a good deal.
