UPDATE: They got back to me and agreed to do more than one mode groups. So I’m going to go for one set of firmware from THE and another mode selection from Flashpilot.
Off time memory is supported.
UPDATE: It’s yes on the firmware and they will be sending a sample so we can check them out. They are not Nanjg105C they are made in Taiwan but supposedly the same.
_
I have contacted a supplier of drivers and ask them about a custom build for drivers.
SEE POST 47 for how the modes will end up working out. I’m going to just go with this as it sounds great and hopefully this will keep most of the people happy.
They have let me know that they will custom build drivers for me if I place a large enough order. I asked about 1,000 drivers hoping for the lowest price possible and they confirmed that they would custom build them for that amount. I suspect they would do less but I didn’t think that 1,000 was out of the realm of possibilities. These would also have low voltage protection and reverse polarity protection.
This is their reply.
I would also have to ask them how much extra for Paypal or I suppose I could try and do a wire transfer (TT). Although I’m a little leery doing one with other people’s money. I would have to have people pre-pay. (paypal gift so I don’t get into trouble with the paypal fees again) Of course no payments until I know if it’s a go or not.
Now of course I would have to get these in and then ship them out to everyone who is interested but shipping should be dirt cheap considering the size of drivers.
If you are interested please post below and I’ll run a tally and see how it goes. I’ll let it run for a while and see how many people are interested. If we get a bunch I will try and see if they will go for a lower number.
12*7135 do fit in 17mm, but not with a controller or other support hardware. I think this project is impossible if you intend to use a single double-sided PCB with 7135’s.
Where did you come up with those 5 modes? I’m genuinely just lost, is there a big demand for… those modes? I’ve probably just missed the relevant discussions, I’d love a link or two.
I think using PP gift like that is likely an abuse of the PP TOS.
I’d also like to see the answers to these questions.
As for the last one, I’m sure he meant the individuals sending PP gifts to 18sixfifty and his sending a commercial PP to the supplier once he has the funds.
Hi thanks for catching the typo. It is the AMC 7135 it’s also a two sided driver. As for how many people will be interested, only time will tell. I know I would sure like a bunch of them for all the mods I do. Stacking an extra 4 7135 is a nice little amp bump and I like the mode selection as well. I’m sure others would rather have it one way or another but I’m really not planning on getting into that. If I do there will be 50 different people all wanting them slightly different. So those are the mode selections and hopefully enough people will like that so this is a go.
For me the biggest appeal is not having to solder on extra resistors which I stink at and having the extra modes is also a big plus. Hopefully others will agree.
As for PP; I am not making a profit off of this adventure and will likely loose at least some money on envelopes and such (certainly lots of time) I think GIFT is very much the right word for it.
Correct I will be sending a paypal payment to them and PP will get their fee from that. Yes they are 7135 typo on that part. They will be stacking the resistors for us so that we don’t have to do it. Huge bonus for me anyway.
Interesting.
It depends on the individual prices if we buy half a dozen each, also i’m guessing thats a typo: (7135 and not 7134)
How big will this driver be ? will it be like the standard Nanjq Q-lite Rev 105c (but with 12 instead of 8 chips,) and 5 modes instead of the 4-modes (the moon light plus 4 higher modes)
without visible PWM in every mode, etc. if its the same size, im guessing they would have to be like the 105c with the 7135s on both sides of the board, and even maybe stacked to get twelve of them on the same size board ?
You're going to struggle to get any interest until you show a design. There are MANY problems with what you're asking.
First up is the driver itself. 12x7135 chips just fits on a 16mm board: https://oshpark.com/shared_projects/ASrNWWhu
If you upped the size of the board above to 17mm that gives you a 0.5mm thick ground trace around the outside. You could fit an MCU in the middle of the chips on the top side, and a pad in the middle on the bottom, but the MCU will have to be a very small under-lead part. It can be done, but people are going to want proof it can be done.
Another point in regards to the MCU - if it is a non-SOIC8 MCU (which is has to be to fit) people are not going to be able to reprogram it and given the fixed 5-mode firmare it'll limit interest even more.
Third problem is PayPal gifts. I think you forgo some rights if you do that and you could get shafted very easily. No way would I send a PayPal gift payment to someone I do not know personally or very, very well.
Finally, you won't get much interest around here for these drivers anyway. There are literally dozens of similar or better options available in the OSHPark thread. Yes they require assembly, but it's not hard and some of the more popular ones can be purchased pre-assembled from Mountain Electronics.
So they’d be stacking the extra 4*7135 IC’s on the top side of the driver (opposite the battery side)?
And the driver would be a normal Nanjg 105c clone in all other aspects besides the UI? eg it would use an ATtiny13A MCU / 4.7k & 19.1k resistors / reverse voltage protection diode
Im interested in several (+20) depending on the final price, firmware & test results. You should definitely test some engineering samples before putting in such a large order.
Put me down for 10,
nice timing, my Kungs driver has just gone kaput, I can use two of these in it for 8.2A :bigsmile:
I know it will be a while, no problems, it will give me some time to mod it for better cooling.
12*7135 chips with $3 shipped (I assume internationally) is good, I am interested in this.
It’s just that I think there is no point to have both 40% and 60% at the same time - they both will look very similar in brightness to our eyes. Keep the 40% level and remove the 60%. The easier way is to just follow the Qlite 4 mode groups.
Also they need to be sure the PWM frequency is very high. Other than these I am fine with this driver. Or what’s even better is to stack more chips and make it 5A on high.
On the other hand to response to someone who has mentioned about the OSHPark project, the BLF drivers are definitely interesting BUT you need to realize that some people may not have the skill/equipment to reflow the components on the board by themselves. Also for non-Americans it’s very expensive to order the finished BLF drivers from USA sellers, the shipping fees is even higher than the driver itself. So spending just $3 and one can get a high current draw driver with good modes I would believe there are still people who are interested in this stuff.
If everyone decides on another mode spacing we can do that. I’m not firm on it, I just don’t want a bunch of people dropping out or not getting in because they can’t get the one they want. You know how these things go.
Also I don’t think overseas shipping will be bad at all. Especially if you buy enough of them. It would drop the per driver cost down for you pretty good. It wouldn’t be worth it for one or two but for 20 I’m sure the price would still be pretty good.
And it's not only the mode spacing.. In fact the mode spacing is about the easiest thing to agree on.
Some people want L->H, others insists having H->L. Some like to have their lights with memory, others without. And then there's the eternal discussion about Moon/LowLow mode: "Moon mode is a must" <-> "But I want L->H and don't want it to start with Moon".
That's why it would be good to have a pre-flashed firmware that offers some flexibility.
..and if someone needs even more flexibility -> go ahead and flash it yourself.
[quote=18sixfifty]
Also I don't think overseas shipping will be bad at all. Especially if you buy enough of them. It would drop the per driver cost down for you pretty good. It wouldn't be worth it for one or two but for 20 I'm sure the price would still be pretty good.
[/quote]
Ok, that sounds good! I'll be in for at least 20 pcs, maybe 50.
