Test/Review of UltraFire SJ18650 6000mAh (Black)
11 posts / 0 new
HKJ
HKJ's picture
Last seen: 1 day 20 hours ago
DSC_5879
Official specifications:
  • Rechargeable 3.7 V 18650 6000mAh li-ion Battery
  • 6000mAh 3.7V 18650 rechargeable Battery
  • No memory effect, recharge up to 1000 cycles
  • 100% Q.C. of every battery
  • Manufactured by Hi-Capacity power products.
  • Suitable for laser pointer, flashlight torch and other electronic products.
  • Safe and environmental friendly.
  • Item size: 66*18mm
UltraFire%20SJ18650%206000mAh%20(Black)-info
This is a cheap battery from ebay with record breaking capacity according to its specifications. This is, of course, not correct.
DSC_5877 DSC_5878
DSC_5880 DSC_5881
DSC_5882
DSC_5883
DSC_5884
UltraFire%20SJ18650%206000mAh%20(Black)-Capacity
The battery can deliver about 1500mAh at low load, anything about 1A load is a problem and the two cells has different capacity.
UltraFire%20SJ18650%206000mAh%20(Black)-CapacityTimeHours
UltraFire%20SJ18650%206000mAh%20(Black)-Energy
UltraFire%20SJ18650%206000mAh%20(Black)-PowerLoadTime
UltraFire%20SJ18650%206000mAh%20(Black)-TripCurrent
UltraFire%20SJ18650%206000mAh%20(Black)-Charge
Conclusion
There batteries are not very impressive, they can drive a low power flashlight, but only about half the time a good battery can.
Also remember that these batteries are unprotected.
I will rate this as a bad cell.
Notes and links
Compare to 18650 and other batteries
aoeu
aoeu's picture
Last seen: 1 week 3 days ago
This one-upmanship is getting a bit ridiculous. By December we’ll be seeing 10 000mAh 16340!
Your work is appreciated HKJ!
tkmckay
Last seen: 11 months 2 days ago
Great to see just how bad these sorts of cells are in comparison to the usual Panny/Sanyo/LG/Sammy cells. Thanks HKJ for another review!
FlashPilot
FlashPilot's picture
Last seen: 10 hours 46 min ago
Redneck slingshot ammo! Im in! :bigsmile:
Richwouldnt
Richwouldnt's picture
Location: Reno, NV, USA, Terra, Sol, Milky Way, Known Universe
Be interesting to see what is actually in these cells considering that they actually have only 20% to 25% of the claimed capacity depending on current draw. Pretty crappy current capability too.
Rich Wood
Reno, NV
HKJ
HKJ's picture
I did open one crappy battery, it looked fairly normal: http://lygte-info.dk/info/batteryDisassembly5000mAh%20UK.html
FlashPilot
Those cells were probably made on the other side of the shack where they also make those fancy new ultrafire spark plugs (guaranteed to triple your fuel economy). I got a set for only $50 and now my car wont start! Darn those crafty people for scamming me again!
feral
feral's picture
Last seen: 3 years 4 months ago
G’day all. A little bit of eye-balling will show the vast discrepancy between the two cells that have been denuded. One seems to have 10/11 coils of li-Ion material whilst the other has 20/21 coils. One would think this would have a large bearing on the cells “capacity”? The black SJ UltraFire weighs 41gms, whereas an up market cell is 50 odd, (Pana/Sony/LG/Samsung/etc). I would suggest the latter are better/tighter wound and therefore higher in Coulombs. Bottom line is, I call them “fake” – not “bad”.
I would like to see an adventurous member dismember an SJ. I’m too old and clumsy. Glasses
Just old fashion common-sense.
HKJ
HKJ's picture
https://lygte-info.dk/info/batteryDisassemblyUltraFire%20UK.html
feral
feral's picture
Fast as lightning. Didn’t exactly expect an answer from you. It is a very old post. Thanks for the update. I only got the SJ’s recently and was not happy with their weight to start with. So I did a discharge test as well as weighing them. Eight of them weighed .204kg in total, in their package. Considerably lighter than your listed weight 39 or 41 I’ve seen both whilst reading. And as I suspected, the SJ is lightly wound and down on coils, as I suspect all cheap cells will be. At least eBay bought into it and I got a total refund. Lesson learned. Cheers.
HKJ
HKJ's picture
Today it is probably made the same way as the GTL18650 I have disassembled here: https://lygte-info.dk/info/BatteryDisassemblyGTL%20UK.html
