Hi Guys!
to calm my Lady down a little i had to buy her a Light.
a purple one…
a small one…
has to run on “normal batteries”…
must be purple…
keychain is necessary…
did i point out that it has to be PURPLE???
since i had some coupons from gearbest (Dreamcharger GB) i decided to go with Olight and found” the i3s (in purple ;))“:http://www.gearbest.com/led-flashlights/pp_26977.html
from Olight website:
Key Features:
*Three brightness levels from 0.5 to 80 lumens, plus a strobe mode
*Output set by twisting head to cycle through modes
*High efficiency CREE XP-G2 LED provides plenty of light in a tiny package
*Durable aircraft-grade aluminum body, reversible stainless steel pocket clip, and keychain
*Available in five attractive colors: red, blue, purple, gold and black
*Comes in a handsome hard shell gift case
10 days later i opened a bubble-foil-filled Envelope and out came a very nice giftbox:
filled with a tiny, purple light and a AAA Battery ready to illuminate!
also 2 spare O-Rings and a Usermanual found place in that box
anodisation and engraving are first class
there is no tailcap - batteries are filled in from the Head
the end of the battery compartment is naked to make contact with the head - which works as a “twisty”
the threads are square cut and well lubed
orange peel reflector
perfect centered LED
(excuse the cathair? - the lens is without scratches!)
tailstand IS possible!
due to the nice mouning “ring” (triangle?) which lets the keychain rotate free
even at the lights side is a tiny Carabine
purple (did you see???) nice light in my Hand
fits good!
the UI is simple:
loose (which is not “loose” due to the O-Ring) is OFF - or lockout if you like
tighten to get MID (20 Lumen - 8 hrs)
loosen it -> off
tighten again to get HIGH (80 Lumen - 35 min)
loosen it -> off
tighten to get it on into Moon Mode (0,5 Lumen - 60 hrs)
loosen it -> off
then it starts again with MID - HIGH - Moon…
not soo simple:
open-close 7 times to get into STROBE
no mode memory - starts always in MID after some seconds OFF
my conclusio:
great small PURPLE light!
-> comes also in black, red, gold, blue
