Add Protection to Unprotected 18650 Batteries
8 posts / 0 new
doslyn
Last seen: 11 months 1 day ago
Is it possible to add protection circuitry to unprotected 18650 batteries? If so, where would a person buy the parts to do this?
Crux
Crux's picture
Last seen: 3 months 4 weeks ago
It looks like DX.com has some SKU: 26114 is for 14mm dia cells they may have others.
MRsDNF
MRsDNF's picture
Two different ones here. It appears they are either 2 or 4 amp.
http://www.fasttech.com/products/1616/10003003/1225103
doslyn
Thanks. I know this is a stupid question, but how do you attach these to the batteries? Do you have to solder to the negative end?
Richwouldnt
Richwouldnt's picture
Last seen: 11 months 2 days ago
Location: Reno, NV, USA, Terra, Sol, Milky Way, Known Universe
Battery Junction offers protection circuits too.
http://www.batteryjunction.com/pcb.html
Rich Wood
Reno, NV
Helios-
Helios-'s picture
Last seen: 2 years 1 month ago
Personally I would avoid any protection pcb which doesn’t use a seiko chip. Seiko is regarded as the best, all of the better batteries seem to use them. Protection chips sometimes fail, I suspect the failure rate is higher with those other random chips.
2pc 18650 4A-6A Seiko protection $5.98 ($2.75 / piece) free shipping.
20pcs 18650 4A-6A Seiko protection $25.66 ($1.10 / piece) free shippping
Wire strips
Kapton tape is used to isolate the wire.
Anatomy of a Protected LiIon Battery
Counterfeit 18650s, 2,<a href=“http://
leaftye
Last seen: 1 year 1 month ago
They're welded, but you may have to solder.  A battery tab welder costs about $150.  There's a guy on the other forum that plans to do a write up when he gets his.
The low mode should be lower.
comfychair
comfychair's picture
Last seen: 5 years 8 months ago
Just adding more stuff to go wrong. Use quality unprotected cells, charge them properly, check them often. You should be doing those things anyway.
