Hi I have lost the 120v input for the intellicharger.
But it has 12v input!
So i created (From old external hard drive power supply) a 12 volt, 750miliamp power supply.
is this enough?
12v * 750ma = 9 watts power supply output
4.2v * 750ma*2 = 6.3 watts charging power for 2 cells
4.2v * 375ma*4 = 6.3 watts charging power for 4 cells
this charger has a broken port, and only charges 3 cells max anyway.
seems sufficient?
By “lost the 120v input”, do you mean it no longer works, or you lost the cable?
(LI-ION)
straight from HKJ’s 2014 review. All four bays work on his, so YMMV.
zelee
(zelee)
August 24, 2014, 9:29pm
3
is this enough?
seems sufficient?
got the same problem,must be the fuse has been fry.
still looking for spare but i can’t find it on my local store
ryansoh3
(ryansoh3)
August 24, 2014, 10:40pm
4
A 750mA 12V power supply may be a little bit too small for the charger. Try digging around for a 12V 12A wall wart, you must have some of those in your house.
keengeorge
(keengeorge)
August 25, 2014, 12:15am
5
Good Day ryansoh3,
I think You mean 12V 1.2A wall wart (& not 12V 12A)
Btw, Nitecore specs state Input: AC 100-240V 50/60Hz 10W, DC 12V 10W
Which means that for DC 12V 10W, You need higher than 0.8 Amps (DC Watts=Amps x Voltage).
So a DC 12V 0.9A (or higher Amps) Power Supply will do.
Best Regards,
George
ryansoh3
(ryansoh3)
August 25, 2014, 12:25am
6
Thanks for the correction George, you are keen indeed.
Yup, a 12V 1A or better power supply would do.
Turby3Pots
(Turby3Pots)
August 25, 2014, 12:58am
7
drat. thanks for the research guys; i bet i could have done the searching myself…
anyway, i need 10 watts, and have 9… of course!
we’ll see… maybe a slow charge…
