I will be making two brass keychain lights using very small cells. One will go to a female member and the other will(I hope) go to a members wife/girlfriend. This thread is for suggestions on battery(10180 vs 10280 vs 10440), led(XP or Nichia), drive current, twisty or tail clicky, etc… At some future date I will start a registration thread for the giveaways.
At the moment I’m envisioning a 50mm tail standing tail clicky with a 2-mode(moon-med) driver and either a 12mm reflector or slightly out of focus aspheric.
It will be hand made, like my contest builds but way smaller.
If this meets with little or no interest then I’ll figure out something else to do with an ultra thin Tiny10. I guess we’re well past that point now.
at this point still going for 50mm 10180 tail clicky and the angle head 10440 should end up ~ 80mm.
This is a very nice gesture of yours RBD. My wife was naughty. Does that mean she is ineligible? Should I just nominate my girlfriend? I hate making decisions.
I think 10180 is the best choice for a keychain light. It’s quickly annoying to have a big thing on my keyring.
Plus IMO, a keychain flashlight is used very sporadically, just to see the keyhole… So small, floddy but still powerful enough to light a path. (350mA should be good!)
1 mode is plenty enough for a keychain flashlight!
I propose .5A and 50mA off a 10440, mode memory optional, small reflector for a large floody hotspot, or a small wide pattern 10mm optic, high cri / neutral tint, depending on what you want. A 219, xpg-2 and xp-l all fit the bill.
Afraid of sounding sexist or anti-feminist or je ne sais pas, but what if it was shaped like a lipstick, twisty like? like, a square prism shape. Easy to twist two squares, motion that some are already accustomed to, less likely to roll around. Downsides: perpetuating the notion that women need makeup; shining light in ones mouth instead of applying lip paint; probably much harder to make, DIY like.
I vote XP for smallest battery, nichia for other two batteries. I feel like when I have more capacity, I can afford to sacrifice efficacy for nicer tint.
So… if I were (hypothetically) a woman with a girlfriend, I could enter twice?
Hold on, I need to go talk to someone about … elective surgery …
Honestly, it depends how small you can get a switch down to.
I’ve got a DQG tiny and it either shreds o-rings, turns on in my pocket or the head unscrews itself, so I’d prefer a small clicky
No, it’s you, Steve. Turnover on my mods isn’t quite up to the speed of most others so it’s understandable if you’ve forgotten making a bunch of 12mm sections for me, especially since this is the first opportunity I’ve taken to use them. Originally they were going to sleeve the heads of solitaires but I haven’t done one of those in awhile and have since discovered the joys of making entire lights from scratch.
