2xAA utility lights
43 posts / 0 new
TeeJay37
Thanks, bikenber. I’ll put that on the list. Does it say what the low level is?
Bort
Bort's picture
Last seen: 1 hour 36 min ago
bikenber73 wrote:
I have ordered from this Store before and received exactly what was described 3 times in the past 4 months.
Crelant V21-A for $21.90
here is more infomation, the numbers are all wrong though, hihg is maybe 250 lumens at hte most and lasts about an hour
http://www.crelant.com/led-flashlights/v-series/new-v21a-flahslight-2aa-...
the medium and low are probably also wrong as are the runtimes
The Journal of Alternative Facts TM
"It is critical that there is a credible academic source for the growing and important discipline of alternative facts. This field of study will just keep winning, and we knew that all the best people would want to be on board. There is a real risk in the world today that people might be getting their information about science from actual scientists"
TeeJay37
Thanks Bort. They didn’t mention it had a mid level on the other site. I don’t mind if it’s not 450, as that’s not really what I am looking for.
The specs list actually contradicts what is in the pics, so it really doesn’t surprise me that some stuff is off. The spec list says 450/128/13 while the picture says 450/210/30
Bort
Bort's picture
Its sitting in the car, i don’t like it at all, the runtimes are low, the lumens are not high, the light is not well designed, and it makes random sizzling/hissing noises while its running, i haven’t used it since last year and it works but i don’t recommend it.
I think you should seriously consider the starry light linked above, it may be 4AA, but it will put a smile on your face
DavidEF
DavidEF's picture
Last seen: 1 week 4 days ago
Bort, do you know what the approximate runtimes are for the Starry Light?
- The YKK Philosophy
Bort
Bort's picture
I have tested these (except the super low, i use the light too much to test it, in 12 hours it dropped 10% which is what the batteries do when recharged and left for a day)
Bort wrote:
This is a great light, they seem to be selling whats left so its unlikely they will make more but it uses 4AA (which is actually even better)
super low 2 lumens (450-500 hours – 2000mA batteries)
low 20 lumens (50 hours – 2000mA batteries)
medium 200 lumens (4 hours – 2000mA batteries)
high 600 lumens (1 hour – 2000mA batteries)
http://cnqualitygoods.com/goods.php?id=1980
Use NiMH rechargeables, alkaline will perform poorly and you will think its the lights fault, and keep in mind lithium will not do well in high temps, so don’t leave them in the car (in the house is fine)
Bort
Bort's picture
I should have mentioned the modes are
0.2%
2%
25%
100%
I suggest using the 100% for less then 10 minutes at a time, the head will get hot enough to burn you if left on too long, think of it as a manual turbo, you often see 30-90 second turbos on other lights, this is one you can control.
There is one quirk/flaw, sometimes when you switch modes it turns off instead of going into the mode, just change modes again and it will come back in the following mode (i call it the missed mode issue)
DavidEF
DavidEF's picture
Okay, I’d seen that post above, but somehow missed that those numbers were for the Starry Light. Thanks! :bigsmile:
Bort
Bort's picture
no worries, its a great light, its now my most used light (due to the durability of the batteries)
flyboy
Last seen: 1 month 3 days ago
The RayOvac Indestructible 2AA light might be what you can use. 2 modes, waterproof, fair runtime. I don’t really need one, but it will probably be on sale for Black Friday. Wink
It Is A Fine and Pleasant Madness
1dash1
1dash1's picture
Last seen: 2 years 6 months ago
Did you notice that they make the flashlight in left-handed and right-handed models?
Look closely at the battery configurations. They are mirror images of each other!
Rule 1-1 as it applies to life, take it as it comes.
SawMaster
Last seen: 2 years 1 week ago
No lights to recommend, but for stored lights Lithium primaries or good NiMh rechargables (Eneloops are very good) is the way to go. LIons are much better in performance but require special handling and care plus they do not store well under a full charge. They are best for lights that are used often and regularly.
Rare is the instance where you can get every parameter you seek in one light, so my approach is to list them in importance, set the list aside a few days to think about it, revise if needed, then search for what I want compromising the least important aspects as I must. Price matters a lot to me but I find it usually inhibits getting what I really want- it is cheaper to buy the right light once than to find you need to buy another because the first one disappointed. And with a good quality light, it will last for many years- maybe a lifetime in storage- so that makes for good economy regardless of initial cost.
And welcome to BLF Smile
Phil
