Test: Efest 18350 700 mAh V1
7 posts / 0 new
leaftye
Last seen: 11 months 2 weeks ago
Packaging
Photos
Top & bottomLabel pic
Discharge Graphs
Charging Graphs
Notes
Batteries provided for testing by: Coval Vapes
To simplify testing and prevent mistakes, batteries in each test were charged at 0.5A and discharged to 2.80V.
More battery tests here.
Donations.
The low mode should be lower.
Edited by: leaftye on 09/10/2014 - 16:13
leaftye
This is the first test to use the upgraded testing equipment.  I'm going to try to use that equipment to update the old reviews within the next week.
WarHawk-AVG
WarHawk-AVG's picture
Very nice….but daggum the 3-5 min run time on that teeny 18350 at 10A wow
Still getting 10A continuous out of a teeny 18350 IS something to write home about!
Great review…on par with HKJ reviews…excellent, can always use more excellent and full spectrum testers of batteries, HKJ set the bar but you guys are getting close…and this in depth testing is the ONLY true reporting of the capabilities of batteries
Excellent review!
ledoman
Last seen: 6 days 4 hours ago
Leaftye, nice review agan. How do you compare it with Basen 18350? I know I could look the graphs, but you probably already know it. Ok I've take a look -> http://budgetlightforum.com/node/33325. Basen looks better up to 5A. What's went wrong at 10A there?
leaftye
The Basen has more capacity up to 5A, but the Efest has less voltage sag.  The Basen couldn't perform at 10A continuous, which was confirmed with both the Reaktor and M9712C.  If I didn't have buyers coming to look at the house soon, I'd make a comparison graph...I'll see about doing that later.
I just realized I put a typo in the specifications for the Basen.  The maximum discharge rate should be "20C5rate" instead of "20°5rate".  What does "5rate" mean?  It means 5 second pulses.
blueb8llz
Last seen: 5 hours 17 min ago
how do these compare with the AW 18350’s? did they get dethrone yet?
WarHawk-AVG
http://lygte-info.dk/review/batteries2012/AW%20IMR%2018350%20700mAh%20%2...
HKJ didn’t test em at 10A I believe
