Triple XP-L Convoy S2 MTN Edition BLF17DD Review
149 posts / 0 new
Bort
Bort's picture
Last seen: 11 min 3 sec ago
hank wrote:
I keep saying we need ray-gun-type cooling fins.
I just found the ideal hardware to mod with the latest, hottest emitter:
what is that?
The Journal of Alternative Facts TM
"It is critical that there is a credible academic source for the growing and important discipline of alternative facts. This field of study will just keep winning, and we knew that all the best people would want to be on board. There is a real risk in the world today that people might be getting their information about science from actual scientists"
nofearek9
nofearek9's picture
Last seen: 17 hours 23 min ago
what kind of wires you used for this triple ? 18-20awg?
Turby3Pots
Turby3Pots's picture
Last seen: 8 months 3 weeks ago
You know I have no idea. Whatever wires rmm connects to the blf17dd
Legolas Jr.
Legolas Jr.'s picture
Last seen: 3 days 12 hours ago
Should be 22AWG.
“Strive to be a warrior and a scholar. Be forged in fire and tempered by knowledge. If not, you will either lack the courage to fight for your ideals or lack ideals worth fighting for.”
nofearek9
nofearek9's picture
i assumed that for 10Amps you will needed thicker wires .
theLIGHTINGDUTCHMAN
Last seen: 4 years 1 month ago
3000+ lumens on a single 18650 EDC format light?! Me likey Shocked
Bringing light to the Netherlands
Jubeldum
Jubeldum's picture
Last seen: 5 years 8 months ago
How many lumens could you get with only 3 amps driving this?
Turby3Pots
You know it’s not clear, but 10 amps is really great
pilotdog68
pilotdog68's picture
Last seen: 7 months 5 days ago
At 4.0v and a distance of less than 3 inches, 22AWG will carry close to 20A, assuming 5% loss
hank
hank's picture
Last seen: 1 day 6 hours ago
Bort, that was an attempt at humor, about cooling fins: the link is to http://www.rayguns-r-us.com/
Bort
Bort's picture
It was a rare non attempt at humour, it just looks futuristic, thanks for the link, i thought it might have been the gun marvin the martian used.
Caleb-v
Caleb-v's picture
Last seen: 3 weeks 3 days ago
i just built one of these lights and i get 6.2a with a blf17dd and sony vtc5. does anyone else get more?? i would like 10a. lol maybe il try changing the standard wires to 18 gauge.
RMM
RMM's picture
Last seen: 1 year 9 months ago
You don't need 18 AWG wires, the 22 AWG are just fine for 9A-10A.  What is your current measuring setup?  If you are using multimeter probes then you have a huge problem right there.
Mountain Electronics : batteries, Noctigon, and much more! What's new?
Turby3Pots
Hahahahaha oh Richard.. Where is that FAQ you were talking about?
As rmm alluded to, the problem is in the meter leads you are using. If you measure the 6 amps, and then touch the leads together circumventing the multimeter, and the light gets brighter, there’s your other 4 amps.
vresto
vresto's picture
Last seen: 8 hours 33 min ago
question-i will do my own tripple xpl.will be a big difference,if i will use IMR or Unprotected 18650? in the output of lumens…or is it the same? i use original branded ones..
EDC-Sofirn IF-25A Lh351d, Mezzol X8R-L xhp70 nw, Astrolux ST01 xhp50
Headlamp-Thrunite TH30 nw
Turby3Pots
Do not use unbranded batteries ever.
If you want max lumens, unprotected is a must.
And a high drain battery is preferred, such as the 18650GA or a 30Q
T-boon
Last seen: 9 months 2 weeks ago
comfychair wrote:
DavidEF wrote:
comfychair wrote:
Thermal pastes only work where the layer is very thin, like microscopically thin. In thicker layers it acts as an insulator not much better than air. To get the thin layers required usually means very flat highly-finished surfaces and high clamp loads, things that are usually not possible in most flashlight parts other than like between MCPCB & pill top, pill flange to head surfaces, or rather tight press-fit pills.
Okay, wait. You’re saying that thermal paste, something that is supposedly made for helping to conduct heat between two surfaces, is just barely better at conducting heat than air? That is hard for me to understand. According to Engineering Toolbox, even Styrofoam (made to NOT conduct heat) conducts heat better than air. Plain ole Epoxy has a thermal conductivity that is almost 15 times that of air. Insulating brick (didn’t know that existed) conducts heat at a rate 6.25 times that of air. Yes, these are still relatively tiny amounts, because the only thing that air conducts heat better than is a vacuum. But, we’re talking about thermal paste. It should be pretty good, I’d think, at doing what it was made for – especially compared to leaving the air void that would be there if the paste wasn’t! edit: to clarify, there are several gases on the list that are less heat conductive than the air we breathe, but I call them all ‘air’ for the purpose of these comparisons.
Yes, that’s exactly what I’m saying. Your ideal insulator, styrofoam, could very well be a very good conductor at a thickness of 1-3 microns.
edit: And this is why these reference charts are misleading at best. You have to know how to interpret the data as it applies to a specific situation, and if you don’t know how to do that, you’ll think you understand something you really don’t.
comfy, you say “And it definitely won’t help between the other parts of the threads that aren’t physically touching.”
but David say it will help,
then you say “Yes, that’s exactly what I’m saying.”
got me confuesd :-/
i mean, how can air be any better then thermal past? even if it is more then 1-3 microns.
i do how ever agree that you need to know how to apllay it.
vresto
vresto's picture
http://rtdelectronix.com/flashlights/custom-lights/
if anyone is interested,there are triple flashlites in very“good” prices:)))))))))))))))))))
vresto
vresto's picture
i have a question-difference between 3 xpl and 3 nichia newset will be? 3000 lumens vs.2500?
RMM
RMM's picture
vresto wrote:
http://rtdelectronix.com/flashlights/custom-lights/ if anyone is interested,there are triple flashlites in very“good” prices:)))))))))))))))))))
Indeed. Triple “custom” P60 for $99.99 as well (I obviously did not build that driver!)
RMM
RMM's picture
You can get a bit more than 3000 from the XP-L HI, while the 219C can almost reach 3000 OTF with a single 18650 due to the low vF, but it quickly settles down to 2500 or less.
vresto
vresto's picture
well.my first build triple xpl with BLF A6 body is not happy idea..probably i need spacer for space between star with leds and the dropin…too much space there…
but the outpur is beatiful:)
do i need really a spacer for convoy s2 BLUE?
nofearek9
nofearek9's picture
yes you need spacer for all convoys version or at least copper washers do the trick.
vresto
vresto's picture
http://www.mtnelectronics.com/index.php?route=product/category&path=25_95
hm..which one would fit into blf a6?
my first modding is painfull:)))
RMM
RMM's picture
How long is the stock reflector?
vresto
vresto's picture
11 mm..
RMM
RMM's picture
vresto wrote:
11 mm..
Then you would want the S2+ spacer.
vresto
vresto's picture
question-how will fet driver blf working with the triple xpl?the same function? cos as i know,there is turbo timer.30 seconds or so.how will it work in this upgrade?
also-do we need longer wires,when we will use the spacer?
also-do we need cut the base of the carclo optic? cos they looks little bit longer,then we need…iam not yet sure..
nofearek9
nofearek9's picture
for the convoy hosts you need longer wires,the optic dont need to be cut.the fet driver will work as before but expect on high to get near 10amps if you have good battery.
vresto
vresto's picture
