Mobile Solar Power Bank
6 posts / 0 new
fellfromtree
fellfromtree's picture
Last seen: 7 years 2 months ago
This looks like a good deal http://www.gearbest.com/mobile-power-bank/pp_15137.html
Has a coupon code: Solar5000
I was thinking of wiring it so it could be charged with a regular charger like the opus. Then it could trickle charge when your outside. Wouldn’t be bad if it was on a holster or something like that. Anyone use these and how long does it take to charge from drained to full?
leaftye
Last seen: 1 year 1 month ago
The rating is bs.  384mA from that tiny panel?  Not likely.  100mA would be surprising if it was pointed directly at the sun, and the output would be far less if it wasn't.
The low mode should be lower.
Serifus
Last seen: 9 months 2 weeks ago
Ive had something like that, it didnt work very well, and went with a 10 watt pannel from fast tech, it works better
fellfromtree
Thanks.. I was thinking if it takes too long to charge- oh well
Richwouldnt
Richwouldnt's picture
Last seen: 11 months 3 days ago
Location: Reno, NV, USA, Terra, Sol, Milky Way, Known Universe
Way too small to put out much power for recharging the batteries plus good old Chinese specifications list the size of the panel as thicker than the packaged unit so far as I can determine. Does that mean they crush it prior to shipment? Shocked
Rich Wood
Reno, NV
WarHawk-AVG
WarHawk-AVG's picture
There is a way, more or less a very slow trickle charge
Texas Instruments has a IC that boosts the very low voltage up to charging levels in order to charge 4.2vdc Li Ion batterys, but it does it at very low currents…like 100-200mA at best
Sure…setting it out you could trickle charge if you needed it but not fully charge the internal battery w/o external USB help, I don’t think something that size would be 5K mAh, more like 2000 maybe
adafruit has a charger somewhat like that, they have 6vdc panels as well
Still for under $20…get one and you tell us how well it works out Wink
