High CRI led bulbs
32 posts / 0 new
Barkuti
Barkuti's picture
Last seen: 7 hours 41 min ago
mdeni, you may want to peek at these: 3-4x3 W Watt High Power LED Light lamp Driver Power Supply 85-265V 600mA
600mA constant current drivers, with adequate output voltage range. With 3 pieces in parallel, ≈1.8A of driving current. Also, having multiple supplies gives you a redundancy reliability advantage: if one of the drivers goes poof, the light will just dim a bit, so you'll know its time to swap a driver.
Cheers Party
Deleting a post and redoing it causes the forum thread answer notifications to become invalid. Thus, if you need to change your just published post, edit it. Thanks.
Please avoid quoting lenghty posts, namely with nested quotes. Trim the quote down to the essential. Helps with forum neatness and legibility. Thanks.
Localized AliExpress links mess up with the language setting of whoever clicks or taps on them. While this is a fault of the AliExpress system, turning localized links into global links helps and is easy; just change the locale letters in the url for www. Example:
https://es.aliexpress.com/item/bla-bla-bla.html turns into https://www.aliexpress.com/item/bla-bla-bla.html. Thumbs Up
