CANCELLED -- Group Buy for Trustfire TR-S700
84 posts / 0 new
AlexGT
AlexGT's picture
Last seen: 1 day 11 hours ago
is it really waterproof as JM says on his review? How are the wires from the switch water proof? O rings, silicone sealant ? are the threads glued?
Thanks!
jmpaul320
jmpaul320's picture
Last seen: 1 month 3 days ago
I got my trs700 neutral white xml2 yesterday from trustfire direct
measured 3500 lumen OTF Smile
Would you mind keeping the wrong flashlight?
Best wish, May
Tmart service team
Soumil wrote:
PLEASE HELP ME GEARBEsT! IM LITERALLY CRYING!
Richie086
Richie086's picture
Last seen: 7 hours 24 min ago
Thanks!
Alex, Trustfire rates the S700 as IP VI or IP X6, Protected against heavy jet spray for at least 3 minutes.
Richie
Richie086
Richie086's picture
JM,
JohnnyMac measured exactly 3578 lumens OTF for the XM-L T6 version with his Calibrated Integrated Sphere. If you’re getting 3500 lumens, whether OTF or gross lumens, I’m still happy with that, especially since it’ll maintain close to that even on HIGH mode. Thanks for the information.
Richie
jmpaul320
jmpaul320's picture
JM,
i measured 3578 otf at turn on and 3490 @ 30 seconds on kinoko imr 26650…. lowest output setting is around 0.25 lumen Smile
I think JM has the cool white xml and we have nw xml2 which is why they are about the same
Best wish, May
Tmart service team
Richie086
Richie086's picture
jmpaul320 wrote:
JM,
JMPaul,
Does your S700 go into strobe mode when the slide switch is pushed all the way forward?
Richie
jmpaul320
jmpaul320's picture
Richie086 wrote:
jmpaul320 wrote:
JM,
JMPaul,
I dont think so? Ill have to double check when I get home.
one thing it does do which is rather annoying – if you leave it tailstanding on a very low mode for 10-15 minutes, it bumps up in output to like 150 lumens for no reason…. did it 3 times last night.
Best wish, May
Tmart service team
Richie086
Richie086's picture
I’ll check mine and see if it does the same thing.
Richie
Richie086
Richie086's picture
I had the lens off to check the diameter and thickness in case I come across an AR coated lens for this.
After I reassembled it, I installed the KeepPower Protected 26650 5200mAh cells and adjusted it to the lowest firefly mode. It stayed on for 4-5 minutes and turned off. Although the battery compartment fully closes with these longer cells, I do know from experience, longer cells can cause issues crushing internal components to much.
I removed the batteries, used a lint-free cloth with a bit of alcohol and cleaned off the “B” side of the driver. This time I installed the KeepPower UNprotected IMR26650 cells and turned it back on to firefly mode. It’s been running for 20 minutes putting out much less light than a single birthday candle and seems perfect.
Brightness seems perfectly consistant, whether anything I mention here actually had anything to do with it not suddenly turning off now, I’m not sure.
I will mention from a previous post from Member, Richwouldnt, to get the slide switch adjusted to the lowest firefly mode can be slightly tricky, and he was correct.
Richie
jmpaul320
jmpaul320's picture
Brightness seems perfectly consistant, whether anything I mention here actually had anything to do with it suddenly turning off, I’m not sure.
agreed about the lowest mode(s) being tricky… the slider goes from like…. nothing….. click for on… still nothing… move it 1mm… hey! 400 lumens! LOL… takes some finesse but its there.
I have some unprotected keep power 26650 im going to try as well…. been using the kinoko imr 4000mah and the included TF cells so far… im glad i didnt bother with protected keep power…. theyre too big for anything it seems
Best wish, May
Tmart service team
Richwouldnt
Richwouldnt's picture
Last seen: 10 months 3 weeks ago
Location: Reno, NV, USA, Terra, Sol, Milky Way, Known Universe
One silly question for everyone. Why is this about the only light from a “budget” Chinese maker that seems to have a reasonably accurate Lumens out specification? Based on measurements the actual OTF lumens are within 10% of what members are measuring real life. If they can do it for this one, and actually did so, why the ridiculous outputs listed for other lights like the TR-J20 and virtually every other light that TrustFire makes? Is this light made primarily for the Chinese military or government and they require accurate specifications?
I would like to see Trustfire become the first large budget manufacturer in China to list accurate specifications for ALL their products.
Rich Wood
Reno, NV
Richie086
Richie086's picture
Photos updated with detailed driver pics.
S700 Driver Photos
Richie
jmpaul320
jmpaul320's picture
even the blind squirrel finds a nut sometimes LOL.
honestly i dont know though… maybe the guessed?
but you would think that if they continued with the ‘inflated lumen’ claims this would be a ’6000 lumen’ light min
Best wish, May
Tmart service team
Richie086
Richie086's picture
Hi Rich,
Last night, Ms. Pinky Cao, the Trustfire Rep I was dealing with, contacted me to confirm the S700 was delivered in a safe manor and if I was happy with the light. In fact, she assured me prior to the sale, Trustfire would build me an excellent light exactly as I ordered it, and it would be perfect. Well, true to her word for sure.
You have great communication skills. If I were you, perhaps you might email her directly, and perhaps, she may be able to pass on to her superiors the industry really needs to change with respect to your questions above. Just a thought.
pinkycao@trustfire.net.cn
Richie
leaftye
Last seen: 1 year 1 month ago
Richwouldnt wrote:
One silly question for everyone. Why is this about the only light from a "budget" Chinese maker that seems to have a reasonably accurate Lumens out specification? Based on measurements the actual OTF lumens are within 10% of what members are measuring real life. If they can do it for this one, and actually did so, why the ridiculous outputs listed for other lights like the TR-J20 and virtually every other light that TrustFire makes? Is this light made primarily for the Chinese military or government and they require accurate specifications? I would like to see Trustfire become the first large budget manufacturer in China to list accurate specifications for ALL their products.
There isn't really direct competition for this light, so maybe they realized they could be honest and not lose sales to the competition.   What would the competition be?  I think it would be halfway between the Supbeam X40 and X60.
The low mode should be lower.
Richie086
Richie086's picture
leaftye wrote:
Richwouldnt wrote:
One silly question for everyone. Why is this about the only light from a “budget” Chinese maker that seems to have a reasonably accurate Lumens out specification? Based on measurements the actual OTF lumens are within 10% of what members are measuring real life. If they can do it for this one, and actually did so, why the ridiculous outputs listed for other lights like the TR-J20 and virtually every other light that TrustFire makes? Is this light made primarily for the Chinese military or government and they require accurate specifications? I would like to see Trustfire become the first large budget manufacturer in China to list accurate specifications for ALL their products.
There isn’t really direct competition for this light, so maybe they realized they could be honest and not lose sales to the competition.   What would the competition be?  I think it would be halfway between the Supbeam X40 and X60.
I’m loving this light the more I use it. It easily runs and works on HIGH mode even with just one 26650 cell in it thanks to its parallel battery arraingement. There is no difference in brightness that I can see, visually, whether using 1 or 3 cells. All the cells fully equalize, just like a Skyray King does, as long as the battery compartment is in full contact and not locked out.
I haven’t been able to get a tailcap current reading for some reason. I was able to accomplish it on the SkyRay King, but for some reason, it wouldn’t work on this one. I’m curious to know, depending on the type of cells used, if it really operates at 10 amps, more or less, on HIGH mode.
Richie
B42
B42's picture
Last seen: 1 month 1 week ago
Looks like a nice light with nice tint, I’m also kind of surprised they didn’t say it was 8,000 lumens or something around there. But they also charge significantly more for this light, you paid $170 right? Maybe this light was built for a company in the US or Europe somewhere, which required accurate specifications and a sturdy light, and this “line” is the result.
Richwouldnt
I paid just under $120 from FastTech including shipping with the BLF discount. Another member paid the $170 direct from TrustFire including warmer XM-L2 LED upgrades and DHL shipping as I recall. Mine is with RMM currently for similar work including copper Noctigons and anything else he can figure out to try to SAFELY up the output and improve thermal transfer.
BTW it is heavy enough and feels rugged enough to make one heck of a skull cracker if necessary. the TR-J20 would have the advantage of a longer reach but both could be hellacious skull crackers if required.
Rich Wood
Reno, NV
Richwouldnt
The thing I note which surprises me is that even with all the discussion of this light and the fact that it is such an unusual configuration there are only THREE people who have gone on the buyers list. My excuse is that I ordered mine before the group buy was posted but apparently the appeal for a really large handled light is minimal even though in my opinion it is a very convenient format, particularly with the continuously variable output power switch. With no hidden modes it is a pretty much foolproof user interface.
Richie086; I suspect the difficulty with the current reading is that you need to imitate the switch electronics reading for full output on a jumper between the two innermost contact areas on the driver, the center dot and the smallest ring as shown in post 58. It looks like they are the transfer/control points for the switch position information which controls the electronics drive to the LEDs.
Rich Wood
Reno, NV
texas shooter
Last seen: 4 hours 4 min ago
I still want one and may just have to breakdown and pay the extra.
Richie086
Richie086's picture
Hey B42,
The light itself with the LED option was $87.38. The 3 Trustfire cells were $16.50. I opted for faster shipping via FedEx, which was about $59.00 extra. Aside from the high shipping price to get it here quickly, the light and real Trustfire batteries I consider a steal for them.
I just hate waiting many weeks for lights, so I assume I limit damage to them getting them here fast.
Richie
sunbeam
Last seen: 5 years 5 months ago
the infinite control seems pretty cool
leaftye
Richie086 wrote:
B42 wrote:
Looks like a nice light with nice tint, I'm also kind of surprised they didn't say it was 8,000 lumens or something around there. But they also charge significantly more for this light, you paid $170 right? Maybe this light was built for a company in the US or Europe somewhere, which required accurate specifications and a sturdy light, and this "line" is the result.
Hey B42, The light itself with the LED option was $87.38. The 3 Trustfire cells were $16.50. I opted for faster shipping via FedEx, which was about $59.00 extra. Aside from the high shipping price to get it here quickly, the light and real Trustfire batteries I consider a steal for them. I just hate waiting many weeks for lights, so I assume I limit damage to them getting them here fast.
The price for the light alone is nice, but supposedly the cost of shipping is high because the >2kg weight means lower cost options aren't available.  My last shot will be trying to get the light shipped without the box, which will hopefully get the weight under 2kg and allow inexpensive shipping options.
