C to D Size Battery Adapters Source? HELP!
22 posts / 0 new
Richwouldnt
Richwouldnt's picture
Last seen: 10 months 3 weeks ago
Location: Reno, NV, USA, Terra, Sol, Milky Way, Known Universe
AA to D battery adapters are available in multiple versions, holding from 1 to 3 AA batteries. AAA and AA to C adapters are also readily available as are AAA to AA adapters. I have some four AAA to C adapters on the way.
What I cannot find are single C battery to single D size battery adapters. Does any one have a source or am I going to have to make my own? I presume that they exist as I ran across a reference to them but nothing shows up via a Google search.
Rich Wood
Reno, NV
Edited by: Richwouldnt on 09/21/2014 - 00:55
Wilson
Wilson's picture
Last seen: 3 years 10 months ago
Are you looking for single D size?
This adapter takes 3 or 4 C’s (so they say). Looks like in series, so I imagine the voltage to be 4.5 or 6.
http://www.manventureoutpost.com/products/C-Battery-to-D-Battery-Adapter...
Quote:
This adapter will allow you to use 3-4 C sized batteries in a 3D host light. Specifically designed for 26650 and 25500 Lithium Ion batteries. This allows you to increase the voltage and performance in your modified 3D host light. Features an o-ring for retention. The adapter will not slide out during a battery change, but it is removable without tools.
Inquire…Choose…Proceed
Bort
Bort's picture
Last seen: 13 min 35 sec ago
I used to have some but i never used them so they went in the recycle bin years ago, i probably got them at dollar store or princess auto (harbour freight type store i think)
The Journal of Alternative Facts TM
"It is critical that there is a credible academic source for the growing and important discipline of alternative facts. This field of study will just keep winning, and we knew that all the best people would want to be on board. There is a real risk in the world today that people might be getting their information about science from actual scientists"
Richwouldnt
Wilson;
Yes looking for single D size adapters. The item you found is for high power LED converted Maglite lights or similar it looks like to me. Lights like Old Lumens makes.
Rich Wood
Reno, NV
Fritz t. Cat
Fritz t. Cat's picture
Last seen: 2 years 1 month ago
Don’t see why one would want to put a smaller battery than the size of the space. Apparently there are even C and D Eneloops, though I don’t know where they can be found. My car uses a couple hundred D size nickel metal hydrides.
Flashlight designers should look at lighthouses and pottery.
这些谁设计的手电筒应该看灯塔,以及在陶器。
Richwouldnt
I have seen the D Eneloops on ebay, shipped from Japan, and they run about $50 each. One post on CPF IIRC showed the internals which were three AA Eneloops. Rather have Tenergy Centuras. Cheaper and greater capacity.
I would like to have the adapters so I can use C NiMH in D battery lights and lanterns if needed in an emergency or when want lower weight or battery cost, the same basic reasons why lots of people want to use single AA to D adapters in some applications. I get the impression that the C to D adapters were made at one time but may have been discontinued due to lack of demand. As a hobbyist machinist I can make a batch out of Delrin and copper rod if necessary but I thought that they should be available commercially somewhere.
Rich Wood
Reno, NV
Bort
Bort's picture
I suspect those C and D eneloops are fakes, but this is what i used to have, in blue and green, they were hard plastic and were pretty brittle
Link
I have never heard of this website but its the same adapters as i had, AAA to AA, AA to C and C to D
Ricflair
Ricflair's picture
Last seen: 2 years 2 weeks ago
Try wrapping in foam. I have done that a few times in a jam. Or paper & duck tape.
RicFlair is on the air with blonde hair & pink underwear!! Whaoooooo!
Richwouldnt
Found out where I had seen them. LaCrosse Technology includes four of the AA to C and C to D adapters as pictured by Bort in post #6 with some of their NiMH battery chargers. Not listed as available separately that I can find.
Rich Wood
Reno, NV
jerm03
Last seen: 3 hours 29 min ago
I have a 3 C cell MagLite and do not want the batteries to corrode. It is next to my bed and almost never used. So to keep from potentially ruining the light due to leaking cells I got some AA to C adapters and put eneloops in it. Much cheaper than eneloop C cells even if available.
So the answer is cost.
Jerry
Gj
Gj's picture
I used to see them a lot in discount & dollar stores. I bought a bunch, 2-pack of nested AA to C inside a C to D adapter (4-pieces) for $.79, so it could be used as a AA to D as well with both pieces. They must be in the house somewhere but where? Undecided
Hmm?
Richwouldnt
Cost versus capacity is one reason. The Tenergy Centura C size LSD batteries are actually cheaper than Eneloop high capacity batteries per battery for much greater capacity and current capability so if people use single AA to D adapters then why not C to D adapters.
Rich Wood
Reno, NV
bladesmith3
bladesmith3's picture
Last seen: 7 months 2 weeks ago
I used to make the spacers from c cell to d flashlight by cutting a piece of plastic tubing I got at lowes for about $2 but ay tubing that fills the space between the battery and the light would work. even rolling a piece of toilet paper roll and scotch tape.
bladesmith3
I just checked. LaCrosse Technology does include c-d adaptors in the charger kit. I never looked in the carry bag that came with the charger.
king
Last seen: 5 years 3 weeks ago
I am from ept-battery company ,a CHINESE nimh battery factory ,we are glad to send you more information for your reference .
you can contact me directly by email:sales02@ept-battery.com
geovel56
geovel56's picture
Last seen: 4 years 7 months ago
Hello all,
I have 1000's of C to D adapters available.  I am selling them on eBay.  I would much rather sell them outside eBay because of the eBay and PayPal fees, which means the cost to you would be cheaper
If interested, please contact me at:  geovel56@yahoo.com
Battery Buddy™ product description and instructions are below:
The product is called “Battery Buddy™,” which adapts the size of ANY “AA” battery (heavy duty, alkaline, rechargeable, etc.) to a “C”and/or “D” size battery. Battery Buddy™ provides the convenience of buying/storing one size battery only, and NEVER worrying about what size battery your electronic devices require. In essence, with Battery Buddy™, you NEVER need to buy the much more expensive C and/or D batteries again!
1 package contains two (2) "AA" to "C" adapters and two (2) "C" to "D" adapters (total of 4 pieces)
Also available are: Box - contains 12 packages
                            Case - contains four (4) boxes (total of 48 packages)
1000+ packages are available.
Simple as 1, 2, 3
Battery Buddy™ has a 3-In-1 application:
  1. “AA” to “C”
  2. “AA” to “D” and
  3. “C” to “D”
The expected use duration of a “AA” battery is approximately one-fifth of a“D” size battery. The expected use duration of a “AA” battery is approximately one-third of a “C” size battery, however the cost of operating the same device using one "AA" battery vs. one “C”battery or "D" battery is substantial. This means YOU SAVE MONEY in addition to convenience!
Battery Buddy™ is ideal for use in electronic devices which require batteries such as:
  • Flashlights
  • Clocks
  • Toys
  • Portable Stereos/Radios
  • Small Appliances, and so much more!
  • Great in EMERGENCY situations – If the “C” or “D” batteries in a device (such as a flashlight) are “dead” simply use “AA” batteries from another device you have available which uses "AA" batteries, and Battery Buddy™ for “C” and/or “D” size battery required devices, OR “C” batteries from another device and Battery Buddy™ for devices which require “D” size batteries.
  • The uses are endless!
Instructions for using Battery Buddy™ are as simple as One, Two, Three!
3-in-1 uses
ONE
For use in devices which require “C” size batteries:
  1. Insert any “AA” battery into the Battery Buddy™ “C” size adapter.
  2. Insert combined assembly into your device.
(Note: One (1) Battery Buddy™ “C” adapter is required for each battery your device requires.)
TWO
For use in devices which require “D” size batteries:
  1. Insert the Battery Buddy™ “C” size adapter into the Battery Buddy™ “D” size adapter.
  2. Insert any “AA” battery into this assembly, negative (-) end in first such that the (+) end is
    showing.
  1. Insert combined assembly into your device.
(Note: One (1) Battery Buddy™ “C” adapter and one (1) Battery Buddy™ “D”adapter is required for each battery your device requires.)
THREE
  1. Insert any “C” battery into the Battery Buddy™ “D” size adapter.
(Note: One (1) Battery Buddy™ “D” adapter is required for each battery your device requires.)
©Copyright 2008, Ellengie, Inc. All rights reserved.
brad
brad's picture
Wouldn’t we still be using Paypal? What is your eBay site?
geovel56
geovel56's picture
Hi Brad,
Thanks for your question.
Yes, you would still be using PayPal, but using the payment option of "sending money to a Friend or Family" is FREE for everyone involved vs. using PayPal to pay for an item option (then there is the PayPal fee).
Another FREE option if someone doesn't have a PayPal account, but they have a Chase Bank account, is Chase Quick Pay.
Each package contains 2 AA to C and 2 C to D (total of 4 pieces).
The eBay link for 1 package (4 pieces):
http://www.ebay.com/itm/282036491247?ssPageName=STRK:MESELX:IT&_trksid=p3984.m1586.l2649
2 packages (8 pieces):
http://www.ebay.com/itm/282036504876?ssPageName=STRK:MESELX:IT&_trksid=p3984.m1586.l2649
4 packages (16 pieces):
http://www.ebay.com/itm/282036505496?ssPageName=STRK:MESELX:IT&_trksid=p3984.m1586.l2649
Hope this helps. If you have any questions whatsoever, please contact me at: geovel56@yahoo.com
Thanks,
George
snakebite
snakebite's picture
Last seen: 6 days 20 hours ago
panasonic sold a similar kit.should still be common on ebay.
aa to c and c to d.
a kit of 4 sets was 3.99 shipped a few months back.
and they work well.i have a bunch.great for testing stuff without stocking c or d cells.
we use rechargeable aa in most everything so these are nice to have.
SawMaster
Last seen: 1 year 3 months ago
Snakebite, can you provide a link to where you bought yours? The more sources we have the better off we are!
Phil
snakebite
snakebite's picture
not seeing any now.but will post if i see them again.
would probably order a few sets of the ones offered here if i wasnt already set.they seem to be the same ones i have other than brand.
geovel56
geovel56's picture
Hi all,
For anyone interested in C to D adapters, please see my post above (about 2 weeks ago).
They are available on eBay under the product name Battery Buddy.
I sell them on eBay.
Feel free to contact me at: geovel56@yahoo.com
